> 2010 MS3 - Turbo Induction
Like Tree10Likes
 Old 06-23-2015, 06:39 AM   #1
Voltwings's Avatar
Posts: 3,713   (View Stats)
Default TMIC ducting / engine bay pressure
So i'm not sure exactly where this goes, but i feel here may be as good a spot as any.
I recently picked up a magnehelic gauge for measuring pressure zones when i start ducting my track miata.
Series 2000 | Magnehelic® Differential Pressure Gage | Dwyer Instruments
What this basically does is allows you to measure the pressure differential between either two points, or a point and atmosphere. Since i am still a few months away from really getting serious with the miata, i decided to play around with the (gen2) stock TMIC ducting.
I know for a long time its been stated that you need a shroud because it helps with cooling, and if you don't have it you will bleed tons of pressure into the engine bay and all that, so i figured why not put that theory to the test.
I will admit that my results are not as strictly scientific as possible, but i feel they are close enough to not matter. Basically i got a Gen2 with the stock TMIC and shroud and rigged up the gauge a few inches inside the hood scoop to get a pressure reading on top of the core.
Units of measure are Inches of water: Definition: https://en.wikipedia.org/wiki/Inch_of_water roughly 27.5" of water = 1 psi. Thanks @Tomas; for setting me straight on the units there.
Part 1: TMIC testing with shroud, measured on top of core in the scoop.
40 mph - .5" of water
50 mph - .75" of water
70 mph - 1.25" of water
80 mph - 1.5" of water
There were slight swells as the driver accelerated, but i was trying to just measure steady state since i felt that was a more controlled environment, i'll try seeing if we actually get some "ram air pressure" when WOT at a later time.
The next step was taking my ETS equipped car with no shroud (like i said, not apples to apples) and doing the same test on the same stretch of road.
Part 2: TMIC testing without shroud, measured on top of core in the scoop
50 mph - .5" of water
60 mph - .75" of water
80 mph - 1.5" again
It would appear that the shroud does provide some purpose at lower speeds, but at higher speeds the affect seems to become less apparent. This leads me to believe one of two things is happening: Either the pressure does a shockingly good job of staying on the core, or the engine bay itself is becoming pressurized, which i somewhat doubt.
The next step in this test will be measuring engine bay pressures on either side of the radiator with FMIC and TMIC cars. A radiator wants the highest pressure in front of, and lowest pressure behind of, it as possible. With a FMIC you're basically lowering the pressure in front, and since the TMIC ducting is open to the engine bay, raising the pressure behind the radiator. I'd like to see what that data says.
Part 2: TMIC car / under tray installed / weather stripping in the cowl installed
Pre radiator:
55 mph - .35" of water
60 mph - 1.15" of water
70+ mph ~1.5" of water
Post radiator:
50 mph - .1" of water
55 mph - .2" of water
60 mph - .3" of water
80 mph - ~.5" of water
Cowl with weather stripping installed:
50 mph - .7" of water
60 mph - 1.2" of water
80 mph - 1.6" of water
Part 3: TMIC car / Under tray removed / Weather stripping on cowl installed
30 mph - .1" of water
40 mph - .2" of water
50 mph - .3" of water
60 mph - .4" of water
60 mph was as fast as i was able to get, but clearly the under tray serves an important purpose.
If anyone can think of ways to make these tests more accurate, or tests they would like done as well, please let me know. I figured there may be a better way to go about this, which is why i went ahead and created the thread before i had all my data.
Yanahdi likes this.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
The Following 10 Users Say Thank You to Voltwings For This Useful Post:
Code Monkey (06-23-2015), Easter Bunny (06-23-2015), FistPump20fo7 (06-23-2015), Gr8Speed (06-30-2015), JgamB (06-30-2015), JSmith (11-21-2016), phate (07-03-2015), torquemaniac (06-23-2015), Yanahdi (07-04-2015), zenit (09-02-2015)
 Old 06-23-2015, 07:01 AM   #2
Spec's Avatar
Posts: 4,472   (View Stats)
Test with and without the under trey on the same car when you do the radiator test.
The Following 5 Users Say Thank You to Spec For This Useful Post:
Code Monkey (06-23-2015), Easter Bunny (06-23-2015), torquemaniac (06-23-2015), Voltwings (06-23-2015), WetzMS3 (06-23-2015)
 Old 06-23-2015, 07:03 AM   #3
Voltwings's Avatar
Yes, that would be a really good one, thanks Ray.
Spec likes this.
Past:
-Sold-
-Sold-
Current:
 Old 06-23-2015, 07:09 AM   #4
You can also test with and without the rubber gasket along the rear of the hood.
