> 2010 MS3 - Turbo Induction
 Old 01-10-2011, 08:56 AM   #1
ChimmyChong's Avatar
Posts: 592   (View Stats)
ChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the world
Groans: 39
Default Turbosmart Dual Port Flutter/Surge/Flutterdump?
Hey gays.... I mean guys...
I just got a turbosmart dual port and was wondering if the sounds I am hearing are normal.
All the videos Ive seen of the dual port don't emit the fluttery sound I get when letting off the throttle in low rpms/low boost situations.
Heres a video I just uploaded of the sounds... I tried to lift off the throttle at lower rpms and gradually go to higher rpms towards the end of the video... You notice the flutter then dump at lower boost/rpms and then a clean dump at high rpms/full boost.
Also I cleaned the bpv/bov and lubed up the internals. After lubing up the piston and walls I double checked the install and it changed nothing... Note that even going from the hardest setting to the softest by quater turn increments did nothing but waste time and lube.
thanks dudes for any input
just noticed I made a duplicate thread in the gen 1 section sry
2010 Liquid Silver MS3
// BNR S3 // 3Bar Map+MJ Harness // JBR 3.5" WP // CS TMIC // KMD HPFP // 3" Catless DP/RP // TS Dual Port // Cobb AP // GS 3 port EBCS // ITV-22's // MD OCC // JBR Small Battery Tray //
// JBR Dog Bone RMM // JBR Heavy Knob // JBR Solid Shifter Bushings // JBR Short Shifter Plate // JBR RSB // JBR 80D PMM // 15mm Front // 10mm Rear // SPC Rear Camber Arms // Sonic Tuning Coilovers //
// 6K HID // 35% tint // 12"RF with Infinity Amp // MZ Front Lip // 17x8 Enkei RPF1's //
Last edited by ChimmyChong; 01-10-2011 at 08:56 AM. Reason: MSF Database - Automerged Doublepost
ChimmyChong is offline   Reply With Quote
 Old 01-10-2011, 10:10 AM   #2
ebnash's Avatar
Posts: 244   (View Stats)
ebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond repute
Neutral  +1 score
Just curious why you guys keep installing dual port BOV's on an engine system that is designed to recirculate. I assume you are running a stock turbo, so why did you pick the Dual Port?
If you want something more robust than the stock BPV, than buy an aftermarket BPV. It will hold more pressure and is less likely to fail.
If you are running a dual port just to make more noise, well than you have problems that I am not qualified to address...
Hunt Hard, Kill Swiftly, Waste Nothing, Offer No Apologies...
ebnash is offline   Reply With Quote
The Following 3 Users Say Thank You to ebnash For This Useful Post:
G26 (07-10-2012), genpoo (01-16-2011), Pointless (07-22-2012)
 Old 01-10-2011, 10:26 AM   #3
FY"IED"N
dMuze's Avatar
Posts: 506   (View Stats)
dMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the world
that sounds normal. without the TIP...you want to start two full rotations softer than its hardest setting. and go from there (assuming you are running 50/50). if its too soft you will have a ton of backfire, and you car will run like shit. if its too hard you may get some type of cut at WOT.
2010 Silver MS3 Tech Pkg 307whp, 340ft/lbs tq
CS SRI/TIP, UR Turbo Back, UR FMIC, TS Dual Port BOV, DENSO ITV22 Plugs, AP EcuTek ProTune, DO STG 2 Prog Kit 100% Meth, JBR SSP w/ Bushings, CS Springs, JBR camber arms, Koni yellows, 80D PMM/88D RMM/88D TMM, MD OCC, CP-E HPFP, Ford Motorcraft tranny fluid, DashDaq, Kenwood 12"sub, Kicker 400w amp, DDM 35W 6k lows/3k fogs, CS LED kit, 20% tint.
dMuze is offline   Reply With Quote
 Old 01-10-2011, 11:25 AM   #4
Groans: 39
Cause Im a ricer
I was planning to run 50/50 for novelty and 100% bpv most of the time...
idk... I don't think a flutter sound is normal
at least to my knowledge its air getting pushed backwards to the turbo and the turbine chopping up that air...
unless its the valve opening and closing in a very fast movement that is causing a mimiced turbo flutter sound...
Here is aerthurfury's video of his dual port .... no flutter whatsoever
Aerthurfury, if your reading this can you chime in with some input?
edit:
also it makes the same flutter sound in 100% bpv mode
I am running the yellow spring it came with
I think its flutter dump
thakns
 Old 01-10-2011, 04:56 PM   #5
FY"IED"N
dMuze's Avatar
how soft is your setting? have you tried starting all the way at the red (or black in my case) line?
 Old 01-10-2011, 05:12 PM   #6
Groans: 39
Yes I've tried every setting from the hardest. Then from there quarter turns until at the red warning line. I'm even getting afterfire in-between shifts at any setting (probably because of the flutter/late dump?)
