![]() Join Date: May 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 92
(Thread Starter) | Not Ranked : 0 score I posted these results in the jerky throttle thread, but decided to make a new thread at the requests of other members. I used the app translation in combination with the throttle req. load tables to get a smooth and powerful map. The results are awesome. Very responsive and linear thottle, while not being too sensitive. I think the lag problem caused by linear load tables is best fixed with the app tables. The stock app tables are set up to work with the stock throttle req load tables that ramp up load quickly. That being said the app table I posted above is made to work with the load table I posted below. I used the same app table for all gears. App translation to be put in all gear app tables other than neutral. Code: 0.00 0.32 1.28 2.85 4.52 6.18 7.85 9.51 11.37 13.04 14.83 16.63 18.42 20.22 22.01 23.81 28.30 32.78 37.27 41.76 46.25 50.74 55.22 59.71 65.69 72.41 79.12 82.48 85.83 92.55 100.00 Code: 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.64 0.46 0.34 0.21 0.21 0.21 0.21 0.21 0.21 0.21 0.21 0.21 0.21 0.21 0.21 0.67 0.68 0.61 0.43 0.43 0.43 0.43 0.43 0.43 0.43 0.43 0.43 0.43 0.43 0.43 0.68 0.77 0.80 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.69 0.80 0.90 0.87 0.87 0.87 0.87 0.87 0.87 0.87 0.87 0.87 0.87 0.87 0.87 0.69 0.81 0.94 1.09 1.09 1.09 1.09 1.09 1.09 1.09 1.09 1.09 1.09 1.09 1.09 0.70 0.82 0.95 1.31 1.31 1.31 1.31 1.31 1.31 1.31 1.31 1.31 1.31 1.31 1.31 0.70 0.83 0.96 1.52 1.52 1.52 1.52 1.52 1.52 1.52 1.52 1.52 1.52 1.52 1.52 0.70 0.82 0.97 1.70 1.70 1.70 1.70 1.70 1.70 1.70 1.70 1.70 1.70 1.70 1.70 0.70 0.83 0.97 1.88 1.88 1.88 1.88 1.88 1.88 1.88 1.88 1.88 1.88 1.88 1.88 0.70 0.83 0.97 2.06 2.06 2.06 2.06 2.06 2.06 2.06 2.06 2.06 2.06 2.06 2.06 0.70 0.83 0.97 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 0.70 0.83 0.97 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 0.70 0.83 0.97 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 0.70 0.83 0.97 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 0.70 0.83 0.97 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 0.70 0.83 0.97 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20 2.20
__________________ [SIGPIC]http://i163.photobucket.com/albums/t318/dreadedhero/DSCN2058-2.jpg[/SIGPIC] 2007 ms3 sport black mica completely stock Last edited by dread; 05-22-2009 at 09:59 AM. |
| The Following 10 Users Say Thank You to dread For This Useful Post: | 94jedi (05-29-2009), Arrowpoint (05-24-2009), bioevolve (05-22-2009), Fobio (05-22-2009), jahman (05-22-2009), justint5387 (01-27-2011), kgb (05-22-2009), Nliiitend1 (07-15-2009), RichB (10-14-2009), Smoker6 (05-22-2009) |
| Driver ![]() Join Date: May 2008 Location: Toronto
Rep Power: 1986 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,158
Groans: 44
| Not Ranked : 0 score I will give this a go this wknd.
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- |
![]() Join Date: Jun 2008 Location: Raleigh NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 36
| Not Ranked : 0 score Just tried it out. Feels great so far. Very good throttle response like the ots maps but much much more linear. |
![]() Join Date: Mar 2008 Location: State College, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,091
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score I knew you'd like the app tables. I havent messed around with them too much but it looks like you have. I'll be trying this on my next map.
__________________ 07 Mazdaspeed3 |
(Thread Starter) | Not Ranked : 0 score nice glad you like it smak. I love the way the car drives. Now I'll be done once I finish tuning out my high rpm knock
__________________ [SIGPIC]http://i163.photobucket.com/albums/t318/dreadedhero/DSCN2058-2.jpg[/SIGPIC] 2007 ms3 sport black mica completely stock |
![]() Join Date: Jun 2008 Location: New Port Richey, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,984
Groans: 88
| Not Ranked : 0 score I'll try this too tonight and see how if works....must say your tweaks have really helped.
