 Old 08-14-2019, 08:53 AM   #1
spinfly's Avatar
Posts: 22   (View Stats)
spinfly can only hope to improve
Default Rear sway bar bushing replacement, end link removal needed???
Hey guys,
Going to replace my rear sway bar bushings. Do I need to remove the end link? Or can I just remove the sway bar brackets and replace the bushing?
Thanks!
spinfly is offline   Reply With Quote
 Old 08-14-2019, 09:08 AM   #2
Police - Grammarhead
Vansquish's Avatar
Check the FSM.
 Old 08-14-2019, 06:25 PM   #3
spinfly's Avatar
Sorry but FSM?
 Old 08-14-2019, 06:34 PM   #4
Db09ms3's Avatar
Posts: 536   (View Stats)
Groans: 105
Factory Service Manual. Or google it. Pick your poison!
Stockish
 Old 08-14-2019, 07:41 PM   #5
Posts: 2,826   (View Stats)
Originally Posted by spinfly View Post
Hey guys,
Thanks!
It will probably have some preload, so it will be much easier to undo one end of one or both end links so it “relaxes”. You might have trouble going back together if you don’t. I’d replace the brackets and bushings with ones with zerk fittings that can be greased while at it.
The Following 2 Users Say Thank You to MSMS3 For This Useful Post:
CA_MS3 (08-22-2019), Db09ms3 (08-14-2019)
 Old 08-22-2019, 12:57 AM   #6
CA_MS3's Avatar
CA_MS3 has a spectacular aura aboutCA_MS3 has a spectacular aura about
I installed the Corksport RSB on my car and completely agree with this advice. It will be much easier to disconnect the end links at the bar-side ball joints so you that can deal with the bar and brackets separately. The bar is stiff and once you remove the brackets it is going to do what it wants to do based on any preload or stiffness in the ball joints. Chances are that it is not going to be loaded with perfect side-to-side symmetry.
It also makes good sense to take the bar all the way off the car to clean it up near the bushing surfaces. Then you can lube the new bushings and install the brackets, with bar mounted inside, to the car. Last step is reverse of the first, attaching end links at the bar-side ball joints.
The CS RSB and FSB zerk fittings seem like a great idea, but I must admit I have not used them yet. The RSB has been on the car for 3yrs, no squeaks. The FSB has been on for 2yrs, and it squeaks, but not loudly enough for me to go running for a grease gun (yet).
CA_MS3 is offline   Reply With Quote
 Old 08-22-2019, 06:12 AM   #7
tripppleP's Avatar
Posts: 97   (View Stats)
Im curious what the symptoms are of worn RSB bushings? Is it visible to see? I have a some clunking coming from that area of my car when stoping and starting but nothing looks out of sort.
2010 Black MazdaSpeed 3
80k+ miles
CS RMM
Damond PMM
Autotech HPFP
JBR solid shift bushing
DM short shift plate
HPS SRI
G-plus TIP
CP-e TMIC
AP V3 Stage 1 +SF
 Old 08-22-2019, 07:42 AM   #8
Check the end links first. They have a lock/jam nut that can just back off and get loose over time and needs to be retightened. When that happens they clunk. I had that happen on my MS3 on the way home from the dealer on the day I bought the car new.
Years later, it happened again. Far more common that the bushings. Put some blue Loctite on the threads. I ended up putting blue Loctite on both sides. Never clunked again.
But, yes, bushings do eventually wear out. Begin by checking the end links, though. Either loose nut or simply worn out. If end links are ok replace the sway bar bushings. It would be a good time to install new ones with zerk fitting brackets.
C-love (12-12-2019), CA_MS3 (08-23-2019)
 Old 08-22-2019, 09:48 AM   #9
tripppleP's Avatar
Thanks. Im going to check the links out on friday.
Im searching all over and cannot find much on Zerk. I do see a few aftermarket brackets though. But Zerk is eluding me at the moment. Ill search more when I amnoutnof work.