Spec likes this.
torquemaniac (06-23-2015), WetzMS3 (06-23-2015)
 Old 06-23-2015, 07:14 AM   #5
Police - Grammarhead
Vansquish's Avatar
I'd be very curious to see what the results were with a hood-scoop extension like Corksport's too.
Spec likes this.
Easter Bunny (06-23-2015), speedfreak44 (06-23-2015)
 Old 06-23-2015, 07:15 AM   #6
Voltwings's Avatar
Yes, i know a lot of people remove that, i did my first time around. I'll probably just measure the pressure (positive or negative) in the cowl with it attached, and compare it to engine bay pressure from the above tests. May make things easier?
Basically if i measure say .5" in the engine bay and .6" in the cowl, i can assume the cowl will be putting air into the engine bay instead of removing it, correct? Whereas if i measure .5" in the engine bay, and ... really anything less than that, especially negative pressure, we can assume it will pull pressure from the engine bay?
Spec likes this.
Past:
-Sold-
-Sold-
Current:
 Old 06-23-2015, 07:31 AM   #7
Yes. Though if the numbers are very close the removal of the strip may cha he the airflow pattern in that area.
Spec likes this.
 Old 06-23-2015, 07:50 AM   #8
Spec's Avatar
Yea, whatever dog.
 Old 06-23-2015, 08:12 AM   #9
torquemaniac's Avatar
Posts: 733   (View Stats)
Testing the pressure over a gen1 TMIC could be nice also...front of the car usualy has higher pressure reading, so the gen1 could see more pressure over the TMIC since its feed from the front of the car (upper grill area)
2011 CX-7 AWD 2.3 turbo
The Following User Says Thank You to torquemaniac For This Useful Post:
 Old 06-29-2015, 08:11 PM   #10
Voltwings's Avatar
I now realize this is going to be a very large amount of data, so I cleaned up the OP to hopefully make it easier to read, and added the following data from tonight:
Pre radiator:
Post radiator:
Past:
-Sold-
-Sold-
Current:
The Following 3 Users Say Thank You to Voltwings For This Useful Post:
Easter Bunny (06-29-2015), phate (07-03-2015), torquemaniac (06-30-2015)
 Old 06-30-2015, 03:43 AM   #11
Did you mean ''cowl with weather stripping unistalled''?
 Old 06-30-2015, 06:22 AM   #12
Voltwings's Avatar
Nope, installed, as it comes from the factory. So if im looking at this right, the cowl at the base of the windshield is basically a high pressure zone, and compared to the post-radiator readings, removing that weather stripping would be pumping air into the engine bay.
Past:
-Sold-
-Sold-
Current:
The Following 4 Users Say Thank You to Voltwings For This Useful Post:
Easter Bunny (06-30-2015), JgamB (06-30-2015), SuckSqueezBangBlow (06-30-2015), torquemaniac (06-30-2015)
 Old 06-30-2015, 11:08 AM   #13
SuckSqueezBangBlow's Avatar
Posts: 266   (View Stats)
I have taken that weather striping on and off so many times, I wonder if I should take it off again.... I am having a hard time interpreting the date (and nice job on the testing!)
I guess I will wait and see if it is beneficial or not.
 Old 06-30-2015, 12:18 PM   #14
Voltwings's Avatar
In my mind, the number on the cowl is higher than the number in the engine bay. Pressure moves from high to low, which leads me to believe it would flow into the engine bay.
Past:
-Sold-
-Sold-
Current:
 Old 06-30-2015, 12:27 PM   #15
DaUberSchwebel's Avatar
Posts: 233   (View Stats)
DaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the world
I'd really like to see some results with the under tray removed as well. I noticed my BAT's really dropped after I removed mine. However, I removed my EGR and TB coolant lines at the same time. I'm sure that was the main reason they dropped, but would like to know if there is any benefit to not having an under tray.
2013 VRM with Cobb AP V3/ CS SRI/TIP/SS/TP/ CP-E RMM CP-E TMIC Autotechs JBR TIG/IMG/EGR delete Stratified OTS tune
DaUberSchwebel is offline   Reply With Quote
 Old 06-30-2015, 01:34 PM   #16
Voltwings's Avatar
Im getting there lol one thing at a time. The car needs an oil change this friday, and since im off work i may just see about doing it then. I'll still need to find a FMIC car with the time to replicate all these tests as well on.
