| | LinkBack | Thread Tools | Search this Thread | Display Modes |
![]() Join Date: Jul 2019 Location: Central NJ
Rep Power: 11 ![]() ![]() ![]() ![]() Thanks: 5
(Thread Starter) | Not Ranked : 0 score This is my first post so please take it easy on me! I've been reading for quite a while now, trying to educate myself on the various options that exist for our platform. I am now stuck on what turbo to choose. Part of me says to keep it as straight forward as possible so going BNR K04 reman or S1, but the other half says go S3/CST4. My mods consist of HPFP, CAI+ TIP, Axle-back + res delete, and a RMM. I intend to add a FMIC or TMIC in the future, but am hesitant about adding in a catted DP (or non-catted RP) because of emissions. I haven't even tuned my car yet and am happy as f*** with it which makes me think that a K04/S1 with my current mods and a AP+Freektune would suffice. My car is my DD and I genuinely enjoy the crap out of it! Since I don't intend to take it much further, do any of you think I could take advantage of the S3/CST4 with my mods? or would it be a waste? P.S. if i go with the S3/CST4 I would buy the 3port EBCS as recommended. Any insight is greatly appreciated! |
![]() Join Date: Oct 2019 Location: Sacramento, CA
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score I think that the stock K04 is very fun to have in the car. I have been able get 23psi on open boost with only a high pressure fuel pump, Cobb Air intake, and 3" exhaust putting out 280WHP. In my opinion you don't need to upgrade this bad boy til you blow it. I have not looked into the turbos you listed but i was going to get a Corksport CTS6 or a GTX, leaning more towards the CTS6, but i was looking to be in the 350WHP range and my turbo upgrade would not be til I blow my own. I personally still need a real tune as I only have the free ones along with my accessport. |
| The Following User Says Thank You to LBC_Shadow For This Useful Post: | cyclist20 (02-14-2020) |
| Not Ranked : 0 score For oil loss I went from the 14mm banjo bolt to a 22mm from Damound sport or something like that. It really really helped a lot. https://damondmotorsports.com/produc...kaAvQSEALw_wcB I BNR S3 is also a good Turbo i would get. |
Yes I have read S3 everywhere, yet some argue CST4, which is about the same price, is closer to the S4 top end but S3 spool. | |
![]() Join Date: Jun 2013 Location: Statesboro, GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score You are probably going to be leaving a good bit of power on the table without at least a catted downpipe if you go CST4 or S3. I just installed my CST4 (with a CS catted downpipe and HPFP, had a CS SRI already) and don't throw any CEL, if that is what you are worried about. Also, getting a freektune, and on the base map with low boost, the 2000-3500 RPM range felt kinda sluggish compared to before the CST4/HPFP/Downpipe install, AND I had done a long overdue intake valve cleaning during the install. If you are set on no downpipe/high flow cat, you might be happier just getting an S1 to just avoid the seal issue. |
![]() Join Date: Oct 2011 Location: San Leandro, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 460
Groans: 87
| Not Ranked : 0 score Don't bother with S1/rebuild. Can't go wrong with S3 or CST4. A conservative tune will put the K04 to shame. Yes, they are slower to spool up but the area gained below the curve and pulling hard to redline makes up for it.
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT |
![]() Join Date: Oct 2015 Location: Central Jerz
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17
| Not Ranked : 0 score +1
__________________ 2010 MS3 - Tuned By Nishan Autotech Fuel Pump Internals OBX R Custom Exhaust Cobb SF Intake & TIH w. Blitz Filter CP-e TMIC Corksport Dual VTA BPV JBR 88 Duro RMM |
Also, what seal issues are you referring to? Lastly, can you provide input on my inquiry below (replied to tegxsi)? Last edited by 55suarod; 01-14-2020 at 01:35 PM. | |
Last question, since I do intend to purchase the ETS or CPE TMIC, a new BPV, and knowing myself, I will eventually go for a catted DP, should I just get the AP & Freektune OTS+ until I finish with those last mods? Right now, $1900 for CST4, JBR EBCS, and AP+Freektune is maxing out my budget. | |
| Not Ranked : 0 score Seals - turbo seals. The S1 is basically a K04 with the possibility of seal failure removed. With the bigger turbo, you will need a base map from a tuner before firing up for the first time. They will take your full mod list and write you a map that is very conservative, until they can get some datalogs. So you will need to purchase the AP and tune along with the turbo. I believe as far as adding mods later, you can purchase a lower priced update vs. a full price tune. |
Also appreciate the clarification regarding the tune, ofcourse I will work with my tuner to get everything buttoned up accordingly. | |
Groans: 87
I believe Freektune OTS+ is only for stock turbo. You need a custom tune for aftermarket turbos. Tuners will send you a safe base map based on your mods to make the car drive able. I see your dilemma... You can just install the AP + turbo and drive around on wastegate spring pressure until get your other mods in. It won't be punchy like the K04 but it will pull nicely at higher revs. So... I also have to deal with emissions in the future. I have a early revision of the CS turbo that CREEPS. I believe CS has made improvements in their current turbos. For this reason, kept the stock DP + test pipe setup to control the creep and keep it looking stockish. I'm content with this exhaust setup.
