![]() Join Date: Feb 2013 Location: San Antonio, TX
Rep Power: 0 ![]() ![]() Thanks: 2
| Not Ranked : 0 score It does sound like your solenoid needs a replacement. What it does is bleed pressure from the line going to the WG. The higher the duty cycle the more it bleeds the lower the pressure at the WG the higher your actual boost. If you can't find a replacement locally, we have a solution for you that is plug and play and you don't have to worry about breaking it as easily. http://www.stratifiedauto.com/index....roducts_id=222
| The Following User Says Thank You to Lex For This Useful Post: | bertrand_CX_7 (03-22-2013) |
(Thread Starter) | Not Ranked : 0 score How difficult is it to tune with the ATR software? I'm still learning the basics of all this. |
| Not Ranked : 0 score The EBCV can be put in 2 port mode and no tuning is needed - it will act like OEM.
(Thread Starter) | Not Ranked : 0 score So in 2 port mode I should be hitting my boost targets? If I hadn't broken the stock solenoid the tune I have was set for 17psi. |
| Not Ranked : 0 score Can't speak for your tune but the solenoid will get the job done.
| Not Ranked : 0 score If the end of that hose going into the tip is crushed or blocked in any way, it will prevent the ebcs from actually bleeding pressure away from the wastegate. You will only get spring pressure like you are seeing. I would start with the simplest thing, which is your broken part, since it likely needs replaced anyway. Edit: did you break the nipple on the tip or the ebcs?
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. |
| The Following User Says Thank You to phate For This Useful Post: | rfinkle2 (03-19-2013) |
(Thread Starter) | Not Ranked : 0 score Not the tip, I broke the nipple on the ecbs. I wasn't foolish enough to break the one on the tip. I'm uploading a picture of the rig I set up now. |
| The Following User Says Thank You to RxHeadkicks For This Useful Post: | phate (03-19-2013) |
(Thread Starter) | Not Ranked : 0 score I broke the outer nipple off. It looked like l_ instead of the two vertical nipples looking like l_l, so I shoved the hose on the end hoping it would work. So the one I broke was bleeding air INTO or FROM the wg? |
| Not Ranked : 0 score It bleeds pressure from the wastegate diaphragm. You need a new solenoid lol.
| Neutral : +1 score Yes they can all run in 2 and 3 port. The one we sell comes with an elegant thread on plug for the unused port while the GS solenoid and COBB solenoid (they are the same) you will have to install a cap. Also the barb size on those solenoids is a little on the small size for the stock lines.
| The Following User Says Thank You to Lex For This Useful Post: | RxHeadkicks (03-19-2013) |
(Thread Starter) | Not Ranked : 0 score I think you just sold me Lex. I'm gonna tell my buddies about ST. I hadn't heard of you guys before today. How about some free express shipping so I can get back out there sooner? heh, heh?
__________________ Keep Calm and PSSHHHHHHHH CHOOOOOOO! |
(Thread Starter) | Not Ranked : 0 score Just ordered the Stratified ECBS! I really hope this solves the problem, will let you guys know when I install it.
| The Following User Says Thank You to RxHeadkicks For This Useful Post: | Lex (03-19-2013) |
![]() Join Date: Jun 2012 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 155
| Not Ranked : 0 score It'll do the trick in 2-port mode nicely and give you options for the future. I busted the FWD nipple off mine and was able to bandaid it back together with JB Weld until my GS arrived. Unfortunately, Lex's option wasn't available when I broke mine, it looks nicer and I like the plastic ports rather than the metal ones on the GS. BTW...Lex your install diagrams are the best yet!!! Very nice offering.
__________________ '10 VRM MS3 3" JBR WP, ETS TMIC, KMD/Aviva HPFP, NGK LTR7IX, M2 TP, Grimmspeed, JBR & MD EGR delete, MD OCC, MD PMM, CPe Stg2 RMM, CS TMM insert Mazda Motorsports C/O, JBR RSB, SPC camber arms, Konig Hypergram 17x9 +40 & 200 UTQG rubber or Drag DR-49 18x8 +45, Michelin Pilot Sport A/S 3 Strive for perfection in everything. Take the best that exists and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough. Sir Henry Royce |
![]() Join Date: Aug 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 112
Groans: 53
Groaned at 56 Times in 18 Posts
| Not Ranked : 0 score I did the same thing when I removed the stock TIP. I thought I had everything disconnected and ripped the nipple right off the selonoid. Luckily COBB suregline is close to me and I took the wifes car to get there 3 port.
__________________ 2012 MS3 VR COBB AP /// Autotech Internals /// CP-E Nano SRI /// CP-E TIP /// JBR Dogbone RMM /// JBR OCC Stage 2 /// RichTune |
![]() Join Date: Oct 2018
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score I did the same thing just broke it last night and I pushed the line over the same part on the ebcs and I need a new one but will the gen1 work on the gen 2? |
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,505
You will need to set it up in two port mode if aftermarket. I got the Grimmspeed one. Instructions are very clear. Just leave the old one in place and mount the GS on the front of your battery box. it will come with new vacuum lines and a cap for the unused port. FWIW, its good you searched first before posting. Kudos.
| Not Ranked : 0 score Could that be the reason I’m only pushing 9psi? Also my bov doesn’t sound the same used to sound hard |
| Not Ranked : 0 score Sound hard??? One thing at a time. Replace the EBCS with one with metal nipples. Then check boost. Then do a boost leak test.
| Boost Solenoid | mildsalsa | MSP - Turbo Induction | 0 | 05-20-2012 06:52 PM |
| Where is the Boost solenoid ??? | camdensms6 | MazdaSpeed 3/6 - Turbo Induction | 2 | 12-13-2009 09:25 AM |
