Like Tree4Likes
 Old 10-31-2011, 02:36 PM   #1
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
Default anti lift kit possibly will fit MS3?
So I have been in the search to find suspension components that will improve the handling for our cars. Whiteline has a lot of bushing kits and such, which I am interested in. But I found this http://www.whiteline.com.au/docs/bul...e%20BL-371.pdf .. I know it says focus RS but I have been told it would be a direct fit. This part is not out yet (due in Jan) but seems like it could be a nice improvement for us. I called whiteline US to confirm; the techs were at the SEMA show but I left a message. I want this if it will work. @Nliiitend1 where you at? what do you think?
Ex_WRX_driver likes this.
The Following 2 Users Say Thank You to specvspeedfreak For This Useful Post:
Nataphen (11-25-2011), TexasSpeed3 (11-12-2011)
 Old 10-31-2011, 02:46 PM   #2
Ex_WRX_driver's Avatar
Posts: 719   (View Stats)
Ex_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the world
subbed
2011 Liquid Silver
Corksport SRI/TIP/AIRBOX
Ultimate Racing catback
JBR stage 2 shift kit
SURE RMM
Ex_WRX_driver is offline   Reply With Quote
 Old 10-31-2011, 02:57 PM   #3
this is another Whiteline part I will be getting. should be a noticeable improvement
 Old 10-31-2011, 03:05 PM   #4
Didnt link to anything.
2011 Liquid Silver
SURE RMM
 Old 10-31-2011, 03:07 PM   #5
really .. it works for me
try this Whiteline
 Old 10-31-2011, 03:17 PM   #6
Nah still didnt work, I just copied the part # in and pulled it up.
2011 Liquid Silver
SURE RMM
 Old 10-31-2011, 04:41 PM   #7
Danish's Avatar
Posts: 595   (View Stats)
Danish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the world
Groaned at 249 Times in 46 Posts
Interesting.
Danish is offline   Reply With Quote
 Old 10-31-2011, 05:20 PM   #8
apparently MRT Performance in Australia confirmed this will work for the MS3. Bad news they expect it to cost $300. Maybe @jbarone can come up with his own version to save us some money?
EDIT: looking up other whiteline anti lift kits, I don't think this will cost $300. Others kits are half that price. But it still would be nice to buy these from @jbarone
AJ713 (11-25-2011)
 Old 10-31-2011, 05:40 PM   #9
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Well the "Anti-Lift" kit and the Caster Correction bushings that you also linked to replace the same bushings, so you'll probably want to go with one or the other...
Regarding cross-fitment with the MS3, as long as the inboard mounts for the RS's LCAs are the same as the MS3's (which is pretty likely), then there shouldn't be a problem. The real difference between the RS's LCAs and the MS3's is that there is no outboard balljoint on the RS. It's just a single-axis link (since the part that bolts to it doesn't need to turn) instead.
blkspd3 likes this.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
 Old 10-31-2011, 07:28 PM   #10
TRex's Avatar
Posts: 3,139   (View Stats)
i guess i dont quite understand what this is.....just a sway bar kit???
 Old 11-01-2011, 05:18 AM   #11
Thanks man. Yeah I didn't know exactly where the anti lift kit was mounted. I found out that the brackets in the kit (vs just having the bushings) will allow for fully adjustable caster and anti-lift.
I will wait and see what happens on the anti-lift kit.
