Like Tree10Likes
 Old 07-29-2014, 07:08 PM   #1
1LapMS3's Avatar
Posts: 36   (View Stats)
1LapMS3 is a name known to all1LapMS3 is a name known to all1LapMS3 is a name known to all1LapMS3 is a name known to all1LapMS3 is a name known to all1LapMS3 is a name known to all
Default New Wilwood 6 Piston kit
Hey all,
Just received email from Wilwood about the launch of their 6 piston BBK for our cars. Here is a link to their page: Wilwood BBK
I also talked to Todd at TCE Performance Products (google it) and he is making upgrades for those kits up to 14"!! Very reasonably priced. I will be getting a kit from him with the upgraded FNSL6 Caliper and 13.10" rotors.
Will post pics and feedback once I get the kit, probably next month or so. I track my car so this will be a nice upgrade from stock!
Later,
Enrique
2011 Mazdaspeed3
CP-E HPFP, Corksport TIP and intake, catless DP, Grimmspeed 3 port EBCS. Cobb Tuning Accessport Freek tuned and loving it!!
1LapMS3 is offline   Reply With Quote
The Following 7 Users Say Thank You to 1LapMS3 For This Useful Post:
Alpha (11-30-2014), duffman04 (07-30-2014), hideyuki_s (07-30-2014), kbz0129 (10-25-2014), phate (07-29-2014), taf0422 (07-29-2014), Yousuf (08-12-2014)
 Old 09-03-2014, 08:38 PM   #2
ouchmonkey's Avatar
Posts: 268   (View Stats)
ouchmonkey is the leader of the worldouchmonkey is the leader of the worldouchmonkey is the leader of the worldouchmonkey is the leader of the worldouchmonkey is the leader of the worldouchmonkey is the leader of the worldouchmonkey is the leader of the worldouchmonkey is the leader of the worldouchmonkey is the leader of the worldouchmonkey is the leader of the worldouchmonkey is the leader of the world
Update? Im looking into the 14" FNSL6 kit.
Corksport:CAB//SS+Bushings//Frnt Adj SB w/Adj End Lnks//RMM//HPFP//Skd Plate//Int LED kit//Poly Trans MntCobb:Shft knb//APv3//Cattd DP//BOVTires:Street - Dunlop Zll 235/40/18//Track - NT01sTein:SS CO w/EDFC ActivePro+GPS ModuleTri-Point Engineering:Rear Adj Race SB w/Adj End Links//Performance Spec Alignmnt//Cstm CAB CvrETS:TMICHTP:3" Intake//Small Battery BoxWilwood TCE:FNSL 14" rotor 6 piston kit & SS brd lines with Stoptech 600 fluidDamond MS:OCCStratified:Shift Extr//TuneOther:Rolld Frnt and Rear Fendrs//Ichiba V.2 15mm Spacers//Mazda 5 Rear Rtrs w/StopTech Pads&SS brd lines//NGk 1stp colder
ouchmonkey is offline   Reply With Quote
 Old 09-03-2014, 08:57 PM   #3
1LapMS3's Avatar
Sorry, I am having to hold off due to some unexpected expenses and job change. Hopefully everything comes together by end of year. Planning on building up car over winter for next year's season.
2011 Mazdaspeed3
 Old 09-03-2014, 10:37 PM   #4
ouchmonkey's Avatar
Werd. Good luck man. I may get it done first and update you!
 Old 09-04-2014, 04:23 AM   #5
1LapMS3's Avatar
Sounds good. I can tell you from past experience that the Wilwood kits are high quality stuff. Have had them on a couple of other cars.
Sent from my SCH-I535 using Tapatalk 4
ouchmonkey likes this.
2011 Mazdaspeed3
 Old 09-08-2014, 04:57 AM   #6
Yousuf's Avatar
Posts: 1,398   (View Stats)
Groans: 128
Willwood brakes all around are the next big thing I want
Mod-bug's back...
 Old 09-08-2014, 02:30 PM   #7
ouchmonkey's Avatar
Yeah, Im hoping to have mine installed before the next event on 10/24/14.
