> 2010 MS3 - Turbo Induction
  • 2 Post By shamie
 Old 05-10-2019, 05:36 AM   #1
eliwwjd's Avatar
Posts: 518   (View Stats)
Default Decision to make on turbo upgrade
Ive been planning on upgrading my turbo but its been hard for me to make up my mind.
At first i wanted a ball bearing turbo but ive seen that all 4 models that ive considered al journal bearing. My goal is 400hp stock block limit, but at the same time have the closest spool of oem K04 turbo. I will also be doing corksport cams and big 3.5 intake from htp.
The turbos that have been on my decision list are:
1) CS Turbo
2) BNR S3
3) GTX2867
4) GTX2871
I know i need some auxiliary fueling to achieve 400hp.What is your turbo recommendation to achieve 400hp with the least spool time?
Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS
 Old 05-10-2019, 11:02 AM   #2
Oshiguru's Avatar
Posts: 102   (View Stats)
Oshiguru is a name known to allOshiguru is a name known to allOshiguru is a name known to allOshiguru is a name known to allOshiguru is a name known to allOshiguru is a name known to all
According to Stratified's page and dynos i've seen on this forum. Your best bet for the numbers are the latter two, and for closest spool the first two. I personally wanted the same spool time as the K04 to replace my turbo and I was set on getting the CS turbo. Opted against a turbo upgrade as I didn't realize it would require me to upgrade my DP, buy a 3 port, possibly injector seals with ++ power, and more.
MazdaSpeed 3/6 Garrett ATP Big Turbo + Custom Tune Package [MZSPD_ATP_Package] - $1,750.00USD : Stratified Automotive Controls scroll down
Oshiguru is offline   Reply With Quote
 Old 05-18-2019, 07:05 PM   #3
eliwwjd's Avatar
After gathering opinions i've decided to go with CS turbo being the one with the quickest spool time close to k04 and capable of 400+ hp over the other 3 turbo options.
Now i want to hear experiences from members who have installed the CS turbo C4 updated.
How has the turbo turn out in service and performance? Any bad experiences?
 Old 06-07-2019, 04:56 AM   #4
eliwwjd's Avatar
Can any member here with the CS turbo share how has been the experience with the upgrade?
 Old 06-07-2019, 06:23 AM   #5
shamie's Avatar
Posts: 952   (View Stats)
Nope. No member has written anything on this forum about the CS turbo. What is this CS Turbo you speak of?
Search and you will find...
Db09ms3 and danb like this.
 Old 06-07-2019, 11:29 AM   #6
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Burn...
I haven't had any "major" issues with my CS turbo. I supposedly got one from the updated 2nd batch, but before they changed the name to CST4.
Considering the stock fueling (with HPFP upgrade) will take you to 360whp, adding aux fueling to get 40 more HP seems silly expensive for what you get back.
And that's coming from someone who is spending silly amounts of money for smaller gains.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 06-11-2019, 09:40 PM   #7
180mph's Avatar
Posts: 29   (View Stats)
180mph will become famous soon enough180mph will become famous soon enough
I'm in a similar boat. I have a smoking k04 and have been lurking the forums for the past month trying to decide on my goals for the car. I have all of the "bolt ons" so the turbo is the next logical progression.
To me it seems like the options are really between the cs turbo and bnrs3. Don't quote me here but I think the CS turbo is more of a direct bolt on where as the others require other tweaks.
If you do get the cs turbo post back on what you plan to do for tuning. I'm very interested.
180mph is offline   Reply With Quote
 Old 06-11-2019, 10:06 PM   #8
Fstrnyou's Avatar
The CS turbo is direct-direct. Can still use stock intake pipe.
I'm fairly certain the S3 requires an upsized inlet pipe.
Other rides:
History:
 Old 06-12-2019, 12:12 AM   #9
180mph's Avatar
Agreed, iirc the cs uses a 2.5 inch intake and the bnrs3 uses a 3 inch. It's also a consideration that when installing the bnrs3, you relocate the ECU or do the battery box mod. The ECU harness will rub on the bigger intake (plus the turbo pushing it out slightly) and could cause wire faults down the line.
Edit: grammar
 Old 06-12-2019, 08:19 AM   #10
Posts: 2,237   (View Stats)
on a first gen3 You can run 3'' silicone TIH just by removing the ecu splash guard and keep same size battery and rack.
You can even squeeze it there without removing the guard but it will rub against the TB cooling hose and make it leak over time.
For 360 it may not come into play much but larger intake is never a bad thing.
Any restriction before turbo is reported after it, by 2-3 times the lost value. (It affect BAT too)
Did I make the wrong decision? anesthetize Mazdaspeed3/6 General Discussion 9 11-29-2015 03:17 PM
Need to make a tuning decision eliwwjd 2010 MS3 - ECU Computer Tuning 12 05-30-2014 02:00 AM
Need to make decision! need some advice eliwwjd 2010 MS3 - Turbo Induction 30 03-02-2014 07:37 PM
MS6 or MS3 Help me make my decision. Godofelru Mazdaspeed3/6 General Discussion 8 12-02-2008 02:10 PM
Page generated in 0.31019 seconds with 25 queries