 Old 11-01-2011, 05:34 AM   #12
The Following 7 Users Say Thank You to specvspeedfreak For This Useful Post:
AJ713 (11-25-2011), allo80 (09-29-2014), dshrek (11-12-2012), SLOWHATCH (01-08-2012), TexasSpeed3 (11-12-2011), TRex (11-01-2011), zpele (11-12-2011)
 Old 11-01-2011, 06:55 AM   #13
TRex's Avatar
^thanks
also read this FAQ on nasioc
Anti-lift Kit FAQ - NASIOC
The Following 2 Users Say Thank You to TRex For This Useful Post:
smoogs12 (05-26-2012), wolly6973 (11-01-2011)
 Old 11-01-2011, 08:13 PM   #14
RamiLP's Avatar
Posts: 85   (View Stats)
RamiLP has a reputation beyond reputeRamiLP has a reputation beyond reputeRamiLP has a reputation beyond reputeRamiLP has a reputation beyond reputeRamiLP has a reputation beyond reputeRamiLP has a reputation beyond reputeRamiLP has a reputation beyond reputeRamiLP has a reputation beyond reputeRamiLP has a reputation beyond reputeRamiLP has a reputation beyond reputeRamiLP has a reputation beyond repute
Groaned at 10 Times in 2 Posts
what this kit will help mostly is when you launch the car, it will reduce the amount of squat, what i mean by squat is when you take off or launch, the front lifts up and the rear dips down.
why is this bad?? well we have FWD cars, when you launch it the weight of the car shifts back wards, the front end lifts up, and the weight on the front wheels becomes less, so the traction in the front is reduced a lot which results in just spinning the tires and blowing white smoke, looks cool, but it will effect your 0-60 times.
so by change in the angle of the front front control arm, it helps reduce the front end lift. but that only solves 1/2 the problem, because the rear still wants to dip down, so you still need to do the same to the rear in order to help it from squatting, but in the rear you would have to change the angle the opposite direction that what you did to the front.
2011 Velocity Red MS3 W/Tech
"Technically Fully Bolted" CS sir/tip, Racing Beat CBE, CS TP, UR catted DP, CP-e TMIC, AutoTech HPFP, 1 step colder NGK plugs, Cobb AP stage 2 (+ self tune), Forge V1 BPV, JBR solid shifter bushings, SU RMM, NRG Torque Dampener, DDM 35w 3000k Fogs, LED rear bumper marker, aluminum Polished factory MS3 wheels, replaced stock wimpy horn with a set of Mazda6 dual horn setup.
RamiLP is offline   Reply With Quote
The Following 7 Users Say Thank You to RamiLP For This Useful Post:
GunGuru727 (08-29-2012), rghispanic88 (11-12-2011), SLOWHATCH (11-12-2011), smoogs12 (05-26-2012), specvspeedfreak (11-01-2011), TexasSpeed3 (11-12-2011), zpele (11-12-2011)
 Old 11-12-2011, 12:14 PM   #15
Pedal-Force's Avatar
Posts: 419   (View Stats)
Pedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the world
subbed. I definitely need something like this for my car. I'm getting tons of wheel spin, plus some really bad wheel hop occasionally. I don't have that much HP really, probably 280 to the wheels, but you can't use any of it, lol. I can't imagine what guys are doing with 400+ HP.
2010 MS3 - Liquid Silver - tech package, Nav, Bose - Cobb AP - HPFP from HPFPUpgrades - JBR Cro-Mo Dogbone RMM - JBR SSP and solid bushings - tinted windows - Ultragauge - CS SRI/TIP - Super duper tranny fluid - Denso ITV22 plugs.
wish list - Catted DP, EGR block off, intake and throttle thermal gaskets, OCC, throttle coolant bypass
maybe list - BSD, top or front IC, cat back exhaust
2010 CX-7 Grand Touring - Silver - Fiance's car (owned by me though).
Pedal-Force is offline   Reply With Quote
The Following User Says Thank You to Pedal-Force For This Useful Post:
 Old 11-12-2011, 06:54 PM   #16
From the Aussies
Fulcrum castor/anti lift bushes
Whiteline Anti Lift Kit
 Old 11-24-2011, 12:23 AM   #17
Roddiy's Avatar
Posts: 5,388   (View Stats)
Groans: 279
This sounds really good,
has anyone here had an anti-lift kit on any other cars? If so, does it affect daily driving?
