![]() Join Date: Dec 2015
Rep Power: 0 ![]() Thanks: 2
(Thread Starter) | Not Ranked : 0 score I recently bought a purple fin for my HKS SSQV not knowing that I can't insert a fin while it's recirculating. I took the SSQV off, noticed I can't install the fin and I reinstalled it. Ever since then I have noticed a whining when I'm in boost. It never did it before which leads me to believe it's something not reinstalled correctly or it was a massive coincidence. I checked that the gasket is still in good shape, all my bolts are tight, and my recirculating hose clamp is tight. I also made sure that the recirculating "cap" or whatever it's called is tightened well with the 4 hex bolts. I have a video if anyone can give me some ideas of things to check. I am tuned for 20lbs of boost, and am still reaching that for the most part, so I'm not sure if I have a boost leak or where to go from here. Thank you in advance for the help. https://www.youtube.com/watch?v=yzRlB1f1dr4 |
| Front end whining noise | rocarr2 | Mazdaspeed3/6 General Discussion | 5 | 04-22-2015 07:03 AM |
| Whining noise when turning | Castillo817 | Gen2 MS3 General Discussion | 25 | 01-27-2015 08:03 PM |
| Whining Noise Front End - Help?!!! | jfkireland | MazdaSpeed 6 - Engine, Transmission & Driveline | 5 | 03-24-2013 01:23 PM |
| Whining noise in reverse? | shadowms3 | Gen2 MS3 General Discussion | 13 | 05-23-2011 08:15 PM |
| whining noise when cluch is out? | 02stang951 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 2 | 04-01-2010 01:46 PM |