I spoke with Todd at TCE (via email) and he said for what I do (lots of track driving) that the standard DP6 Wilwood kit is too light weight. - Mind you this is after Wilwood directed me to him after I tried to get Wilwood to build me a custom kit at Mazdafest.
TCE recommends their big boy FNSL6 kit on 14" rotors. So Ill let you all know how goes it.
Oh and far as "all the way around" this is what Miguel at Wilwood said, "....for the rear of the Mazda 3, we have never made a kit direct and do not plan on it due to the OEM parking brake."
TCE makes a rear rotor kit but the caliper is gonna remain stock. I guess I'll paint it to match.
The Following User Says Thank You to ouchmonkey For This Useful Post:
blam1 (09-29-2014)
 Old 09-08-2014, 04:23 PM   #8
Yousuf's Avatar
Groans: 128
Is there anything for the rear or is this just front brakes only. I'm confused of all the willwood variants because I've seen so many
Mod-bug's back...
 Old 09-08-2014, 04:45 PM   #9
Todd@TCE's Avatar
Posts: 159   (View Stats)
Todd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond repute
I'll help, if you'll oblige.
There is only ONE Wilwood factory kit for your car: the 13" DP6 kit. No matter what you read, who says it or what it's called this is the first and only kit Wilwood produces for your car.
There are however other kits produced using Wilwood product in part. Me being one of those with the FNSL6 option discussed above. Yes it can be confusing. You'll seldom see any kit produced by my company that is not rightly labeled TCE/Wilwood. Anyone else selling similar kits should be doing the same as it's a mis representation of Wilwood not doing so. I covered that in greater detail in my own intro post.
There are NO Wilwood rear kits for your car as Miguel stated- And pretty much what I knew would be your answer to that. Anyone making a rear kit, including my proposed "rotor kit" would also not be a Wilwood kit. That being said, there is the opportunity to produce a Wilwood caliper shod kit. This however would be a single piston sliding caliper arrangement exactly as you have now. Nice part. Looks great. Works the same. And costs $1300 to do. Not really what I see as a huge seller. For that very reason we produced the 12" rear rotor kit years ago and will look at doing so again.
And for the more street enthusiast minded driver who would seldom see any "beat the crap out of it 30min open track sessions" the DP6 kit would be a fine choice. Even with proper pads it's durable enough for moderate track use.
Vehicle Applications
Driving Environment Vehicle Sub-Types Application Duty
Street Rods Heavy Duty
Street Performance Domestic Heavy Duty
Street Performance Import Heavy Duty
Rally Medium Duty
Road Race Medium Duty
Late Model Dirt STARS, UMP, IMCA, etc... Heavy Duty
Drag Racing Heavy Duty
Northeast Modified Dirt or Pavement Medium Duty
Open Wheel Sprint, Midget, etc… Dirt or Pavement Medium Duty
Off Road Medium Duty
Industrial Medium Duty
There are a number of options as a buyer. Be honest with yourself and your budget. Ask the right question from the right people. Compare info and make an informed decision is all that's needed.
VRM_MS3, Yousuf and ouchmonkey like this.
TCE PERFORMANCE PRODUCTS
Your one stop....for Wilwood Brakes.
* Corvette * Lightning * Impala SS * Focus ST * Marauder * 350/370Z * MINI * Challenger * WRX *Super Duty * SHO * Mustang *...and more!
Todd@TCE is offline   Reply With Quote
The Following 3 Users Say Thank You to Todd@TCE For This Useful Post:
Easter Bunny (10-16-2014), ouchmonkey (09-08-2014), Yousuf (09-08-2014)
 Old 09-08-2014, 04:47 PM   #10
Yousuf's Avatar
Groans: 128
Thank you for this! I'm gonna re read it in detail when I get home
Mod-bug's back...
 Old 09-16-2014, 02:25 PM   #11
ouchmonkey's Avatar
Just got off the phone with Todd. I'm about to drop my deposit and will let you all know how these bad boys perform after my next track event on 10/24.
