![]() | | #41 | ![]() |
| Not Ranked : 0 score
![]() | | #42 | ![]() |
![]() Join Date: Oct 2011 Location: San Leandro, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 460
Groans: 87
| Not Ranked : 0 score I put 15k so far and no issues. It lives at 20psi so nothing aggressive. The stock clutch can only handle so much... It's a TD05. I'm guessing a standard TD05 rebuild kit would work. There are places you can send your turbo to have rebuilt. I rather have it professionally checked out and balanced but that's just me. How much is CS charging for a CHRA?
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT |
![]() | | #43 | ![]() |
![]() Join Date: Apr 2014 Location: Brisbane, QLD, Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 225
| Not Ranked : 0 score Looks like I might have just joined the blown CST4 club. Done about 20,000 km in my CX7 tuned for max boost of 24psi. Just moved it to my MPS3. Still on the running in oil. Now blowing clouds of smoke. I will try and add video.
__________________ CX7 - The younger, taller and sexier replacement for the MS6. 2007 CX7 2.3 DISI AWD | Forged Build | Mahle Pistons | Molnar Rods | APR studs | Corksport Turbo @25psi | ETS TMIC | Cobb XLE BOV | CS HPFP | JBR 3.5" WPI | Cooling Mist WMI | CS OCC | CX9 20x7.5's | CX9 Brakes | Pedders Lowered 40mm | VersaTuned by Stratified |
![]() | | #44 | ![]() |
| Not Ranked : 0 score OK here is video attached.
![]() | | #45 | ![]() |
![]() Join Date: Mar 2013
Rep Power: 0 ![]() Thanks: 0
I contacted Corksport about a rebuild kit. The following is my e-mail to them, and their response.
| The Following User Says Thank You to thrice For This Useful Post: | Ozynigma (06-19-2019) |
![]() | | #46 | ![]() |
![]() Join Date: May 2013 Location: Ponce, Puerto Rico
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
| Not Ranked : 0 score Dam! I was considering on doing CS Turbo but with these reviews, I think ill stay with K04 and do meth with K04
__________________ Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS |
![]() | | #47 | ![]() |
| Not Ranked : 0 score K04-Meth seems to be fairly successful. My "no experience with meth" opinion would be to start tapering in the meth around 3500-4000. If it will be an on/off switch, maybe wait a little later. Stock block of course.
![]() | | #48 | ![]() |
![]() Join Date: Mar 2017 Location: Milwaukee
Rep Power: 0 ![]() Thanks: 3
| Not Ranked : 0 score Sorry to hear about that @thrice. $800+ shipping + what you already paid for it seems ridiculous. You would think CorkSport would get V1 owners those hot sides for cost with it being a design flaw. But the community would benefit greatly if you found another common 18g CHRA that was compatible because I’m sure there’s thousands of CST4’s out there. Good luck to you sir! Looking forward to your findings
__________________ 2008 MS3, Cobb AP V3, JBR 3.5 WP, CS 3.5 BAR, BNR S3 V2, JBR RMM 88 Duro, JBR TMM 70 Duro, Cobb TBE, EBCS, autotech HPFP, E85 mixed to E30, Snow Stage 2 WMI, (Stratified Tuned "Not for WMI") ITV22's, Koni yellows. |
![]() | | #49 | ![]() |
| Not Ranked : 0 score So I haven't pulled my blown CS turbo out of the car yet. It will be done in the next two weeks. I have decided not to rebuild it and thrice reply above shows its probably not economical, at least not with genuine replacement parts. I have bought a Mamba GTX2871R (Garrett) clone. No more journal bearings for me.
![]() | | #50 | ![]() |
1) CS turbo 2) BNR S3 3) GTX2867 4) GTX2871R and i was told that the CS Turbo was the fastest spooling turbo of all 4 so i was decided on it but now with all these bad experiences i'm kind of holding back on CS.