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT | |
| Not Ranked : 0 score There is some stuff said here that may need attention: LBC_Shadow Stock k04 at 23 psi is a peak midrange rpm results. it won't hold it to redline Your car is making a huge amount of torque above oem but a lot less added hp. This amount of mid range torque is fun but it is also a nice way to be looking for a new engine in a near futur if there is nothing to control knock and BAT... A slightly larger turbo will hold pressure to redline and even if it is set below your 23, it will make a more powerfull setup with less stress on the internals. The k04 is already near it's flow limits with stock tune, this is why you get more gain on torque than hp... The risks of a bnr s3 or cst4 is the temptation to add too much boost on the stock engine. It need to be dialed down for longevity (raison for creep) and stuff will last. But some peoples like me, cannot resist to the temptation to raise boost...So if you cannot afford a new engine and lose your DD for a while, you need to remain careful. My stock bloc handled a gt2871 abuse for a very long time until i pushed it too far...And it is about the same range of size of the bnrs3-4 and cst4...
| The Following User Says Thank You to Jeff23spl For This Useful Post: | MSMS3 (02-13-2020) |
Groans: 87
| Not Ranked : 0 score hmm...LBC_Shadow AP reads 23psi?? The stock 2.5bar maxes out at 22. You really don't know the actual amount of boost beyond that. How do you not hit boost cut on OTS maps?
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT Last edited by tegxsi; 01-15-2020 at 03:08 PM. |
Rep Power: 3748 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,747
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
| If you rolled your car and blew it up, how are you still asking questions about it and complaining about the car's stuttering performance? Post datalogs.
| The Following User Says Thank You to Vansquish For This Useful Post: | MSMS3 (02-13-2020) |
Regardless, i just have to survive a few months before being able to drop more money into my car. Right now I'm limited to 2 Gs because I had some work done in my newly purchased home. | |
(Thread Starter) | Not Ranked : 0 score Just purchased the CST4 and JBR 3port EBCS. Last week I got my AP and BT freektune package. Let the fun begin! |
| Not Ranked : 0 score It should be like day and night difference.
![]() Join Date: Mar 2019 Location: Wellington, New Zealand
Rep Power: 0 ![]() Thanks: 1
So what is it like dude?! I'm deciding whether to go big turbo myself. I have the Stage 3 COBB package. FMIC Full Turboback exhaust HPFP SF Intake XLE BPV AP V3 Running basic OTS stage 3 map and I think its quick... considering either a tune or big turbo and not look back! | |
Turbo is going in tonight because I was waiting on a part. JBR took longer than expected to ship out my EBCS, it arrives tomorrow. I already have the bt tune from Freek so once the install is done I'm going to test it. I'll keep you posted. P.S. i think if you get a tune with your mods you would be pushing more then me. I only have the cs tip/ aem cai, hpfp, and 3port ebcs to go with my turbo and tune. I'm sure a proper freek ots would blow your mind until the K04 goes. | |
![]() | | #24 | ![]() |
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,507
| Not Ranked : 0 score Not interested in pics, but am interested in avoiding false info. There was no way you knew your midrange boost to be 23 psi and not higher on the stock sensor. I ran a mechanical boost gauge and always felt comfortable with boost levels. It will show boost beyond 22.5. I kept peak boost with my tune and mods at 18-19 psi with taper. If you didn’t have a boost gauge, the cut you were getting in another thread was saving your ass because you were far exceeding OEM boost/fuel cut. My guess is that the open line from ECBS to your turbo was preventing the ECBS from regulating boost. That was dangerous, like a manual boost controller with no limit. As others have said you can run 23 psi earlier in the power band, back around 4,000 rpm, but you had better taper it to 15-16 psi at redline or the little K04 turbo will turn into a flamethrower. But, high boost down low just bends rods and shreds tires. The torque goes up too high if you bring on that much boost in the 3,000 rpm range. Might look good on a Dyno chart, but not good for the car. Probably ought to think about whether giving out engine tuning advice is a good idea.
__________________ 2017 Audi Q5 3.0 T (supercharged) Stage 2+ EPL tune, JHM overdrive crank pulley, EPL supercharger pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 480 hp. Sunlight Silver '08 MS3 GT Mods: (Sold 1/25/2019 after 10+ years of ownership) BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. Last edited by MSMS3; 02-13-2020 at 04:25 PM. |
![]() | | #25 | ![]() |
I look forward to your report on the big turbo install and tuning.