2010 LSM Speed3
#BakeryTuned
 Old 11-25-2011, 08:39 PM   #18
it will increase NVH
 Old 11-25-2011, 08:54 PM   #19
TexasSpeed3's Avatar
Posts: 1,996   (View Stats)
TexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the world
Groans: 273
bah who cars about nvh
2011 Black Mica - Daily
JBR SSP and heavy knob and SSB | Sure RMM | Corksport SRI/TIP/RSB/TMIC | Tanabe FSTB | Cobb AP getting PERM'd | Autotech internals | H&R springs | DDM HID | pussy delete - catless ebay dp and tp
TexasSpeed3 is offline   Reply With Quote
The Following User Says Thank You to TexasSpeed3 For This Useful Post:
specvspeedfreak (11-25-2011)
 Old 11-25-2011, 09:18 PM   #20
I know I won't care much about the lil added NVH; Some people might though. Improvement will be worth it.
To see a review on ALK on a FWD car I would suggest reading this
Whiteline Anti Lift Kit - WALK Review « markFive GTI
BTW. I received an email from Whiteline a few weeks ago. Part will be release early January. I will be keeping an eye out for the release so I will update the thread..I am getting this, no doubt
 Old 11-25-2011, 09:20 PM   #21
Groans: 273
sweet another part on your car im gonna be jealous of.
 Old 11-25-2011, 09:30 PM   #22
You want a magnaflow CBE? lol .. Im getting a UR CBE.
 Old 11-25-2011, 09:43 PM   #23
Groans: 273
nah i want a UR bastard lol. there is a guy in austin with it. sounds nice
 Old 11-25-2011, 09:44 PM   #24
Nataphen's Avatar
Posts: 2,704   (View Stats)
Nice find! I'm also interested in the test fitting of the new Focus LCAs. They are lighter and longer, so they would add more front camber out of the box. I'm hoping that we can find many parts to cross shop in the near future with the Euro-Focus finally coming over.
FYI, I'm more interested in adding caster than anti-lift. I don't drag race much these days, but I drive the hell out of my cars on country roads. Having an adjustable one like the Fulcrum would be bad ass.
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
The Following 3 Users Say Thank You to Nataphen For This Useful Post:
daafisch (11-25-2011), specvspeedfreak (11-29-2011), TexasSpeed3 (11-25-2011)
 Old 11-26-2011, 09:01 AM   #25
Todd98SE's Avatar
Posts: 1,077   (View Stats)
Nataphen, in regards to the Focus LCA's see this thread http://www.mazdaspeedforum.org/forum/foru...02/index3.html Enjoy my fail.
www.MOTOIQ.com
Beater Titan
Todd98SE is offline   Reply With Quote
The Following 4 Users Say Thank You to Todd98SE For This Useful Post:
Nataphen (11-26-2011), Nliiitend1 (11-26-2011), specvspeedfreak (11-29-2011), TexasSpeed3 (11-26-2011)
 Old 11-26-2011, 09:19 AM   #26
Nataphen's Avatar
I'm subbing to that thread for updates. Thanks for going out on a limb to figure that out.
The Following User Says Thank You to Nataphen For This Useful Post:
 Old 01-08-2012, 03:55 PM   #27
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
Any updates on ALK? I wants
The Following 2 Users Say Thank You to SLOWHATCH For This Useful Post:
Bucker (01-08-2012), Tomas (01-08-2012)
 Old 01-08-2012, 09:22 PM   #28
Todd98SE's Avatar
JP @ Edge just checked with Whiteline and they will probably be scheduled for release at the end of the month, pricing is not set yet.
www.MOTOIQ.com
Beater Titan
nextgenerationx1 (01-08-2012), Nliiitend1 (01-08-2012), SLOWHATCH (01-08-2012), specvspeedfreak (01-09-2012)
 Old 01-09-2012, 05:21 PM   #29
just called whiteline and they said it's still in the final stage of developing. It wont be out for another 1-3 months, sucks.
