 Old 07-15-2019, 09:20 PM   #1
ONiX's Avatar
Posts: 3   (View Stats)
ONiX is an unknown quantity at this point
Default Rear Coil Spring Height Adjustment?
Hello. I'm currently having an issue with my rear tires rubbing on the quarter panels on mild to harsh bumps. I was wondering if there was any type of spacer or something that can be placed on the springs to give it a bit of a lift. If not, is there any company that sells adjustable rear springs individually? I've seen coilovers kits, but they're only kits and they come with the front struts as well which I do not currently need. Thank you!
ONiX is offline   Reply With Quote
 Old 07-16-2019, 01:14 PM   #2
Posts: 2,235   (View Stats)
you can search airlift thread, a baloon installed inside your worn out coil to stiffen them.
there is rubber that could be stuffed on the coil also but it isn,t great. i had some against squat it wasn,t helping much.
usually people just get the rear fender rolled by a professional to get clearance.
Stock rear coil spring questions tripppleP 2010 MS3 - Suspension & Brakes 22 02-11-2020 11:05 AM
Mazda s3 rear K&W V1 height adjustment mazdas3 MazdaSpeed 3/6 - Suspension & Brakes 6 07-31-2014 09:54 AM
Rear coil spring spacers JgamB 2010 MS3 - Suspension & Brakes 2 11-14-2013 11:45 AM
Coilover Rear Height Adjustment hruiz1 2010 MS3 - Suspension & Brakes 2 02-19-2012 09:45 PM
Setting rear ride height on BC coil overs trdsw MazdaSpeed 3/6 - Suspension & Brakes 2 03-25-2011 06:47 PM
Page generated in 0.24188 seconds with 21 queries