__________________ FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute JAM SESSION........US Amps (in Series w/ Stock Amp) using OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back) RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors - Acne Rear Bumper LED Reflectors |
![]() Join Date: Aug 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 49
| Not Ranked : 0 score Applied these to my map to be flashed tonite, and then after some more logs I'll have to tune out my WOT knock. |
(Thread Starter) | Not Ranked : 0 score I already cut my knock in half by adding fuel, and lowering load. The problem I am having is my boost is too high above 5k rpm and my turbo is probably a flame thrower. My next map is using the boost throttle close tables to limit boost up top. I am just hoping the throttle only closes slightly and doesn't slam shut.
Groans: 44
| Not Ranked : 0 score definitely brings the wild child back...just enough that I'll keep these changes for the dyno and track map for the next 2 wknds...for the commute, I may go back to your original throttle fixes, so I have a little bit more pedal play to vent frustration on the commute...thanks!
![]() Join Date: Sep 2008 Location: Missouri
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 276
| Not Ranked : 0 score Dread, thanks for all the info you are generously sharing with the forum. You've always impressed me with the amount of time and effort you put in not just for yourself but for the others on this forum. I just wanted to point that out. I'd like so see a complete map with all your changes. According to what I've read and from my testing it seems to hold true that whichever values in the Throttle req load tables and the gear specific load tables is lower are the values that get used. Are the values in your gear specific tables set high to force the ecu to use the throttle req a and c tables. I am begining to think that posting the values in one of these tables without the values in the other is useless since depending on what those values are the ecu may be switching back and forth between these three tables. I know it's a pain in the ass but if you could post the map or better still the values in all your tables? It would be extremely helpfull. I can see dissadvantages to the pieces parts method of info exchange we are useing now. This full disclosure is going to become more inportant as we learn more widely how all the tables relate to each other. Last edited by Arrowpoint; 05-23-2009 at 07:41 AM. |
| The Following User Says Thank You to Arrowpoint For This Useful Post: | 94jedi (05-29-2009) |
(Thread Starter) | Not Ranked : 0 score I still use the gear based load tables but those don't come into affect until higher throttle requests. I like the gear based tuning. I am not sure how to upload maps I keep getting errors. I will post them up if someone tells me how.
(Thread Starter) | Not Ranked : 0 score Ok I figured it out. here is the map stage 1+93 octane cali spec with dread's special sauce. Nevermind the forum won't let me attach the same map in two places. It is 107h in the tuning out knock thread.
| The Following User Says Thank You to dread For This Useful Post: | Arrowpoint (05-24-2009) |
![]() Join Date: Nov 2008 Location: Citrus Heights, CA
Rep Power: 0 ![]() ![]() ![]() Thanks: 0
Interested to try the APP translation changes you made. Thanks. | |
| Not Ranked : 0 score +1^^^ I know it's a pain but if you can spare the time it would be great. I haven't tried yet but I don't think my ATR Fed will load the Cali maps. |
| Not Ranked : 0 score If you use dreads map, be very careful and watch your logs closely. Its not that dreads a bad guy...its just his load values are close to 2.00 in some places. His car and mine have the same exact mods, yet, I'm making the same boost as he is with values in the 1.75 range. If I used 2.00...i'd boost 27 psi and knock the hubble telescope out of orbit with one (or more) of my rods. My point being...all of our cars act differently. This is why the OTS maps were so unsuccessful. Be careful with this software, itd be very easy to start getting careless as some of us become more confident with its use.
