![]() Join Date: May 2014
Rep Power: 0 ![]() Thanks: 0
![]() Join Date: Sep 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 246
| The Following 2 Users Say Thank You to nilashish For This Useful Post: | Code Monkey (06-09-2014), Vader (06-13-2014) |
![]() Join Date: Nov 2010 Location: Columbus, GA
Rep Power: 4253 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,493
Groans: 307
| Not Ranked : 0 score You apparently missed this section.... New Member Section Start there... You will find the answers you seek.
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() |
![]() Join Date: Nov 2010 Location: Long Island, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 581
| Not Ranked : 0 score If you have to ask a question about upgrading your turbo, you shouldn't. |
| The Following 3 Users Say Thank You to kby For This Useful Post: |
![]() Join Date: Feb 2012 Location: davenport, iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 128
| Not Ranked : 0 score have hpfp internals or an ap? any other mods ? list em.
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. |
![]() Join Date: Jan 2011 Location: Lynn Haven/Niceville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 831
Groans: 77
| Not Ranked : 0 score This one, upgrade to this one. No mods needed.
__________________ 2011 MS3 BLACK MICA W/TECH PACKAGE BNRSv3 - COBB 3 Port Boost Controller - BOSCH 3 Bar MAP Sensor - HTP 3" Intake (Candy Red)- CS Downpipe - CS LED Fog Lights - CS Interior LED Kit - CS Hood Strut Kit - COBB AccessPORT - JBR Adjustible Rear Sway Bar - JBR Solid Shifter Bushings - SURE Flow M3 W/ Res Delete - MangnaFlow 4x3.5" Stainless Exhaust Tips - AutoTech Internals - JBR 88a Dogbone RMM - H&R Lowering Springs - NGK Iridium Step Colder - Beachshoer's Pnp Intake Manifold W/ VTCS Delete - TurboSmart Plumb Black BPV - CX Racing FMIC - 18x8 Bronze MB Motoring Battles - Nitto Motivo 235/40/18 - Hawk HPS Brake Pads - Block8head Dual Gauge Pod - Prosport Evo Boost and Coolant Temp Gauges - Autodvdgps Touch Screen DVD Player W/ Navigation - CS Radiator Cover - CS Exhaust Manifold Cover - CS OCC Stratified Tune In Progress SCCA Member# 450495 Class - SMF TRMotorsport C3 17x9 Hancook 255/245 RS-3 LIQUOR AND WHORES |
| The Following 2 Users Say Thank You to Kamaril For This Useful Post: | Easter Bunny (06-14-2014), socaltouch13 (06-12-2014) |
![]() Join Date: Oct 2011 Location: Fort Irwin, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21
| Not Ranked : 0 score I think your best option would be the search bar.
__________________ 2011 Black Mica MS3 //Cobb AP V3//Autotech Internals//Ultimate Racing TBE//Ultimate racing FMIC//Grimmspeed EBCS//JBR OCC//SURE RMM (Street Urethane)//SURE Shortcut //SURE Countershift //SURE Anchors //Corksport SRI // Corksport TIP // Turbosmart Duel Port BOV // Ksport control pro coilovers // 35% Tint All Around // Corksport LED Fog Lights // Corksport Interior LEDs // Corksport Stub Antenna // Corksport Eyelids // XXR 527s 18x8.75 35mm// |
![]() Join Date: Jun 2013 Location: New Orleans, LA : From LI, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
| Not Ranked : 0 score Was that even English?
__________________ 2013 CWP MS3 w/Tech Pkg Performance Mods Cobb AP V3 ~ JBR 3" WP Intake + Turbo inlet ~ JBR IC Boost tubes ~ AT hpfp Internals ~ ETS TMIC ~ CS Catless DP ~ CS Race pipe ~ CS Catback ~ CP-E Stg2 RMM ~ NGK Iridium IX's (1 step colder) ~ Turbosmart 50/50 ~ KSport Pro Coilovers [SIGPIC][/SIGPIC]on 93 307whp 339lbft Exterior mods: ESM 004s - Hankook Ventus V12 Evo2 225/40/18 - Gloss Black Vinyl Roof - Gloss Black emblems - 15% tint - Rear Wiper delete - OEM window visors On Order: GT2871r, Freektune 3.5" Intake, Bosch 3.5 Bar Map sensor, Cobb EBCS |
![]() Join Date: Nov 2012 Location: Winston-Salem, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,946
| Not Ranked : 0 score Search. What mods are on your car now?
