> 2010 MS3 - Turbo Induction
  • 1 Post By Tomumass06
 Old 10-12-2018, 11:44 AM   #1
Tomumass06's Avatar
Posts: 18   (View Stats)
Tomumass06 has a little shameless behaviour in the past
Default XS Power K04 option
Have any of you ever heard of this brand turbo, XS Power? I did a search but yielded nothing on here. Not too expensive.
Tomumass06 is offline   Reply With Quote
 Old 10-12-2018, 12:19 PM   #2
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
XS Power has been around for a while. They developed an exhaust manifold for our platform that evolved over 3 revisions. Its now the V3.
The turbo they offer is a rebuilt OEM with their billet wheel and supposed upgraded bearings and seals. Seems legit but never heard of anyone buying one. I'd save up for at least a BNR S3. Around $400 more or a little less if you find one used in good condition.
Tomumass06 (10-12-2018)
 Old 10-12-2018, 04:03 PM   #3
Tomumass06's Avatar
Trust me, I’ve been back and forth over the bigger-performance turbo over the stock setup but my car is bone-stock in every way. It bugs the heck out of me to know I could go with a larger and better flowing unit which has a minimal cost difference over the stock set-up but my engine has 122k on it-albeit with good compression, clean plugs, system and all, but the other components would need to be upgraded to match the larger turbo which would really jack up the cost. I have to say, the maintenance over the years since new has been minimal and very standard-oil changes every 3500-4000 miles, front brakes only once, air filter, and 1.5 sets of tires (rotation every 25-30k). Either way, I’m going to upgrade the fuel pump, have to fix/change the TIP, new plugs (maybe Denzos), and thinking of eliminating the stock air filter box and change to a K&N conical-style filter. I have been going back and fourth with K04 replacements or CHRA replace as the housings-both hot and cold side, look good. I read the write-up about the Rotomaster CHRA on this site but never heard any more data since the authir had a “chirping issue” to diagnose. It was not clear whether this was due to the CHRA or something else although the write-up seemed to point away from the turbo.
Ms3stock likes this.
 Old 10-19-2018, 11:36 AM   #4
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
The BNR turbos are mostly bolt-on. I think the only things you'd have to upgrade is the intake and fuel pump internals......and a tune.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
New Clutch option for bigger power guys pinkcheese MazdaSpeed 3 - Engine, Transmission & Driveline 76 02-10-2013 01:14 PM
Video: Bike Magazine loses pedal power in favor of Porsche power Haltech Automotive News 0 09-22-2011 01:20 PM
Rumormill: Ford's Power Stroke diesel getting power increase to beat GM Duramax Haltech Automotive News 0 03-24-2010 07:20 AM
Antec True Power Trio TP3-550 ATX12V 550W Power Supply with Three 12V Rails $49.99 at newegg Haltech Hot Deals Section 0 04-16-2008 09:40 AM
COOLER MASTER Real Power Pro 750W Power Supply $59.99AR at ZipZoomfly Haltech Hot Deals Section 0 04-14-2008 05:00 PM
Page generated in 0.25584 seconds with 22 queries
