> 2010 MS3 - Turbo Induction
Like Tree9Likes
 Old 12-12-2015, 09:06 AM   #1
Fonsi's Avatar
Posts: 236   (View Stats)
Fonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond repute
Default Oil return line is leaking
Hi guys,
my BNR S1 is leaking oil at the oil return line underneath the turbo. Two months after installing the S1, it looked like this:
I cleaned everything up and installed a new upper gasket at the oil return line (when installign the BNR S1, I re-used the old gasket). It seems that there is now less oil leaking but it still leaks somewhere underneath.
Any help or hints appreciated. According to my Mazda dealer you dont have to use any kind of sealant for the screws.
2012 Mazdaspeed 3
CS SRI, BNR S1, CS TMIC w/ Boost Tubes, GrimmSpeed EBCS, CS RMM, Stratified tuned, Cobb DP, 3" Catback, H&R coilovers, Tanabe strut & other parts
Fonsi is offline   Reply With Quote
 Old 12-12-2015, 09:18 AM   #2
wyeto's Avatar
Posts: 465   (View Stats)
wyeto is the leader of the worldwyeto is the leader of the worldwyeto is the leader of the worldwyeto is the leader of the worldwyeto is the leader of the worldwyeto is the leader of the worldwyeto is the leader of the worldwyeto is the leader of the worldwyeto is the leader of the worldwyeto is the leader of the worldwyeto is the leader of the world
I hate oil leaks man. Its so hard to get rid of them, it seems like your always checking under the car for oil.
The dealer was right you don't use sealant on the screws it gets too hot for any sealant.
If it is still leaking but just less I would go out to your car when it is cold in the morning and feel the oil feed line on top of the turbo. See if there's any oil on your hand. If not start the car and feel the line again. You may have a slight leak from where the banjo bolt crush washers are on the feed line and it could be dripping down to the return line.
wyeto is offline   Reply With Quote
The Following 2 Users Say Thank You to wyeto For This Useful Post:
btstarcher (12-13-2015), Fonsi (12-12-2015)
 Old 12-12-2015, 09:25 AM   #3
Fonsi's Avatar
Good idea dude. I'll install new banjo bolt crush washers and see if it helps.
2012 Mazdaspeed 3
 Old 12-12-2015, 09:35 AM   #4
wyeto's Avatar
Those crush washers really can be a pain in the ass. Its really tempting to re-use them but they just don't seal up the same.
Before you reinstall I would do that test to confirm that's where its leaking. Put your hand straight on that banjo bolt where those washers are and go all the way around then see if there's oil on your fingers.
 Old 12-12-2015, 09:40 AM   #5
Fonsi's Avatar
I'll to that test first, thanks!
2012 Mazdaspeed 3
 Old 12-12-2015, 10:23 AM   #6
If it is not the feed line as stated above, take the oil drain line off and see if there are any cracks in it. In it was the flex section, but you have a leak coming from way above so I hope this is the feed line. Is the oil leaking at idle or only after you put some load on the engine?
Fonsi (12-13-2015), qtrmile beast (12-13-2016)
 Old 12-12-2015, 10:41 AM   #7
wyeto's Avatar
This is a hard test to get results from unless its leaking really bad haha.
I was going to add make sure to check the feed and return for cracks because if they are cracked it can get REALLY ugly fast.
I had my feed line break on my vw tdi daily commuter and I was lucky enough to be pulling into a parking spot at the time. It takes 4.5 qts when you do an oil change and after I installed the new line I had to fill up just over 4 qts... talk about a lucky close call. The line had been leaking pretty good for a while and I just got lucky I wasn't on the freeway or driving around when it broke.
Code Monkey (12-12-2015), Fonsi (12-13-2015)
 Old 12-13-2015, 04:26 AM   #8
Fonsi's Avatar
Alright, I'll check the feed and return line for cracks and will replace the crush washers on the feed line the upcoming week.
I cannot exactly say if its in idle or under pressure. What I can say is that it seems to be a very slow leak, as there are now 4 weeks gone since I replaced the gasked and cleaned everything up and there was just little oil at the return line yesterday.
2012 Mazdaspeed 3
 Old 12-13-2015, 05:46 AM   #9
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
I'm in the same boat with my S3. Included gasket was junk. Put a spare OE on, but I think it's still leaking a little bit. Wish I had just installed new crush washers and OEM gaskets on the feed and drain lines when I put the turbo in. What a pain in the ass.
2007 Mazdaspeed3 GT
 Old 12-15-2015, 06:21 AM   #10
Fonsi's Avatar
I've checked the inlet pipe and the compressor housing yesterday. Apart from two or three little drops of oil it is bone try in there.
I'm checking the oil feed line the day after tomorrow. I've already purchased new crush washers to replace the old ones. I hope this helps .