I've searched far and wide on these forms and google but no one seems to be experiencing my symptoms -_-
 Old 01-11-2011, 08:08 AM   #7
SharkBite's Avatar
Posts: 40   (View Stats)
SharkBite is a jewel in the roughSharkBite is a jewel in the roughSharkBite is a jewel in the rough
Neutral  -1 score
sounds fine to me.
SharkBite is offline   Reply With Quote
 Old 01-11-2011, 08:35 AM   #8
blkspeed307's Avatar
Posts: 509   (View Stats)
blkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the worldblkspeed307 is the leader of the world
Have had it on my car for 3months now 50/50 vta no backfires or problems whatsoever . But your sounds fine to me from the vid, try adjusting it some more & let it break in a bit more.
sent from my HTC evo using
tapatalk
blkspeed307 is offline   Reply With Quote
The Following User Says Thank You to blkspeed307 For This Useful Post:
csmaan12 (07-25-2014)
 Old 01-11-2011, 10:14 AM   #9
xsilent13x's Avatar
Posts: 479   (View Stats)
xsilent13x is the leader of the worldxsilent13x is the leader of the worldxsilent13x is the leader of the worldxsilent13x is the leader of the worldxsilent13x is the leader of the worldxsilent13x is the leader of the worldxsilent13x is the leader of the worldxsilent13x is the leader of the worldxsilent13x is the leader of the worldxsilent13x is the leader of the worldxsilent13x is the leader of the world
I've had mine on 50/50 for about 2k miles and from time to time I get backfires.....loud ones and I've always had that fluttering sound when boosting a bit in low gears. I looked everywhere and people say that this BOV needs to be adjusted per car or needs to be lubed. It took me awhile to find the best place to adjust it at.....and I still have fluttering.
Edit: What I mean by "best place" I mean the point in which it backfired and fluttered the least. I gave up and put it on full-recirc so all I have a a bit of fluttering during low gear shifts.
-- 2010 MS3 Black Mica --
Ultimate Racing TP w/ Res delete, Corksport SRI+TIP, Turbosmart DP BOV, Autotech Fuel Pump Internals, Denso ITV22's, AP Tuned StagePu, custom painted headlights & decals.
From Southern New England? Check out our local club! www.nescc.net
xsilent13x is offline   Reply With Quote
 Old 01-11-2011, 10:37 AM   #10
2010Speed3's Avatar
Posts: 607   (View Stats)
2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world
Hmm I never had an enormous amount of fluttering whenever I had my Turbosmart BOV. I don't know what spring was being used because I bought it used. The ride was harsher with the BOV, and it popped here and there. I ended up putting the stocker back on because I was putting an exhaust and I didn't want the car being any louder and poppy.
SOLD on 08/2013
2010 Black Mica MazdaSpeed3
Performance: BNR S3 - Sure Full 3" Aeros - Bosch 3 Bar Map - DDM HID Kit 6k 35w - Hella Super Tones - CorkSport LED Light Kit - Cobb Knob (Red) - VG Sharkfin Antenna - Sure Anchors - Jbarone 88duro Dog Bone RMM - Black CorkSport SRI/TIP (Powder Coated Black) - Ultimate Racing Race Pipe & CBE - KMD Internals - CorkSport Cold Air Box w/ Carbon Fiber Top - Turbosmart SU Blacked Out BPV - Cobb AccessPort Stage 2 (Nataphen Tuned) - JBarone RSB - CP-E TMIC
2010Speed3 is offline   Reply With Quote
 Old 01-11-2011, 11:15 AM   #11
pearl_ms3's Avatar
Posts: 545   (View Stats)
pearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the world
Groans: 32
Groaned at 27 Times in 12 Posts
have you lubed it? i lube mine every 3 weeks. keeps the flutter away. mine only flutters under 4 psi.
CP-E INTAKE W/ AMSOIL FILTER, CP-E INLET, TURBOSMART BOV, DENSO ITV22, AWR RMM, STREET-UNIT TMM & PMM, STEEDSPEED MANI CERAMIC COATED, T3 GT3076, TIAL EWG, CUSTOM V-BAND DOWNPIPE, UR CATTED TESTPIPE, TURBO XS CATBACK EXHAUST, COBB FMIC, CP-E FUEL PUMP, DASHHAWK+CP-E MOUNT, JBARONE SSP, COBB ACCESSPORT STAGE 2 SF 91 FMIC. SELF TUNED WITH 400HP/375TQ @ 21 PSI ON 100 OCTANE.
pearl_ms3 is offline   Reply With Quote
 Old 08-30-2011, 06:06 PM   #12
borninmotion's Avatar
Posts: 50   (View Stats)
borninmotion will become famous soon enoughborninmotion will become famous soon enough
I just put mine on today. Only get the flutter if I load up the turbo at low rpms (which you arnt supposed to do) but only doing it to test it. Under regular driving and boosting above 3k it seems to sound competely normal. I just popped that thing on and didnt do any adjusting thus far.
borninmotion is offline   Reply With Quote
 Old 09-01-2011, 03:23 AM   #13
Matx's Avatar
Posts: 1,681   (View Stats)
Matx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the world
Ya mine fluttered alot when I first got it, gotta play with it alot and let it break in little more, Its hard to get this to the right spot will take you awhile
MS6 COBB-BROKEN: SOLD
GXP G8: Sold
EVO 8: speed rapist
14 Wrangler
Originally Posted by backward_0 View Post
.... I will be more than happy to fuck your world off....
