  • 1 Post By Nliiitend1
 Old 02-15-2016, 10:49 AM   #1
Sp15shak's Avatar
Posts: 10   (View Stats)
Sp15shak is an unknown quantity at this point
Default Mazda 3 suspension on Mazdaspeed 3
hello everyone im new to speed's and ive searched for info but i cant find any, is it possible to put second gen mazda 3 coilovers on a mazdaspeed 3? Ive found a good deal and i want to know if i should pull the trigger
Sp15shak is offline   Reply With Quote
 Old 02-15-2016, 11:08 AM   #2
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Possible? Yes.
Advisable? Not really.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
WetzMS3 (02-15-2016)
 Old 02-15-2016, 11:10 AM   #3
Sp15shak's Avatar
Possible? Yes.
Why not?
 Old 02-15-2016, 11:26 AM   #4
ryguy 3's Avatar
Posts: 353   (View Stats)
Originally Posted by Sp15shak View Post
Why not?
the Spring ranges are not the same for both cars, The mazda 3 coilovers will be geared for the lighter front end vs the slightly heavier nose of the mazdaspeed 3. they might bolt in but they won't perform as they should.
The Following User Says Thank You to ryguy 3 For This Useful Post:
Nliiitend1 (02-15-2016)
 Old 02-15-2016, 11:29 AM   #5
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
Possible? Yes.
This would be the guy you want to listen to.
 Old 02-15-2016, 11:29 AM   #6
Sp15shak's Avatar
Oh ok got it, what if i change the springs tho, like going to swift springs? Or is the dampening for the 3 different than the speed
 Old 02-15-2016, 11:32 AM   #7
Nliiitend1's Avatar
Damping needs are dictated by largely by spring rate...
Depending on the particular setup, there may not be enough adjustability to handle the increased rates.
What specific setup are you considering?
2008 MS3 GT
2016 MX-5 Club
 Old 02-15-2016, 11:38 AM   #8
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
The mazdaspeed 3 is like 180-200kg (that's about 400 pounds) heavier than the regular mazda 3. So the coilovers are designed for that weight and the reduction in height is also engineered from the height of a regular 3 to take into account the bushings twisting angle and everything.
If you put a regular mazda 3 suspension on a speed3 what you'll have will be a suspension that will bottom out every time the wheels go over a chewing gum, will be under damped and the ride will have quite a bit of floppiness even on normal/good roads.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 02-15-2016, 11:39 AM   #9
Sp15shak's Avatar
Damping needs are dictated by spring rate...
They are st coilovers
 Old 02-15-2016, 11:42 AM   #10
Nliiitend1's Avatar
I'd pass if I were you.
2008 MS3 GT
2016 MX-5 Club
 Old 02-15-2016, 11:46 AM   #11
Sp15shak's Avatar
Ok well im glad i asked u guys cause if i didnt i wouldve been assed out. Thanks guys ill keep looking for mazdaspeed coilovers and i know that gen 1 suspension will work on gen 2 with little modifications so ill maybe look into those aswell.
 Old 02-15-2016, 11:52 AM   #12
ryguy 3's Avatar
There a potential group buy for some yellow speed coilovers here:
Group buy!
 Old 02-15-2016, 03:12 PM   #13
mituc's Avatar
Groans: 111
Gen1 works on gen2 and the other way around with 0 modification. I know that because I sold my Bilstein B14 kit to a gen2 owner.
 Old 02-15-2016, 03:28 PM   #14
Nliiitend1's Avatar
Not exactly...
The bottoms of the rear shocks are different, and require at the very least some additional parts to make work.
Gen 1 has a wider shock eye bushing, and uses a longer bolt. If putting Gen 1 shocks on a Gen 2 you need a longer bolt. If putting Gen 2 shocks on a Gen 1 you need washers or some sort of spacer.
gen 1 to gen 2 suspension
texasboy21 likes this.
2008 MS3 GT
2016 MX-5 Club
Matt H. (03-28-2016)
Mazdaspeed 6 (Mazda 6 MPS) suspension options robby85 MazdaSpeed 3/6 - Suspension & Brakes 13 12-18-2012 07:23 AM
will a regular mazda 3 support mazda speed 3 suspension Eyce 2010 MS3 - Suspension & Brakes 7 03-29-2011 10:41 PM
Page generated in 0.33884 seconds with 24 queries