80k+ miles
CS RMM
Damond PMM
Autotech HPFP
HPS SRI
G-plus TIP
CP-e TMIC
AP V3 Stage 1 +SF
 Old 08-22-2019, 10:55 AM   #10
A zerk fitting is a grease nipple on the part that you keep full with a standard grease gun. Some of us believe that grease fittings help to make the bushings or other suspension parts that have them last longer. I typically re-lube these fittings when doing an oil change. You give the fitting a shot or two of grease until you see it come out of the cup or bushing. That also pushes out any water or other foreign material that may have gotten in.
Others prefer permanent suspension parts that do not have grease fittings.
For the rear suspension, I used Moog "Problem Solver" end links. They come with zerk fittings.
The swaybar brackets/bushings with zerk fittings are made by many different sources. Mine came from JBR (James Baronne Racing), a popular Mazdaspeed parts vendor.
The Gen 1 MS3 uses the same part number for front and rear. Gen 2 (yours) has different ones for front and rear. I'm not promoting or endorsing any particular company, this is just the one that I used and they work great. They are sold and priced in pairs. Do both sides at the same time regardless of which side is making noise, because the other soon will and the part is there in the box. The rear is pretty easy. The front can be a bit difficult to get to.
https://jamesbaroneracing.com/shop/i...roducts_id=297
C-love (12-22-2019), CA_MS3 (08-23-2019)
 Old 08-22-2019, 11:53 AM   #11
tripppleP's Avatar
Haha. I was looking at the Zerk greese nipples and thought they were a good idea and had no clue they were what I was looking for. Thanks so much for the information.
I replaced rear coil springs and took the sway bar off the mounts during the process. It was the first time I ever worked on my car. So im getting more familiar a step at a time.
80k+ miles
CS RMM
Damond PMM
Autotech HPFP
HPS SRI
G-plus TIP
CP-e TMIC
AP V3 Stage 1 +SF
 Old 11-06-2019, 08:26 AM   #12
CptScrublington's Avatar
Posts: 1   (View Stats)
CptScrublington is an unknown quantity at this point
Default Moog sway bar bushings
https://jamesbaroneracing.com/shop/i...roducts_id=297[/QUOTE]
So you're saying for the Gen1 the sway bar bushings are the same size? I need to replace mine as I've had this same clunking and am getting tired of it. I'm trying make sure I have the correct size before I order anything as I really don't want to do this job more than once! xD
I'm just looking for an inexpensive replacement for now to rule out the bushings as the source of the noise, would you happen to know the part number for the Moog bushings that would fit with the OEM bracket?
CptScrublington is offline   Reply With Quote
 Old 12-22-2019, 11:26 AM   #13
C-love's Avatar
Posts: 38   (View Stats)
C-love is a name known to allC-love is a name known to allC-love is a name known to allC-love is a name known to allC-love is a name known to allC-love is a name known to all
Did this yesterday on my '08. OEM priced out @ $30 shipped for me, and the JBR were the same price. Didn't drop the subrframe or modify the brackets, just nudged the stoppers in a little closer to make room for the wider brackets and bushings. As others have mentioned a flex head ratcheting 14mm wrench REALLY helps.
My obnoxious clunk is finally gone! My passenger side bushing seemed to be disintegrating... I get the idea it got hosed with brake cleaner or something caustic.
Here is a pic for comparison to OEM.
C-love is offline   Reply With Quote
How-To: Front Sway Bar Bushing replacement w/o dropping subframe DeadWayt MazdaSpeed 3 - How-To's 69 04-15-2019 03:12 PM
Easy OEM Front Sway Bar Bushing Replacement spl 2010 MS3 - Suspension & Brakes 7 12-30-2017 07:42 PM
MS6 driver-side sway bar bushing removal wdautrem MazdaSpeed 3/6 - Suspension & Brakes 16 06-01-2012 10:44 PM
Sway bar link bolt removal MARKSPEED3 MazdaSpeed 3/6 - Suspension & Brakes 12 03-18-2012 09:28 AM
Page generated in 0.34153 seconds with 28 queries