__________________ 2017 Audi Q5 3.0 T (supercharged) Stage 2+ EPL tune, JHM overdrive crank pulley, EPL supercharger pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 480 hp. Sunlight Silver '08 MS3 GT Mods: (Sold 1/25/2019 after 10+ years of ownership) BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. Last edited by MSMS3; 02-13-2020 at 04:54 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #26 | ![]() |
No problem! Unfortunately I live a pretty busy life so I'm not doing the install myself. However, I'll definitely be posting feedback once my car is done this weekend! Regarding the s1, I opted out for the CST4 due to the similar pricing while having room for more in the future. I also thought my K04 was fun (as this is my first real fast car), but got convinced by the countless posts saying to just go big(ger) now. | |
![]() | | #27 | ![]() |
I was trying to figure out how much power I was making and COBB put up these numbers (see attached). 39.2% increase in HP and TQ for stage 3. So that would be stock HP 263 + 39.2%? Is that right? Cheers guys | |
![]() | | #28 | ![]() |
As for hp... 263 hp is at the crank, not wheels (whp). I cant input for what numbers you should be at, but a good tune would make a difference. Cobb ots maps arent good. | |
| The Following User Says Thank You to 55suarod For This Useful Post: | MSMS3 (02-14-2020) |
![]() | | #29 | ![]() |
| Not Ranked : 0 score Are there any threads I can look at to seek more info? Not having the best time searching on mobile lol. I'd probably do the one similar to the $1,200 turbo! |
![]() | | #30 | ![]() |
My JBR EBCS gets here today, so I should have my car by tomorrow. Super excited to see how the cst4 will run with minimal mods (tip/cai, hpfp, rmm) and a tune. | |
![]() | | #31 | ![]() |
Like the K04, it responds to all K04 compatible mods, including intake systems and catted or catless downpipe s (with hpfp upgrade and appropriate K04 stage 2 tunes. With compatible mods and tune, expect 300 whp and 300-320 ft. lbs. torque. The same as for a properly modified and tuned MS3 with a K04. That is about 350-360 hp at the crank. Or +80 to +90 hp. over bone stock. Virtual Dyno on my car. This was with the K04. S1 is identical, maybe 5whp more.
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score Man I still think I wouldve been happy with the S1, but couldnt stomach $900 for an exact replacement when an upgrade is just $200 more. In a year I'll be adding some more power mods to take advantage of the additional capabilities. |
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score Ok so i double checked to make sure i couldn't find this RP. Anyone recognize? |
![]() | | #34 | ![]() |
| Not Ranked : 0 score Appears to be a resonated race pipe, brand unknown to me.
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score I think its a catalytic converter, see inside pic. Yea, can't find the brand anywhere. Guess that turbo back is coming sooner than later haha |
| The Following User Says Thank You to 55suarod For This Useful Post: | MSMS3 (02-15-2020) |
![]() | | #36 | ![]() |
It is, but it is not OEM for a MS3. These were my OEM cats, as removed when I went catless. Secondary cat is on the right. Much larger than your photo.
| The Following User Says Thank You to MSMS3 For This Useful Post: | 55suarod (02-16-2020) |
![]() | | #37 | ![]() |
![]() | | #38 | ![]() |
(Thread Starter) | Not Ranked : 0 score Haven't been able to provide an update because the site was down. My CST4 is in and I'm already on my first revision from Justin. The only issue I'm getting is some spark blowout. Once and a while I will hit a "wall" when stepping on it at 2500 - 3500 and my car gets bogged down/stutters. From the numerous threads I've read I will be cleaning the EGR and adding the copper wire 'mod' to my coils. If that doesn't work, I think I will go to the FPR valve next. I have a fresh set of NGK stock heat gapped at .026" (per Justin) and I already stretched my coil springs. Besides the above, car is running pretty good. Very fun on the highway, I get to 100mph too fast to even notice haha. I'm assuming the earlier revisions must only target about 11lbs because I'm only hitting like 10 - 11lbs. Can't wait to see what happens as Justin ups the boost. Since it seems that MSF is going down I guess I'll see some of you on MSO. Hope to have my car rippin very soon. |
![]() | | #39 | ![]() |
| Not Ranked : 0 score are you sure it is spark blow out at just 11psi with a good gap ? have you tried old plugs in case 1 is bad ? You may try copper but i would also check connection, grounding and wiring as usually oem spark can handle way more boost without issues with close gap...
| The Following User Says Thank You to Jeff23spl For This Useful Post: | MSMS3 (Yesterday) |
![]() | | #40 | ![]() |
![]() Join Date: Jun 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 242
| Not Ranked : 0 score Give the MAF a clean as well.
__________________ Gen 2 2012 - Precision 6062 Turbo - CPE Exhaust Mani - PTE 46mm EWG - 2NV Industries built Forged bottom end - PNP Head - JMF V2 Intake Mani- Custom DP UR Cat Back - HTP 4 inch intake - TR8 FMIC - Custom FREEKTUNE METH Port Injection - Cobb 3 port EBC- Autotech internals - FREEKTUNED. |
| Need help deciding to replace turbo or not | mazdamx3freak | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 8 | 03-24-2016 06:24 PM |
| Help deciding on ms3/ si, etc | jaco1234 | Mazdaspeed3/6 General Discussion | 42 | 03-02-2009 02:49 PM |
| Help deciding on ms3/ si, etc | jaco1234 | MazdaSpeed 3 - Engine, Transmission & Driveline | 39 | 02-23-2009 01:58 PM |
