 Old 12-11-2018, 09:54 AM   #1
tmaiorca's Avatar
Posts: 193   (View Stats)
tmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of light
Default Ball Joint Replacements
Hey all,
So my ball joints are bad, really bad. Mechanic said to order Moog's and he'll get them replaced for me, however I'm having a really hard time trying to find replacement ball joints for my 2010 MS3.
Total n00b here, but from all my searching I only see Advanced Auto selling the lower control arms + ball joints for ~180$ per side.
Is this accurate in that I must replace my control arms as well, or can I get away from just doing the ball joints? If so, does anyone have a part # or brand that is a known OEM replacement?
RIP 2006 MS6:: CP-E CAI // 3" CP-E TIP // SU Turbosmart BPV // M2 3" Catless DP // Cobb AP v2 //CP-E Rear Motor Mount // JBR SSP //JBR OCC // 1" Springs // EGR Unplugged // JBR Coolant Bypass // JBR TIG
2010 Genpu:: JBR SRI // JBR TIH // SU Turbosmart Full Recirc BPV // Cobb AP v2 // S-OTS Tuned // RallyArmor UR
tmaiorca is offline   Reply With Quote
 Old 12-11-2018, 04:59 PM   #2
doublegmoto's Avatar
Posts: 23   (View Stats)
doublegmoto will become famous soon enough
Yup, you have to get the control arm
Sent from my LGMS631 using Tapatalk
doublegmoto is offline   Reply With Quote
 Old 12-26-2018, 06:50 PM   #3
08mzr's Avatar
Posts: 641   (View Stats)
08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world
You do not have to get a whole control arm. The ball joint is replaceable on its own. I dont have part numbers, but can get them if you still need them.
2008 Metro Gray Mica Speed 3-SOLD
Corksport SRI
Corksport TIP
JBR 80 duro RMM
Cobb AP v3
Autotech internals
CX Racing FMIC
SPC rear camber arms
Hawk HPS pads front and rear
FREEKTUNE OTS+
1998 Civic - SOLD
2011 Speed3 200k+ miles Stock -Daily
08mzr is offline   Reply With Quote
 Old 12-26-2018, 07:46 PM   #4
That's cool where can we get them. I've been looking for 3 years
One more thing are we talking about front balljoints?
Just to make sure are we talkin about the front ball joints
Last edited by doublegmoto; 12-26-2018 at 07:46 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-26-2018, 07:49 PM   #5
08mzr's Avatar
When i replaced them on my gen 1 i believe i got them from NAPA. Ill look through my paperwork tomorrow to find the part numbers I used.
I am talking about front lower ball joints. I dont think there are any others on the MS3
Corksport SRI
Corksport TIP
JBR 80 duro RMM
Cobb AP v3
Autotech internals
CX Racing FMIC
FREEKTUNE OTS+
1998 Civic - SOLD
 Old 12-26-2018, 08:27 PM   #6
07MS3TrueRed's Avatar
07MS3TrueRed is an unknown quantity at this point
You need to buy the whole arm for the Gen 2, I always order from Rock Auto https://www.rockauto.com/en/catalog/...trol+arm,10401
07MS3TrueRed is offline   Reply With Quote
 Old 12-26-2018, 08:59 PM   #7
08mzr's Avatar
My driver's side needs replacing soon. While I was replacing the engine it looked the same as my previous speed. I will buy the same ball joint I used previously and give it a try.
Corksport SRI
Corksport TIP
JBR 80 duro RMM
Cobb AP v3
Autotech internals
CX Racing FMIC
FREEKTUNE OTS+
1998 Civic - SOLD
 Old 12-27-2018, 11:55 AM   #8
Yeah I have a gen2. So are there seperate front balljoints? Cause I searched hi and low and only found that you must buy entire arm.
 Old 12-27-2018, 12:12 PM   #9
08mzr's Avatar
On my gen 1 i replaced both lower ball joints separately. While i was doing the engine on my gen 1 i was looking at the ball joints because one was loose and it looked similar so i thought it could be replaced separately. I will know for sure when i attempt it soon.
I used Moog part # K500209 for my gen 1 and will order these to try for the gen 2
Edit: further research shows gen 1 and gen 2 control arms are different part numbers. I am still going to compare the replacement ball joint and attempt replacement. If it works then I'm a genius, if it doesn't then ill just replace the control arms. I have the tools so i may as well try.
Corksport SRI
Corksport TIP
JBR 80 duro RMM
Cobb AP v3
Autotech internals
CX Racing FMIC
FREEKTUNE OTS+
1998 Civic - SOLD
Mevotech adjustable ball joint ZX299 MazdaSpeed 3/6 - Suspension & Brakes 3 11-26-2014 01:42 PM
MS3 LCA ball joint dead-zone MazdaSpeed 3/6 - Suspension & Brakes 1 10-20-2014 08:34 AM
Really Really Seized Ball Joint, Thoughts? Coaststarlight MazdaSpeed 3/6 - Suspension & Brakes 6 12-30-2013 10:41 PM
Ball joint help?! MS6FL MazdaSpeed 3/6 - Suspension & Brakes 1 03-16-2011 04:01 PM
Page generated in 0.29727 seconds with 23 queries