Past:
-Sold-
-Sold-
Current:
 Old 06-30-2015, 01:46 PM   #17
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
even if that is the case, the air at the base of the windshield is cooler than in the bay. so the net effect of removing the strip is positive. or am I missing something?
the positive effect may be minimal (i.e. unmeasurable) lol
 Old 06-30-2015, 01:52 PM   #18
Voltwings's Avatar
While that is true, i guess my underlying thought is that it would raise the pressure on the backside on the radiator and reduce its efficiency. So, that makes a few assumptions:
1. We're swapping water cooling effectiveness for air cooling effectiveness in that case.
2. We're assuming its already at a point where the stock radiator cant keep up and we will see a negative impact in cooling by raising the pressure on the backside of the radiator.
3. while there is a rather large amount of pressure on the base of the windshield, i suppose without more testing its hard to quantify how much actually makes its way into the engine bay.
Im just trying to collect the data, someone smarter than me can decide what to do with it
Past:
-Sold-
-Sold-
Current:
Easter Bunny (07-01-2015), torquemaniac (12-13-2016)
 Old 06-30-2015, 02:26 PM   #19
Trail of Fail
Dano's Avatar
Yes, too many variables and you'd need to define what your goal is.
1) reducing engine bay temps
2) reducing ECT
the two may be necessarily mutually exclusive in some scenarios like the strip removal.
I think something like the scoop deletes the scoobie guys install is great for letting heat out AND should (just a guess) decrease the pressure in the engine bay so also would aid in lowering ECT.
Who's up for cutting a giant hole in the back of their hood?
torquemaniac (12-13-2016), Voltwings (06-30-2015)
 Old 06-30-2015, 02:31 PM   #20
Voltwings's Avatar
@Code Monkey; Dont talk about it, be about it.
Past:
-Sold-
-Sold-
Current:
 Old 06-30-2015, 02:55 PM   #21
A giant hole? My peen would get all banged up against the walls.
 Old 06-30-2015, 03:03 PM   #22
Tyhackman15's Avatar
Posts: 1,742   (View Stats)
You want the vents to be in LOW pressure zones, not high pressure zones. Ramming air (even if it's ambient temp) into the back of your engine bay is a bad thing. Reduces the air moving through the radiator by increasing the pressure behind the radiator.
A vent on the low pressure portion of the hood will reduce underhood pressure, allowing hot air to be pulled out, and allowing more air to pass through the radiator.
Example: http://i.ytimg.com/vi/wjjOgX_C5g0/maxresdefault.jpg
The air should be flowing out of the vents (as seen), not into them
The Following 6 Users Say Thank You to Tyhackman15 For This Useful Post:
Code Monkey (06-30-2015), Dano (06-30-2015), Easter Bunny (07-01-2015), phate (06-30-2015), torquemaniac (07-01-2015), WetzMS3 (07-02-2015)
 Old 06-30-2015, 03:39 PM   #23
sheston's Avatar
Posts: 1,847   (View Stats)
I took the cowling (the plastic that has the windshield wiper squirters in it) out of my car and when I sit in traffic I can see the heat waves coming out in front of my windshield. Doesn't seem to hurt the normal operation of my IAT or BATs
 Old 06-30-2015, 03:42 PM   #24
When you aren't moving, of course heat will naturally rise. The larger concern is when you are WOT for extended periods of time, taxing your cooling system (for most people).
Of course all this is application specific talk.
The Following User Says Thank You to Tyhackman15 For This Useful Post:
 Old 07-01-2015, 10:30 AM   #25
I think that removing the weatherstripping on the back of the hood would only be beneficial for drag racing
Code Monkey (07-01-2015), JgamB (07-01-2015)
 Old 07-01-2015, 12:11 PM   #26
JgamB's Avatar
Posts: 2,566   (View Stats)
That is all I needed to hear. I knew I clicked the "subscribe to thread" for a reason.
 Old 07-01-2015, 05:47 PM   #27
IMO, removing the weather strip will only improve heat removal when sitting in traffic
Im 100% with @Tyhackman15;
The Following 2 Users Say Thank You to torquemaniac For This Useful Post:
Easter Bunny (07-02-2015), Voltwings (07-02-2015)
 Old 07-02-2015, 09:43 AM   #28
MSP611's Avatar
Posts: 2,291   (View Stats)
hmm well it looks like ducting in the rad on the sides and on top is the way to go... then duct ur intercooler in.
In progress:
 Old 07-02-2015, 10:03 AM   #29
kidlifecrisis's Avatar
Posts: 672   (View Stats)
kidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the world
I'm going to try and experiment with a duct between my fmic and the radiator as that should be fairly simple to mock up and fit with the bumper off. I haven't yet decided whether I should just duct the top and sides and allow some air to go under the IC, or go all the way around.