__________________ Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS | |
![]() | | #51 | ![]() |
The Turbine housing i will be diagnosing and attempting to port the IWG path on my YouTube channel (shameless plug) https://www.youtube.com/channel/UC4i...dxJu9mCcPU_hzA as well as the turbo teardown and bearing measuring for other Mazdaspeed owners to see incase they too are wanting to take the risk of purchasing a used and potentially blown turbo. The good news, both the Compressor and Turbine wheels look almost brand new, just with some oil on them. No bent blades, chips or cracks. Which should mean, as long as i mark the shaft tip, nut, and front face of the compressor wheel with "alignment marks" for when i reassemble the turbo, i (in theory) shouldn't need a re-balance. All MHI turbos are triple balanced (Compressor wheel, Turbine wheel, then again once fully assembled) So as long as the wheels or shaft are not damaged in any way, their weights should not have changed or shifted. The bearings are made of softer material so that they wear out and not the turbine shaft, hence, a rebuild-able CHRA core. | |
![]() | | #52 | ![]() |
![]() Join Date: Sep 2017 Location: Western Mass
Rep Power: 43 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score I have 18k on my cts4 with zero issues, tuned to 24psi and sees it quite often.
__________________ 06 Speed6 White/Black interior Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts To think... this is suppose to be my winter car... because, '72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far '12 1/2 Triumph Daytona 675R stock some how '79 AMC Spirit AMX, 4.6L stroker I6 |
![]() | | #53 | ![]() |
| Not Ranked : 0 score Minor Update. Reached out to Corksport once more hoping for more information if possible. The following is my e-mail to them and their response.
I want to give a large thank you to @Corksport for showing support for their products even though they don't have to divulge any information at all. They're real stand up people over there IMHO. | ||
![]() | | #54 | ![]() |
| Not Ranked : 0 score FWIW, I regularly push mine to 28psi. Shit, nevermind. I already posted that.
![]() | | #55 | ![]() |
If you can afford it go the Garrett. I don't love my car that much so I went the Mamba clone. In my personal opinion, based on general reading and understanding and not actual dyno graphs, I doubt anything is going to overall perform better than a GTX2867R if you want fast spool and boost to redline. I was expecting 10's, maybe 100 thousand kilometres out of the CST4, so its pretty disappointing that it has failed at 20,000 kms.
__________________ CX7 - The younger, taller and sexier replacement for the MS6. 2007 CX7 2.3 DISI AWD | Forged Build | Mahle Pistons | Molnar Rods | APR studs | Corksport Turbo @25psi | ETS TMIC | Cobb XLE BOV | CS HPFP | JBR 3.5" WPI | Cooling Mist WMI | CS OCC | CX9 20x7.5's | CX9 Brakes | Pedders Lowered 40mm | VersaTuned by Stratified | |
![]() | | #56 | ![]() |
| Not Ranked : 0 score For anyone that is still curious about the 1st generation Corksport Turbo (As well as the new CST4), I have a video of taking apart the used one I bought now live on my YouTube channel. https://youtu.be/2hJxsO9ZXFA |
![]() | | #57 | ![]() |
Finally got around to pulling it out. I have got the intake off and the shaft would only spin a ¼ turn each way by hand. I was able to work it through the resistance in the bearings, now it will spin whole revolutions but its grindy AF. So another CS turbo failed at low (20,000km) mileage. I am not happy. In fairness to Corksport I will double check that oil supply etc is all good when I put the replacement Mamba turbo in. It was a brand new flexible oil line and still on new running in oil when it failed though.
![]() | | #58 | ![]() |
| MSF's Punishing Member ![]() Join Date: Apr 2011
Rep Power: 2794 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,165
Groans: 546
| Not Ranked : 0 score not sure if it applies for the cs turbo, but the bnr turbos suffered heavily from oil contamination (such as you'd see during engine break in) destroying the bearings.
__________________ 94 M MS6 IS350 |
![]() | | #59 | ![]() |
| Not Ranked : 0 score I put 10k miles on my new engine with a CS turbo that probably already had about 10k+ miles on stock block. Turbo is still good.