The Following 2 Users Say Thank You to ouchmonkey For This Useful Post:
1LapMS3 (09-16-2014), maisonvi (09-16-2014)
 Old 09-16-2014, 02:28 PM   #12
Yousuf's Avatar
Groans: 128
Can't wait to see this
Mod-bug's back...
 Old 09-16-2014, 02:35 PM   #13
1LapMS3's Avatar
Definitely keep us posted. Pics would be great too!! THANK YOU!
2011 Mazdaspeed3
 Old 09-29-2014, 04:06 PM   #14
ouchmonkey's Avatar
Update from TCE:
...Just to update you; Bill is machining the 14" brackets and I hope to have them completed in a day or two. We'll need to get them anodized as well. Can't give you a firm date yet but much of it is moving along, albeit slowly, and methodically to completion....
I let him know my next event is 10/24 and need to have these in and road tested by then...... Ill keep ya'll in the loop. *I am very excited*
I think I will paint my rear calipers black to match and get SS lines as well as upgraded pads.
 Old 09-29-2014, 04:47 PM   #15
Todd@TCE's Avatar
I'll toss in a set of 'old' rear hoses. From when I first did Mazda kits. Won't have a cover on them, just good old ss like the old days.
 Old 09-29-2014, 05:20 PM   #16
ouchmonkey's Avatar
....and that, ladies and gentlemen, is unparalleled customer service!!!!
Thank you Todd, you are world class.
 Old 09-29-2014, 05:26 PM   #17
Todd@TCE's Avatar
LOL....yeah...no..not really.
I just have about three sets of the old non jackets hose kits here I couldn't bear to just throw out! Someone may as well put them to good use.
(but thanks anyhow!)
 Old 10-09-2014, 04:26 PM   #18
ouchmonkey's Avatar
All my goodies arrived yesterday!!! I will snap some pics of before/during/after install. This is a beefy set! Well done TCE/Wilwood.
1LapMS3 likes this.
 Old 10-09-2014, 07:47 PM   #19
Yousuf's Avatar
Groans: 128
Eagerly awaiting these pics mane
Mod-bug's back...
 Old 10-16-2014, 01:45 PM   #20
ouchmonkey's Avatar
Hopefully will post pics tonight. I am having Tri-Point Engineering do the install and they are documenting the whole process for me to post. Just waiting on pics...
 Old 10-16-2014, 01:47 PM   #21
Yousuf's Avatar
Groans: 128
From what little I've heard, tri point seems to know their shit
Mod-bug's back...
 Old 10-16-2014, 02:47 PM   #22
ouchmonkey's Avatar
They do. Ive been going to them for everything I dont have the time or know-how to do.
 Old 10-17-2014, 02:46 PM   #23
ouchmonkey's Avatar
We all know how to find TCE's description of the kit and what is included, so I will skip that. TCE Performance Products
What wasn't in the description but was thrown in for no good reason other than he's a cool character, Todd gave me - free of charge, a set of SS braided lines for the rear.
The kit is in. I have yet to test (still at TriPoint). Here are some pics. The install process was as planned and went smoothy, aside from a minor fitment issue that was quickly resolved between TCE and TriPoint (and will not be a future issue as TCE made a slight change in milling the of the bracket). I am now running Stoptech 600 brake fluid as well.
I spoke to Todd at TCE about whether or not to post the full install process including the hiccup and he said that he had no problem with me letting you all know how this first set for our cars went.
Here is what Todd said:
"I had done all the mock ups and test fit parts here using only TCE components. All of that before Wilwood came out with the DP6 kits. When they did that I opted to do their hats (and larger 14" rotors) rather than the TCE parts.
The hats used on the factory kit are about .050" different in offset making the centering different that what we programmed for here on the initial plan.
On me. I didn't follow up on the milling program to make the necessary change. And the original pics and fit etc were all right on the money. Until we made the aluminum hat change. Should be a quick fix on his end and I'll square up with him on that directly."