The Following 3 Users Say Thank You to specvspeedfreak For This Useful Post:
Nataphen (01-18-2012), SLOWHATCH (01-09-2012), TexasSpeed3 (01-09-2012)
 Old 04-19-2012, 09:41 PM   #30
It's released
Whiteline KCA428 Front Anti-lift/caster - control arm lower inner rear bushing
Nliiitend1 (04-19-2012), skeurton (04-19-2012), Todd98SE (04-19-2012)
 Old 04-19-2012, 10:57 PM   #31
Todd98SE's Avatar
Its interesting that the bulletin on the Whiteline site says it fits Gen 1 only but the webpage says it fits both? I haven't looked under a Gen 1 but I don't think there is any difference in mounting between the Gen 1 and 2. Thoughts anyone?
Edit: Reading further it doesn't look like the installation instructions deal with the swaybar brackets on the Gen 2. Assuming the bolt diameter is the same as OEM this would possibly just need a longer bolt depending on how thick the flanges are on the new bushing.
www.MOTOIQ.com
Beater Titan
 Old 04-19-2012, 11:05 PM   #32
yeah I saw that and replied with a question about it on their FB post about it.. I'm going to try calling them soon if they don't reply to the question.
 Old 04-20-2012, 12:40 AM   #33
JSC already has it on their website..
07-12 Mazdaspeed3 Whiteline Anti-Lift Caster Kit: JSC Speed
Intruder (05-01-2012), Scoobs (04-21-2012)
 Old 05-01-2012, 02:08 PM   #34
Intruder's Avatar
Posts: 144   (View Stats)
Intruder has much to be proud ofIntruder has much to be proud ofIntruder has much to be proud ofIntruder has much to be proud ofIntruder has much to be proud ofIntruder has much to be proud ofIntruder has much to be proud ofIntruder has much to be proud ofIntruder has much to be proud ofIntruder has much to be proud of
Who's getting these?
2010 Mazdaspeed3
Intruder is offline   Reply With Quote
 Old 05-01-2012, 02:15 PM   #35
Not sure who else..but I already ordered mine from JP
 Old 05-01-2012, 03:56 PM   #36
YoursTruly's Avatar
Posts: 325   (View Stats)
I would like to see an install and review thread.
2010 MS3 "Maiko" - Sold
Last edited by YoursTruly; 05-02-2012 at 03:33 PM. Reason: unanswered question deemed irrelevant
 Old 05-23-2012, 10:53 AM   #37
Whiteline has this at their wherehouse now... So if you order this you should be able to get it fairly soon... I'm still waiting on mine
SLOWHATCH (05-23-2012)
 Old 05-23-2012, 03:18 PM   #38
SFWD 1934's Avatar
Posts: 973   (View Stats)
SFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the world
Mine shipped yesterday.
Jason
JRL Tuning 510-459-7229
www.full-race.com
SFWD 1934 is offline   Reply With Quote
The Following User Says Thank You to SFWD 1934 For This Useful Post:
 Old 05-23-2012, 04:58 PM   #39
foodtime's Avatar
Posts: 225   (View Stats)
I've never touched the suspension world other the easy to install JBR sway bar. How would aftermarket suspension, springs or coilovers, become affected from this anti lift kit? (I don't want to buy parts that aren't compatible with each other)
 Old 05-23-2012, 07:08 PM   #40
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Subbed for results.
Pickles Tune in progress
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Anti-Rice of The Day titusdrake MazdaSpeed 3/6 - Appearance 43 09-25-2012 12:07 PM
Cobb AP & Anti-theft Map suszi MazdaSpeed 3/6 - ECU Computer Tuning 3 10-20-2011 12:05 PM
How much anti-freeze? SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 5 07-11-2009 07:50 AM
Page generated in 0.61899 seconds with 37 queries
