 Old 06-03-2019, 11:36 AM   #1
flyrevs2's Avatar
Posts: 1,235   (View Stats)
flyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the world
Default Gen2 rear sway advice - I need some !
Ok I'm wondering if I should swap the Cobb rear sway from my Gen1 to my new Gen2 before I sell the Gen1. It will be my daily driver and I won't ever auto-x it but I do like driving it hard around corners occasionally. Is it worth it or should I just keep the stock rear sway and be happy with that ? It seems to handle pretty good stock, although I know there is a bit of understeer. Thanks for any advise !
2013 Mazdaspeed3 Gen2
Mods: Cobb SRI, Tip, Turbosmart BPV, Cobb AP, Cp-e DP, CPE HPFP, CPE RMM, PTP Kicker Mount
flyrevs2 is offline   Reply With Quote
 Old 06-06-2019, 03:40 PM   #2
ThorOtheBIG's Avatar
Posts: 56   (View Stats)
ThorOtheBIG has a spectacular aura aboutThorOtheBIG has a spectacular aura aboutThorOtheBIG has a spectacular aura about
Aren't the sway bars the same from Gen1 to Gen2? I'd keep it and swap it over.
ThorOtheBIG is offline   Reply With Quote
OEM Springs & Rear Sway Bar (Gen2) erics 2010 MS3 - Suspension & Brakes 6 10-08-2017 09:51 PM
Corksport Struts, JBR Rear Sway Bar, JBR Rear Camber Arms Install/Initial Feedback Sinister_Speed3 MazdaSpeed 3/6 - Suspension & Brakes 15 11-25-2015 09:03 AM
Page generated in 0.23143 seconds with 21 queries