And he is sending me a new set of brackets (although the milled set now fit like a glove) as a finished product that is fully anodized and without evidence of mill work (even though the milling was done on the mounting side and is not visible anyway).
So as you can see this was a trickle down math error that has been resolved and the product fitment should now be seamless for all future kits as there was no other issue other than that.
I had no problem being the guinea pig on this first set and as an over all experience this went very well. This is a quality product (even TriPoint was impressed). Todd will get my business again - sooner than later, he just finished a rear rotor set.
I hope this helps you in your BBK decision making. I will post again after the track event on 10/24/14 and let you all know about performance.
VRM_MS3 likes this.
The Following 4 Users Say Thank You to ouchmonkey For This Useful Post:
BPASPEED (10-25-2014), Code Monkey (10-18-2014), duffman04 (10-18-2014), MBalik (10-18-2014)
 Old 10-18-2014, 09:49 AM   #24
duffman04's Avatar
Posts: 65   (View Stats)
duffman04 has much to be proud ofduffman04 has much to be proud ofduffman04 has much to be proud ofduffman04 has much to be proud ofduffman04 has much to be proud ofduffman04 has much to be proud ofduffman04 has much to be proud ofduffman04 has much to be proud ofduffman04 has much to be proud ofduffman04 has much to be proud of
Looks awesome! Fills out the 18" wheels too. Do you track the car a fair amount? My old gen1 speed 3's stock brakes were no where near track ready even with motul 600 flushed through. Interested to hear if you think the 2 piece rotors changed the feel much too, thats huge weight savings alone.
2013 Mazdaspeed3: CPE Stage 2 RMM, AP, JBR SRI, HTP TIP, Konig Oversteer - 18x8 +35.
2010 Honda Fit Sport: Stock.
1994 Dodge Viper RT/10: Drop in filters with straight tubes, Lemke 3pc hardtop.
1981 Corvette: Slowly became a restomod.
duffman04 is offline   Reply With Quote
 Old 10-18-2014, 11:55 AM   #25
ouchmonkey's Avatar
I Track as much as I can. That's why I had this kit installed. The stock brakes were my fail point last track day. I want to be the weakest link in my car. I want everything else solid! I will keep you all updated.
 Old 10-20-2014, 07:24 PM   #26
Todd@TCE's Avatar
Updated some info for you on the rear rotor kit as well.
 Old 10-20-2014, 07:29 PM   #27
ouchmonkey's Avatar
We will talk soon. I have many more pics to post as soon as I get them from John.
 Old 10-25-2014, 12:51 AM   #28
ouchmonkey's Avatar
Ok. So I don't LOL or BFF or TGIF..... but OMFG!!! It took a ffew hours to figure out how to drive with these things and the ABS fuse eventually had to be pulled but I have never experienced braking like this. Absolutely incredible. I rode the Wilwood Polymetric H pads for the day and they bit down and stayed consistent all day (in combination with Nitto NT01'S). I am supremely pleased and although the first half of the day was learning how to not engage the ABS or catapult my eyeballs out of their sockets I learned to use them and had a blast. I was so much deeper in each turn before engaging, my passengers let out sqeals - and only one of them was a woman.
Thanks again Todd.
Pics to come.
The Following 3 Users Say Thank You to ouchmonkey For This Useful Post:
BPASPEED (10-25-2014), Code Monkey (10-25-2014), Pointless (11-30-2014)
 Old 10-25-2014, 12:53 AM   #29
Yousuf's Avatar
Groans: 128
Damn that sounds amazing
Mod-bug's back...
 Old 10-25-2014, 05:22 AM   #30
BPASPEED's Avatar
Posts: 1,891   (View Stats)
Groans: 60
May I add that they looked sexy as hell, the brakes, not the passengers lol
BPASPEED is offline   Reply With Quote
 Old 10-25-2014, 08:11 AM   #31
Todd@TCE's Avatar
I think we should have stayed with my first plan and run the Poly B pads. Less bite and easier to modulate perhaps. But in time you'll be doing fine with the H as well.
