 Old 07-18-2017, 12:03 PM   #1
Bazgona's Avatar
Posts: 6   (View Stats)
Bazgona will become famous soon enoughBazgona will become famous soon enough
Default Headlight auto level sensor
Hi guys hope you can help my headlight leveling link on the front has snapped i tried cold weld a while back but has failed again, mazda dont sell the links separately unfortunately, is there an easy way to replace this with?
Bazgona is offline   Reply With Quote
 Old 07-19-2017, 02:08 PM   #2
Bazgona's Avatar
I've found a company who sell angled joint so retaining the ball joint part and using a threaded rod cut to length might be my solution, just waiting to hear back from the comapny for thread size fittings.
 Old 07-31-2017, 01:50 PM   #3
Bazgona's Avatar
All fixed and replaced
 Old 08-03-2019, 09:44 PM   #4
NicAlarcon's Avatar
Posts: 2   (View Stats)
NicAlarcon is an unknown quantity at this point
With regards to the sensor itself, how do I know if the sensor is shot once the rod is fixed? I tried just turning the sensor till the flashing AFS light went off but I couldn’t find the original point where it was set
NicAlarcon is offline   Reply With Quote
Do I need a new front subframe?? Auto levelling headlight sensor bracket broke Mazda3Blog Gen2 MS3 General Discussion 4 06-06-2015 07:22 AM
Canada Spec Washer Tank with level sensor UnknownSuperhero 2010 MS3 - Fuel, Nitrous & Water Injection 3 11-04-2014 09:02 PM
Fuel Level Sensor issues adlpb 2010 MS3 - Troubleshoot/Diagnostics 22 07-22-2012 11:59 PM
Auto Headlight levelling sensor Rich990 2010 MS3 - Car Audio & Electronics 12 04-26-2012 10:28 AM
is there a headlight level adjustment on genpu? 2012speed3 Gen2 MS3 General Discussion 44 01-04-2012 04:33 PM
Page generated in 0.23980 seconds with 22 queries