__________________ Past 2012 Speed3. GT3071r // Manley rods // Wiseco pistons // some other goodies and some Nator love ![]() Present 2014 Chevy Silverado Z71 |
Groans: 63
| Not Ranked : 0 score bn rs1
| The Following User Says Thank You to anavrinIV For This Useful Post: | Easter Bunny (06-14-2014) |
![]() Join Date: Jan 2011 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 311
| Not Ranked : 0 score BNR S3
__________________ 08 MazdaSpeed3 | Cobb AP | MS Intake | CS TIP | CP-E FMIC | CNT Catless TBE | ITV22 | | AutoTech Internals | TurboSmart BOV | BC Racing Coilovers | CS RMM | CS TMM | | Black Powdercoated Stockers | Built Motor | | Mahle 88mm Pistons | Manley H-Beam Rods | |
![]() Join Date: Mar 2013 Location: Huntsville, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,402
| Not Ranked : 0 score This is hands down the best replacement you could ever buy. Mazda MZR 2.3 DISI Elevate? Turbo | cp-e?
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) |
| The Following 3 Users Say Thank You to JgamB For This Useful Post: |
![]() Join Date: Aug 2012 Location: State College, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 987
__________________ 2006 Mazdaspeed 6 (Titanium Gray) : Built, gtx2867r Purple Drank tuned 12.07 @ 116 on 205 snow tires hunting for 11's on 245's | |
| The Following 2 Users Say Thank You to DVM17 For This Useful Post: | Easter Bunny (06-14-2014), JgamB (06-12-2014) |
![]() Join Date: Jan 2013 Location: Fairless hills, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18
| Not Ranked : 0 score must have scared him away? |
![]() Join Date: Dec 2008 Location: FLORIDA
Rep Power: 1419 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,235
| Not Ranked : 0 score He's around..... Last Activity: Today 07:11 PM Current Activity: Viewing Thread Resolving HPFP corn woes (black death/sticking spill valve)
__________________ 2008 Mazdaspeed3 GT GTX2867r ![]() |
(Thread Starter) | Not Ranked : 0 score Sorry haven't looked at this in awhile but as of now mods are Fmic, tbe, tih, mscai, autotech internals, Cobb rmm, Cobb Ap with ots stage 2, turbosmart bpv |
Spend $600 more and get a GT3071 and make 380(?) on a somewhat conservative tune. It's all about your goal at this point
__________________ Past 2012 Speed3. GT3071r // Manley rods // Wiseco pistons // some other goodies and some Nator love ![]() Present 2014 Chevy Silverado Z71 | |
![]() Join Date: Aug 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Hey im looking to run a similar setup that you have. I currently do not have a DP but will be getting one in the near future. Any idea of what your hp/tq is? | |
/threadjack
| Not Ranked : 0 score Sooo you trying to sell that BNR S3 you havent installed yet?
| Not Ranked : 0 score Yea, $2000
![]() | | #24 | ![]() |
| Not Ranked : 0 score Wow I didn't even notice that or the fact that you don't even have the bnr s3 installed yet lol |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score I've read people running 400hp on the stock blocks and would love to go that route with the gt3071 but wouldn't I need the ewg setup along with safe seals and a new manifold? |
![]() | | #26 | ![]() |
![]() Join Date: May 2013 Location: Bryn Mawr, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,449
| Not Ranked : 0 score its the TQ you gotta be careful of when getting into the 400 area with the stock block..or so I've read..
__________________ 2013 LSM Mazdaspeed3 - stocked out and traded 6/5/2017 2017 LGM Golf R - South Bend stage 3 daily clutch / IE intake / Wagner IC / AWE downpipe / Indvidia catback / EQT Tuned 2004 Yamaha R6 - Micron Ricer Pipe / PC 2005 Honda CBR 600 F4i - R.I.P. 10/29/13 |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah I also read that the way you blow these things up is producing too much torque below 3k rpm |
![]() | | #28 | ![]() |
Once I get my BNR on and start tuning, I'll be wanting to keep my torque around 350
__________________ Past 2012 Speed3. GT3071r // Manley rods // Wiseco pistons // some other goodies and some Nator love ![]() Present 2014 Chevy Silverado Z71 | ||
![]() | | #29 | ![]() |
| Not Ranked : 0 score 400whp is difficult to achieve just on the stock fueling system especially in the summer. Either you need a very well flowing setup that stays far from the knock threshold and is lighter on fuel use because of this or some additional fueling from a wmi system or additional injectors.
| The Following 2 Users Say Thank You to Lex For This Useful Post: | kby (06-14-2014), WAMBUSHHHH! (06-15-2014) |
| Mythbusted:are there real gains from upgraded turbo intake hose? | dale_gribble | Mazdaspeed3/6 General Discussion | 63 | 02-15-2013 03:06 PM |
| Which Upgraded Turbo to Choose? | 11cruzito11 | MazdaSpeed 3/6 - Turbo Induction | 22 | 11-22-2009 12:37 AM |
| Upgraded/reworked turbo questions | red07 | Mazdaspeed3/6 General Discussion | 5 | 11-08-2008 12:08 PM |
| no upgraded stocker turbo dynos? | digitaljedi | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 8 | 09-08-2008 02:21 PM |