![]() | | #60 | ![]() |
That is a possible mechanism for my failure as it has got progressively worse making whirry noises until it stopped working and started smoking. Not that I am sure what the remedy would have been, except changing oil and filter even earlier than I did.
![]() | | #61 | ![]() |
Or, use a TD06SL2 turbine wheel/shaft with a modified GTX3071 superback compressor wheel to essentially turn your CST4 into a CST5. Machining will be required on the CHRA and you'll need to purchase an MHI 3" Anti-Surge GTX3071 TD05/TD06 compressor housing from Mamba. A whole new turbine housing would be required as well as the CST4 only uses a .64 A/R housing (9cm2). From what research i've done, it seems Corksport uses Mamba wheels. My compressor wheel had a Mamba part number on it + an additional letter, probably signifying who the customer was. | |
![]() | | #62 | ![]() |
![]() Join Date: May 2015
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 68
so about the oil contamination thing... was there something that could have been done to prevent it from breaking? (like an oil change 1k after install) or it happened just because? | |
![]() | | #63 | ![]() |
Also no filings on the sump plug or any obvious contamination in the oil. There might well be a different problem in my case like poor oil supply, maybe a fragment of metal caught in the oil supply restrictor hole.
__________________ CX7 - The younger, taller and sexier replacement for the MS6. 2007 CX7 2.3 DISI AWD | Forged Build | Mahle Pistons | Molnar Rods | APR studs | Corksport Turbo @25psi | ETS TMIC | Cobb XLE BOV | CS HPFP | JBR 3.5" WPI | Cooling Mist WMI | CS OCC | CX9 20x7.5's | CX9 Brakes | Pedders Lowered 40mm | VersaTuned by Stratified Last edited by Ozynigma; 09-04-2019 at 02:21 AM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #64 | ![]() |
![]() Join Date: Feb 2012 Location: San Antonio, TX
Rep Power: 1139 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,253
Groans: 50
Groaned at 37 Times in 21 Posts
| Not Ranked : 0 score Upgraded oil feed line with a filter will stop this, change the filter every other oil change.
__________________ 2010 Velocity Red w/tech package: Cobb AP, Cobb DP, Tr8L FMIC, Auto Tech internals, BNR S-4 turbo, JBR 3.5 aluminum intake, CPE stage 2 rmm, JBR 80 duro TMM, JBR 70 PMM, JBR SSP and bushings, JBR 5mm spacers, JBR RSB, JBR By Pass Tube, Magna-flow CBE with the "fix", NGK 6510's, JBR EBCS, SSP OCC(now Kozmic), JBR EGR delete, EGR deleted, JBR IM TIG, JBR TB TIG-coolant by-pass, Turbo smart BPV, built block with CP pistons, eagle rods, ported head, pinned cams, shimmed valve springs, Spec clutch stage 3, FordMoCo full syth transmission fluid, Eibach pro kit, ported IM with VCTS delete, ported exhaust mani, Werksracing strut tower brace, TB Performance front traction bar and mid-chassis brace, Corksport adjustable struts and shocks, slotted/drilled rotors, SS brake lines, and lots of TLC. FreekTuned Kotzur built 93/E-85 Prius killa. |
![]() | | #65 | ![]() |
| Not Ranked : 0 score I must have about 13k+ miles on my CST4 and have not noticed any major oil consumption with it or play, seems like I check it two or three times a year and it doesn't feel any different from new according to memory.
![]() | | #66 | ![]() |
| Not Ranked : 0 score |
![]() | | #67 | ![]() |
| Blown turbo | acidhalo | 2010 MS3 - Turbo Induction | 24 | 10-16-2013 03:08 PM |
| Blown Turbo? | finalems3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 7 | 07-24-2013 09:37 AM |
| Blown Turbo | HawkNasty | MazdaSpeed 3/6 - Big Turbo Builds | 15 | 08-21-2012 04:51 PM |
| Blown Turbo????? | sacredmonkey | Mazdaspeed3/6 General Discussion | 10 | 02-15-2012 01:56 PM |