Matx is offline   Reply With Quote
 Old 09-01-2011, 03:50 AM   #14
Spoofmastafly's Avatar
Posts: 1,444   (View Stats)
Damn ricers. Get a forge V2 and be happy.
Spoofmastafly is offline   Reply With Quote
 Old 09-03-2011, 02:46 PM   #15
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
lol genpu's
The Following User Says NO Thank You to dooderek For This Un-useful Post:
DONOTBUGME (09-03-2011)
 Old 09-04-2011, 04:28 AM   #16
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
blast from the past! Flutter at low load is fine anyways it's high load that you should worry about, you're reaching the surge point, mine does it under vacuum when there is still enough delta pressure between the manifold and cold pipe. It happens when you get a stiffer spring in there.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following User Says Thank You to 86AmishMs3 For This Useful Post:
Hooper (11-25-2012)
 Old 09-04-2011, 04:56 AM   #17
mtran's Avatar
Posts: 195   (View Stats)
mtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond reputemtran has a reputation beyond repute
Amen, V2 has the same sounds without the VTA issues.
2010 Black Mica MS3
mtran is offline   Reply With Quote
 Old 09-04-2011, 07:55 AM   #18
Resetting the ECU will make a big difference as well.. Just saying.
06 MS6 // COBB SRI // TS DP BOV // SU TP // CP-E TMIC // MAGNAFLOW CBE // HR SPRINGS // PROSPORT GAGUES // 35% // 18X8 +50 // 225/40/18 // REAR LED // CB GRILLE // BO SM // DEBADGED //
 Old 09-04-2011, 05:09 PM   #19
My buddies Gen1 did the same thing with his HKS bov (running recirculate) .. that sound just makes me think and feel like the car isn't running right.. thats why I went with the Forge V2, still get a VTA sound when your up in the RPM's... but no low rpm flutters or issues.
 Old 07-09-2012, 11:26 AM   #20
goob_os101's Avatar
Posts: 697   (View Stats)
goob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the worldgoob_os101 is the leader of the world
Back from the dead....My Speed3 hesitates from time to time and pops. When I go WOT In 2nd gear (mid rpm) the car will begin to hesitate and pop then accelerate. When I shift into 3rd and go WOT it does the same thing. I am experimenting with softer settings to see if it goes away. It has been 99-105 degrees out with high humidty which makes the car
08 MS3 RIP
05 Saabaru
goob_os101 is offline   Reply With Quote
 Old 07-09-2012, 06:45 PM   #21
Illusion's Avatar
Posts: 123   (View Stats)
Illusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant future
Groaned at 34 Times in 12 Posts
this is not an issue my turbosmart bov flutters at low boost. All that is happening is the boost pressure is not enough to cause the piston to open quickly the the remaining pressure is being fluttered out slowly, it's really a smart design (turbo-smart). Have to get atleast 5 pounds of boost before i get a signifigant phhhhh sound. Again some ppl are into ricer i got mine so i can hold higher amounts of boost.
Illusion is offline   Reply With Quote
The Following User Says Thank You to Illusion For This Useful Post:
kairojya (07-17-2012)
 Old 07-09-2012, 07:46 PM   #22
Voltwings's Avatar
Posts: 3,713   (View Stats)
^^ this, you only have to worry if you boost a significant amount and it flutters, 2-3 psi wont hurt anything, there is a spring in there to assist the piston and you're just not building enough pressure to cleanly over power the spring. Mine did that for like 30k miles on stock turbo and inspected the thing when i went BT a few weeks back and you'd think it was a new turbo, no issues.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 07-22-2012, 10:01 AM   #23
crizer1706's Avatar
Posts: 1   (View Stats)
crizer1706 is an unknown quantity at this point
Hi there
I just got my turbosmart bov in the mail yesterday. It came tightened to its hardest setting. I took a few drives and I adjusted it so it was in the middle of hard and soft and I still got some surge and a little bit of backfire so I loosened it in quarter turn increments and the surge at lower boosts went away but I still got some backfire once every few shifts. The only time I surge is either at low boost with low RPMs and also at high boost and low RPMs(which I was just testing) Is this normal? I have it adjusted about 4 and a quarter full turns from the hardest setting.
crizer1706 is offline   Reply With Quote
Turbosmart Dual Port Flutter/Surge/Flutterdump? ChimmyChong MazdaSpeed 3/6 - Turbo Induction 1 01-10-2011 09:29 AM
Turbosmart Dual Port sheltbh MazdaSpeed 3/6 - Turbo Induction 3 10-26-2009 02:38 PM
Page generated in 0.43930 seconds with 37 queries