(Thread Starter) | Not Ranked : 0 score Yes I do not recommend copying my maps onto your ecu. My load values are pretty high for some reason. I actually lowered them from the custom map christian gave me. I think my car is a freak, I out dyno'd stage 2+ guys on the 102 maps.
| Not Ranked : 0 score I've been slowly increasing the gear load tables and am peakiing in the 190's. The car is pulling harder than it ever has. Boost is peaking at 20psi and tapering nicely to 17psi. I don't want to use the map. I'm in a Fed model. I want to load the map into ATR and compare it to stock and the map I'm running now. I was running peakes in the 180's and getting LTFT's of -2,0,1,2 but when I got into the 190's LTFT's went to 2,4,8,10 so now I guess I'll either reduce load values or go back to the MAF. |
(Thread Starter) | Not Ranked : 0 score arrow, load doesn't affect ltft's, give them more time to settle foster, I am not sure what you are looking for, everything you need is in the first post. All the other changes I have made were to tune out the knock. Just copy the app trans data into the table for each gear.
Groans: 44
| Not Ranked : 0 score there may be some confusion is terminology here... dread posted values for a few tables. A collection of all the tables makes a map. You should just apply dread's values/tables to your corresponding tables in your own map. My car spikes to 22 psi...holds mid 18's...it's been this way whether I was running dread's values or not.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 194
Have you or anyone else datalogged any WOT runs with these changes? If so, did you notice any changes with WOT KR? | |
| Not Ranked : 0 score This doesnt affect WOT KR. Infact at WOT the ECU ignores the req load tables and goes by load by gear. APP tables really only have to do with the throttle response.
| The Following User Says Thank You to jahman For This Useful Post: | Speedn3 (05-27-2009) |
(Thread Starter) | Not Ranked : 0 score ha beat me to it.
| The Following User Says Thank You to dread For This Useful Post: | Speedn3 (05-27-2009) |
![]() Join Date: Dec 2008 Location: Philly, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
Groaned at 5 Times in 1 Post
| Not Ranked : 0 score These changes feel great. I did notice that they changed my LTFT though the high LTFT went from +3 to +8. |
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score These changes have no effect on ltft's. Something else is affecting them or your map needs more time to settle.
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score I have done a ton of logs, this doesn't affect WOT load and does not change KR.
![]() | | #26 | ![]() |
| Not Ranked : 0 score Since I've did the throttle smoothing I have not seen much if any part throttle kr. |
![]() | | #27 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
| Not Ranked : 0 score Has anyone done any dyno testing to see if/how this might affect the torque/horsepower curves? |
![]() | | #28 | ![]() |
![]() Join Date: Oct 2009 Location: Denver, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 47
| Not Ranked : 0 score I just made these changes and went out for a quick spin and love it. My WOT power feels about the same but the part throttle drivability is so predictable now. I love It! Thanks for all of your research Dread. I can't wait to see how my drive in to work feels tomorrow. Once I get my MAF cal where I want it, my req load tables per gear are next.
__________________ 2007 Cosmic Blue Mazdaspeed 3 GT |
![]() | | #29 | ![]() |
![]() Join Date: Sep 2011
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Its supposed to work on 2e gen? Because my APP table have only 20 values but the fix here have 31 values Im using the 1st dread's fix(without app mod) but if he said, linear throttle reponse make lag, i really want to try this one. But if i change APP, that will affect something else? I try to get back my pedal feeling when i had hypertech! A linear aggressive pedal response Last edited by Mini Franki; 08-13-2013 at 09:24 AM. |
![]() | | #30 | ![]() |
| Not Ranked : 0 score bump |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f418/using-app-translation-tables-smooth-powerful-results-28444/ | ||||
| MS3/ATR: Smooth Throttle Fixes (May 23, 2009) - TorontoMazda3 | This thread | Refback | 05-23-2009 07:56 AM | |
| Boost Control for Smooth Response | fjames | Cobb ATR Support | 51 | 10-28-2011 05:00 AM |
| Smooth throttle test | thejake | Cobb ATR Support | 15 | 05-17-2009 01:08 PM |
| Smooth out driving / shifting | KayWhy | MazdaSpeed 3 - Engine, Transmission & Driveline | 24 | 04-15-2009 01:18 PM |
| Pontiac G8 GT: No longer most powerful car under $30K | Haltech | Automotive News | 0 | 06-18-2008 02:20 PM |
| Rumormill: Audi considering more powerful RS6 Avant | Haltech | Automotive News | 0 | 05-15-2008 01:50 PM |