Next up: rear rotor kit.
Thanks for the report!
The Following User Says Thank You to Todd@TCE For This Useful Post:
maisonvi (10-31-2014)
 Old 10-30-2014, 06:50 PM   #32
Todd@TCE's Avatar
If this 14" model is a bit steep for your budget or needs....consider the factory 13" Wilwood kit!
 Old 10-30-2014, 11:59 PM   #33
ouchmonkey's Avatar
Not if you can swing it gents. Ends justify the means. Worth every penny.
 Old 11-30-2014, 09:39 AM   #34
trackweapon's Avatar
Posts: 3   (View Stats)
trackweapon is an unknown quantity at this point
I've been looking into the DP6 kit for my car as well at the 4 piston Corksport kit. In doing the math the prices are pretty similar considering the wilwood kit includes rotors and the corksport kit doesn't. Any opinions on which would work better for a car a is primarily a daily driver?
trackweapon is offline   Reply With Quote
 Old 11-30-2014, 11:57 AM   #35
^ No reason to upgrade for a DD.
littleloogy (11-30-2014), phate (11-30-2014), Vansquish (12-01-2014)
 Old 11-30-2014, 12:28 PM   #36
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
Stock is better for a DD
 Old 11-30-2014, 12:55 PM   #37
In the summer months I do 4 or 5 track days or autocross events a month and its causes some brutal uneven wear on any of the pads I've tried.
 Old 11-30-2014, 03:00 PM   #38
Relube your slider pins.
 Old 11-30-2014, 05:32 PM   #39
ouchmonkey's Avatar
Definitely pay mind to those guide rods (slide pins (. If you burn that off it'll feel like your master cylinder is gone (no more power brakes) and it makes a sound that'll make you cringe.
I went BBK on a car that I drive to work everyday. I didn't fool with piecing a kit together, trying new pads, ss lines or 600 fluid. I did some research. Spoke with some drivers. Spoke with some engineers and decided that fir the amount that I track the car and hit the canyons a BBK was in order if I had the money. The kit is well worth it if you drive the twistys often enough. But if the canyons are a once a month thing or the track is a few times a year, then there are probably other options.
As I've said a few times before... my brakes became the weakest link in my car, so they had to go. I want to be the mod that needs work. I want my car to do what ever my ability dictates. And now I'm one step closer to that.
I went wilwood/tce because Wilwood sent me to Todd. They said that for what I want the stock Dp6 kit may be a bit too light weight. I threw my business at them and they deferred.
More to come. Baby is crying...
 Old 11-30-2014, 06:41 PM   #40
Todd@TCE's Avatar
if your budget doesn't allow for the added costs of the 2ph hats and rotors don't overlook a simple caliper kit for improved response and feel.
That being said a larger and wider disc will afford you increases in brake torque, greater resistance to fade, improved cooling (given the oe parts are not a directional casting and the 2pc are) as well as modest weight savings in both the rotor and caliper area.
The calipers will allow you relatively quick pad changes and ample compounds for your needs. The 2pc hats and rotors will be part of a kit when purchased as such so do compare apples to apples if you need to buy new 'rings' for the use of the caliper kits. And of course be certain you factor any ss flex hose needs if not included as the oe caliper hose type will not work with the Wilwood calipers.
The base 13" DP6 kit is a great street to moderate track use kit. And a helluva bargain at $1100. However as was mentioned; if you truly do more open track use I'd consider a move to the more robust FNSL6 and it's respective, larger pad.
Wilwood Brake Kits at EdgeAutosport! EdgeAutosport.com EdgeAutosport.com 280 02-13-2015 02:26 PM
Fastbrakes Wilwood Brake Caliper Upgrade Kits @ therpmstore.com Chimmike Revolution Performance Motorsports 46 02-11-2015 10:08 PM
wilwood 4 piston caliper kit msp2709 MazdaSpeed 3/6 - Suspension & Brakes 7 05-07-2014 09:30 PM
Page generated in 0.58694 seconds with 29 queries