2012 Mazdaspeed 3
 Old 12-17-2015, 11:23 AM   #11
Fonsi's Avatar
Checked the oil feed line today and found these two crush washers around the banjo bolt:
100 points for the one who can see the difference
2012 Mazdaspeed 3
 Old 12-17-2015, 12:52 PM   #12
No difference, both would fit on my dick.
monkey.bones.007 and Fonsi like this.
Micha (12-22-2015)
 Old 12-17-2015, 11:47 PM   #13
Fonsi's Avatar
This answer is worth 100 points too
2012 Mazdaspeed 3
The Following User Says Thank You to Fonsi For This Useful Post:
Code Monkey (12-18-2015)
 Old 12-17-2015, 11:55 PM   #14
wyeto's Avatar
Weird. I think you found your leak.
 Old 12-18-2015, 12:00 AM   #15
Fonsi's Avatar
I hope so. These crush washers came with my BNR S1.
I dont know if the larger one was meant to fit the coolant line and I was just too dumb to compare them or anything else... I replaced them with two new OEM ones for fck*n 4 dollars to make sure they'll fit now.
memin likes this.
2012 Mazdaspeed 3
 Old 12-18-2015, 01:12 PM   #16
cyclist20's Avatar
Posts: 636   (View Stats)
cyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the world
Yes, from what I recall the coolant washers were bigger. I suspect you will be good to go.
blackms3_71 likes this.
2013 LSM Speed BNR S3v3
AP V3
Corksport: HPFP Internals, Injector Seals, bpv, battery box, intake manifold
Full Race: Exhaust Manifold, ceramic coated for lovliness
CNT:Catted DP
Treadstone TR8 with Cobb piping
CP-e: Stage II RMM
HTP:3" intake
Stratified: 3port, Guardian Angel
JBR RSB, Shifter Bushings, EGR Delete/Blockoff
Matt Damond:OCC, PMM, TMM
UR Axleback
Rice: Corksprt CF Hoodscoop & Spoiler // 12mm spacers // Bayson R lip // Bayson R GV grill // Okiefam powercoated VC, coil, and HPFP covers
Tuned by PURPLE DRANK
cyclist20 is offline   Reply With Quote
 Old 12-22-2015, 08:37 AM   #17
Fonsi's Avatar
Unfortunately, changing the oil feed line crush washers did not help.
I still think it might be the return line / gasket but I already replaced the oil return line gasket. There is even oil around the screws .
Pictures from today:
I cleaned everything up and wrapped two gaskets around the upper return line and torqued it down.
Any ideas?
2012 Mazdaspeed 3
 Old 12-22-2015, 08:56 AM   #18
wyeto's Avatar
Damn man that sucks! I'd say clean everything and when you attach the upper gasket go in really evenly with the bolts. Once they are snug tq down in increments.
If I remember correctly they are 13ft/lbs is that right?
I don't think 2 gaskets on the upper oil return line is gonna help. Usually doubling up on gaskets hurts things not helps.
The Following User Says Thank You to wyeto For This Useful Post:
Code Monkey (12-22-2015)
 Old 12-22-2015, 09:09 AM   #19
^ What he said, just use one gasket, maybe smear a dab of RTV on it.
 Old 12-22-2015, 09:11 AM   #20
Fonsi's Avatar
The workshop manual says 8-10nm which is around 5.9-7.4 ft lbs.
Cleaning and attaching the gasket is what I did first.
Then I replaced the upper gasket with a new OEM one.
Its still leaking ... thats why I tried the two gaskets now
RTV between the gasket and the turbo? Or between the gasket and the return line?
2012 Mazdaspeed 3
Last edited by Fonsi; 12-22-2015 at 09:11 AM. Reason: MSF Database - Automerged Doublepost
 Old 12-22-2015, 09:14 AM   #21
wyeto's Avatar
Ok well no harm in trying, but if you've ever done an oil change and one o-ring gasket gets stuck and you put another filter on you would know 2 gaskets won't be better than one.
I wouldn't suggest rtv because the turbos get so hot I think it would probably burn/smolder and you'd regret it...
Maybe copper spray? Idk man
I guess if you can't get the leak to stop check for cracks where it could be coming from.
I was way off with those tq specs
Fonsi (12-22-2015)
 Old 12-22-2015, 09:16 AM   #22
Yeah, copper spray should work, spray both sides of the gasket.
Fonsi (12-22-2015)
 Old 12-22-2015, 09:17 AM   #23
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Man, careful crusing that thing around. That oil is pretty volatile, is right above the exhaust and will catch on fire. Ask me how I know.
MINI H1 6.0 - CAR LED TAILS
cyclist20 (12-22-2015), Fonsi (12-22-2015), Vansquish (01-09-2016)
 Old 12-22-2015, 09:17 AM   #24
Fonsi's Avatar
I'll try some copper paste. Thank you guys!
2012 Mazdaspeed 3
 Old 12-22-2015, 11:55 AM   #25
cyclist20's Avatar
I'm wondering if it is the weld at the flange. the oil does not appear to be much on the turbo and mostly only on the return line/flange. Perhaps that is cracked? Is it possible they tapped the threads to deep? If that is the case the no gaskets would make a difference.
