![]() Join Date: Apr 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
![]() Join Date: Aug 2009 Location: Kingwood, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,102
Groans: 50
| Not Ranked : 0 score The big difference between the two you listed and the more expensive options, is that DP's like the CP-E and Cobb can be had with high flow cats. So the big question is, are you Al Gore, or Bill Clinton? |
| The Following User Says Thank You to banditscout For This Useful Post: | FridayGt (05-11-2010) |
(Thread Starter) | Not Ranked : 0 score I'm definatly more of a Bush senior/Reagan type. Screw that environment crap and hybrids. PS I'm trying to lose the cat on the downpipe. |
| The Following User Says Thank You to julioroman For This Useful Post: | Raysfan (05-21-2010) |
![]() Join Date: Mar 2010 Location: DE
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 626
__________________ -- 2010 MazdaSpeed3 - Current Mod(s): Ventus V12's, CP-E RMM, CS SRI, CS TIP, JBR Stage 2 SSP, 35% Tint, COBB AP, COBB XLE BPV - Planned Mod(s): JBR Knob, JBR Rear Sway, PMM, CS HPFP (Please), CS Catback, CS TMIC, Driver Mod, Cawk Mod | |
| The Following 2 Users Say Thank You to FridayGt For This Useful Post: | banditscout (05-11-2010), JS + MS3 (05-13-2010) |
![]() Join Date: Feb 2010 Location: Daphne, Alabama
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 236
| Not Ranked : 0 score have you looked at Ultimate Racing? I'm running there catted DP, build quality is awesome. I think there catless can be had for around $300 |
| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
| Not Ranked : 0 score get all of them... cpe, ultimate racing, corksport... idk about genpu |
(Thread Starter) | Not Ranked : 0 score Philly B! I only have on Speed3! I think I will go for the Ultimate racing catless. And then later the racepipe and catback exhaust. |
Groans: 1,940
| Not Ranked : 0 score yeah, people like the ur stuff. idk anything about genpu. have fun. |
| Blue 2 shims ![]() Join Date: Feb 2009 Location: Roswell, GA
Rep Power: 1476 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 954
Groans: 66
| Not Ranked : 0 score How much is race pipe for gen2? Gen1 is cheap, I'd do em both at the same time.
__________________ I used to drive a MazdaSPED 3. It was retarded fast. |
![]() Join Date: Feb 2010 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 124
| Not Ranked : 0 score I think the UR one is 149$. I'd probably get both the DP/RP from them if that's the route you're going.
__________________ [SIGPIC][/SIGPIC] |
![]() Join Date: Sep 2009 Location: Los Angeles, California
Rep Power: 442 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,334
Groaned at 72 Times in 51 Posts
| Not Ranked : 0 score ^ ditttttto DP+RP you will fly..
__________________ 2010 Mazdaspeed3 Cobb AP - CP-E SRI - Ultimate Racing TP - CP-E RMM 75D - JBR RSB - JBR SSP - Autotech HPFP Internal - Denso ITV22 - Advan RZ 18x8 (Conti ExtremeContact DW 235/40/18) |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 895
| Not Ranked : 0 score cp-e released their gen2 yet? because that replaces both pieces...that is why it is so expensive...the 500 dollars is getting you a dp and a testpipe.... |
Groans: 1,940
| Not Ranked : 0 score after installing 4 downpipes... two cpe, one corksport, and one turboxs, for those worried about ease of install, the shorty's are much easier to install. |
| Not Ranked : 0 score philly, what's the hardest part of the install in general? My stock DP is being welded soon and I wanted to take it off myself. Before I spend a bunch of time and broken fingers figured you'd be able to give some tips.
Groans: 1,940
| Not Ranked : 0 score i just did a write up on the dp uninstall/install. how to: mazdaspeed3 downpipe tricky shit - the clips for the o2 sensors. removing the bracket that holds the dp to the block. and removing the heat shielding. |
__________________ [SIGPIC][/SIGPIC] | |
Groans: 1,940
| Not Ranked : 0 score word |
| Downpipes | dkspeed | MazdaSpeed 3 - Engine, Transmission & Driveline | 50 | 02-26-2010 06:25 PM |
| MS3 RR-Tuned Downpipes! | Race Roots | Mazdaspeed3/6 General Discussion | 29 | 01-21-2010 04:49 PM |
| downpipes | pvms3g | MazdaSpeed 3 - Engine, Transmission & Driveline | 12 | 05-21-2009 01:04 PM |
| CPE downpipes | phailerider | Custom Performance Engineering (cp-e.com) | 27 | 11-25-2008 10:58 AM |