After that would be figuring out ductwork from the bumper cover to direct more air into the core and subsequently through to the rad.
In these temps (80s/90s) unless I'm just cruising my ECT is living between 205 and 214 constantly
kidlifecrisis is offline   Reply With Quote
 Old 07-02-2015, 10:10 AM   #30
MSP611's Avatar
Mazdaspeed6 for road racing
this thread on the last couple pages have great info on ducting even tho its a ms6
In progress:
 Old 07-02-2015, 10:11 AM   #31
Trail of Fail
Dano's Avatar
You need fan controller mod. I only ever see 195
From pablos group. Sp36 whatever.
Tappin
Easter Bunny (07-02-2015), MSP611 (07-02-2015)
 Old 07-02-2015, 10:24 AM   #32
MSP611's Avatar
I need to get one of those when I order my block... another thing to add to the list.
In progress:
 Old 07-02-2015, 10:39 AM   #33
Trail of Fail
Dano's Avatar
my post was in response to @kidlifecrisis; but yeah that is a must have mod once you up the HP to say beyond 350-400WHP IMO.
edit: but generally a good mod at any HP level. cooler is always better if you aren't concerned with emissions.
 Old 07-02-2015, 01:29 PM   #34
True, but with that kit my fan would basically just be on 100% of the time. Step 1 is to try and redirect the air that's currently going around everything, then depending on my results I can make the call on the fan controller
 Old 07-03-2015, 07:07 PM   #35
Voltwings's Avatar
Updated OP with the following information after removing the under tray
Easter Bunny likes this.
Past:
-Sold-
-Sold-
Current:
The Following 7 Users Say Thank You to Voltwings For This Useful Post:
Code Monkey (07-04-2015), Dano (07-04-2015), DaUberSchwebel (07-04-2015), Easter Bunny (07-06-2015), JgamB (07-03-2015), phate (07-03-2015), torquemaniac (12-13-2016)
 Old 07-04-2015, 01:34 AM   #36
Thanks for the results. My under tray is going back on today.
 Old 07-04-2015, 04:54 AM   #37
Yanahdi's Avatar
Posts: 198   (View Stats)
Yanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the world
As far as air flow one way I've seen people test it is to just tape a bunch of paper strips at multiple points on the car. PITA and looks goofy as shit but it does work. Obviously no quantifiable data but it can serve as a way to confirm data from pressure testing.
Best results would need another car with a camera man to drive alongside.
kidlifecrisis likes this.
Yanahdi is offline   Reply With Quote
The Following 2 Users Say Thank You to Yanahdi For This Useful Post:
Easter Bunny (07-06-2015), Voltwings (07-05-2015)
 Old 07-06-2015, 09:14 AM   #38
where was this measurement taken?
 Old 07-06-2015, 09:59 AM   #39
Voltwings's Avatar
about 1/2" behind one of the little flappers on the passenger side to allow it a chance to open. I didnt want to put it behind the fan because i wasnt sure if that would skew the readings.
Past:
-Sold-
-Sold-
Current:
 Old 12-03-2016, 11:05 AM   #40
Voltwings's Avatar
Ok, so I got a FMIC from a local that I installed today and will be doing more testing. I'll try to lay this out as orderly as I can, but I think what all I am going to test is:
1. Under tray attached. All cowl ducting in place. All stock TMIC ducting in place. FMIC installed.
- Pressure in front of the FMIC core.
- Pressure behind FMIC core (in front of condenser)
- Pressure behind radiator (in engine bay)
2. Under tray removed. All cowl ducting in place. All stock TMIC ducting in place. FMIC installed.
- same tests as part 1.
3. Under tray attached. Cowl weather stripping removed. All stock TMIC ducting in place. FMIC installed.
-pressure behind radiator (in engine bay)
-Pressure in cowl area (at base of windshield)
4. Install @JSmith;s hood scoop ducting. Cowl weather stripping attached, under tray attached, FMIC installed.
- Same tests as part 1.
5. Install Jsmiths hood scoop ducting, remove cowl weather stripping, under tray attached, FMIC installed.
-pressure in cowl area (base of windshield).
g00s3y likes this.
Past:
-Sold-
-Sold-
Current:
g00s3y (12-03-2016), JSmith (12-05-2016), torquemaniac (12-13-2016)
TMIC Sprayer/Improved Ducting Gr8Speed MazdaSpeed 3/6 - Turbo Induction 36 08-20-2014 12:31 PM
Page generated in 0.59785 seconds with 35 queries