AP V3
CNT:Catted DP
CP-e: Stage II RMM
HTP:3" intake
UR Axleback
The Following 2 Users Say Thank You to cyclist20 For This Useful Post:
Code Monkey (12-22-2015), Fonsi (12-22-2015)
 Old 12-22-2015, 12:10 PM   #26
Fonsi's Avatar
I took a closer look at the oil return line and could not find any cracks. But that is the next part to be replaced after I tried the copper spray.
I'll check the threads of the screws too. But its hard to have a look underneath the car without taking the whole turbo out :-(.
I'm wondering about the oil at the screws... I still think the gasket is not 100% ok. I dont know :-/.
2012 Mazdaspeed 3
blackms3_71 (12-30-2016)
 Old 12-22-2015, 12:12 PM   #27
Pressurize the line like I did in the video above; although seeing where the leak is coming from I doubt it is the line.
 Old 12-22-2015, 12:15 PM   #28
Fonsi's Avatar
Yeah, I will test that after trying the copper spray.
At least I hope its some kind of gasket / return line leak. If its the turbo, I'm having a huge problem
2012 Mazdaspeed 3
 Old 12-22-2015, 03:53 PM   #29
Make sure the surfaces are SPOTLESS, or the oil won't let things setup properly.
Code Monkey (12-29-2015), Fonsi (12-23-2015)
 Old 12-29-2015, 12:54 PM   #30
Fonsi's Avatar
Good news ... well, at least until today. The oil return line is bone dry. It seems the two gaskets are working . It hope it stays dry...
2012 Mazdaspeed 3
The Following 4 Users Say Thank You to Fonsi For This Useful Post:
cyclist20 (12-29-2015), dale_gribble (12-29-2015), MD1032 (12-29-2015), mxlplx71 (12-31-2015)
 Old 12-31-2015, 10:42 AM   #31
wyeto's Avatar
Right on! Any update of the last few days?
 Old 12-31-2015, 11:04 AM   #32
Fonsi's Avatar
Not yet dude. I'm off during christmas and new year's eve, so I don't drive that much. But I'll keep you guys up to date .
2012 Mazdaspeed 3
 Old 12-31-2015, 11:08 AM   #33
wyeto's Avatar
Sounds good man. I'm really interested to hear how the double gasket works.
Fonsi (12-31-2015)
 Old 12-31-2015, 11:46 AM   #34
aviator79's Avatar
Posts: 3,934   (View Stats)
Maybe the holes were not drilled or tapped deep enough and the bolts were bottoming out and the thicker two gaskets made up for that? Need to test remove drain and see if bolt goes all the way in past thickness of drain flange. If just not drilled deem enough can just grind end of bolt down or if not tapped far enough need shorter bolt. But looks good now anyways...just seems weird.
cyclist20 (12-31-2015)
 Old 12-31-2015, 12:08 PM   #35
blackms3_71's Avatar
Posts: 2,250   (View Stats)
Yeah 2 gaskets in place of one usually never works but with the cooper spray he seemed to get lucky
 Old 01-09-2016, 08:52 AM   #36
Fonsi's Avatar
Its still bone try underneath the turbo. Last weekend I was for about 200km on the german autobahn. I guess my double gasket patent works
2012 Mazdaspeed 3
robbspeed (01-09-2016)
 Old 01-09-2016, 09:24 AM   #37
wyeto's Avatar
I think that copper spray did the trick but either way your sailing now!
blackms3_71 (01-09-2016)
 Old 01-09-2016, 09:31 AM   #38
Fonsi's Avatar
There is no copper spray on the gaskets . That would have been my next step if the double gaskets are not working...
2012 Mazdaspeed 3
 Old 01-09-2016, 09:38 AM   #39
wyeto's Avatar
That is seriously weird my friend haha. Well right on man good stuff.
 Old 01-09-2016, 10:36 AM   #40
MD1032's Avatar
Groans: 143
Probably just shitty tolerances on the BNR or oil drain line itself (or both). Mine's leaking right now and I bought new gaskets from Mazda. Hopefully that will fix the problem. If not, maybe I'll order some more and double them up like you suggested.
2007 Mazdaspeed3 GT
HPFP Fuel Line Leaking Jtaylor MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 18 10-03-2016 06:52 PM
leaking break fluid from clutch line need help Roofis119 MazdaSpeed 3 - Engine, Transmission & Driveline 5 03-20-2014 11:37 PM
Oil Feed line leaking 7mileshome MazdaSpeed 3/6 - Turbo Induction 3 05-30-2012 01:40 PM
Leaking clutch line bova MazdaSpeed 6 - Engine, Transmission & Driveline 3 12-23-2011 10:09 PM
KO4 TURBO ON MS6 LEAKING OIL RETURN LINE GAMISTAD Mazdaspeed3/6 General Discussion 9 01-27-2011 01:06 AM
Page generated in 0.58830 seconds with 27 queries
