Like Tree4Likes
  • 1 Post By mituc
  • 1 Post By mituc
  • 1 Post By mituc
  • 1 Post By sheston
 Old 02-25-2016, 09:53 AM   #1
texasboy21's Avatar
Posts: 559   (View Stats)
texasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the world
Default Soft brake pedal feel
When I purchased my MS3 about 5K miles ago from a Ford dealership I negotiated that a brake service be performed on the car, as the pads had very little life left. The dealer replaced the pads and rotors on all four corners with what I was told were Focus ST parts. The stopping power felt fine, but not as firm as I would like, so I bleed the system using my Motive power bleeder (about 5K miles/7 months ago).
Now in that last 500-1000 miles the pedal feels soft, and takes more pedal input (throw) for the car to come to a stop. If I lightly stab the brakes, then press the pedal while coming to a stop it firms up to what I would consider normal, and the distance the pedal has to travel to stop the car is shortened.
I suspect the dealership may have installed regular Focus pads instead of the (presumably) more aggressive ST pads. Further, I am not confident in the dealer's brake work as both front calipers creak like crazy, leading me to believe they did not lubricate the caliper pins.
The brake fluid level is fine.
I have inspected several times for leaks and have not found any.
The pads and rotors were in fact replaced.
Could this simply be the pads giving me a soft pedal feel?
This is my second GenPu MS3, but my first one was purchased new. The first one purchased new had great initial bite, and the pedal throw was not as long coming to a stop.
Any input is appreciated. I want to feel confident in my brakes again!
2012 MazdaSpeed3 - HTP 3" intake, ETS TIMC, Autotech internals, Corksport racepipe, Accessport V3, custom Freektune, CP-E RMM, Koni sports, Progress Technology RSB, AWR endlinks
2003 A4 1.8TQ
APR stg2+, MTM 420cc injectors, EuroCode FMIC, PSi testpipe, Techtonics Tuning downpipe, Forge TIP, Hyperboost DV, 240mm clutch, LWFW flywheel, B5S4 calipers, Goodridge SS lines, Stern snub, motor and transmission mounts, Powerflex rear diff bushing, 034MotorSports rear diff. carrier bushing inserts, JHM SS shifter, solid linkage, stabilizer bushing and weighted knob, Vogtland Jr. Cup Kit, B7 RS4 front and rear sway bars.
texasboy21 is offline   Reply With Quote
 Old 02-25-2016, 10:54 AM   #2
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
This sounds exactly like air in your lines.
Blue Pu.
roguemazda (03-15-2016)
 Old 02-25-2016, 11:16 AM   #3
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Neutral  -1 score
Replace the brake fluid and bleed the lines properly. Replace ALL brake pads and rotors at the same time if you suspect something is wrong. Brakes stop the car. Not being able to accelerate fast will not harm you, but not being able to stop may.
Maybe the ford dealer installed those new good pads (let's assume they were good) on worn rotors. You may not even want to know, just replace everything.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 02-25-2016, 12:16 PM   #4
texasboy21's Avatar
The rotors and pads were both replaced, this is confirmed becuase I watched them do it - I just didnt check the part number on the pads that were installed.
The system (four corners and clutch) has been bled with a power bleeder properly.
Wouldnt this only incur if the system was 'opened'? Since the last time I bled the brakes nothing has been touched.
2003 A4 1.8TQ
Last edited by texasboy21; 02-25-2016 at 12:16 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-25-2016, 01:07 PM   #5
mituc's Avatar
Groans: 111
The rotors or pads don't have anything to do with the soft/spongy pedal. Air/gas bubbles in the brake lines do.
 Old 02-26-2016, 09:59 AM   #6
texasboy21's Avatar
I don’t doubt that the soft pedal feel can be related to the air in the lines, however in my case the pedal began to feel soft nearly 4000 miles after any brake work was performed. I would think that if I had air in the lines it would have become apparent immediately following the service. None the less, I plan on bleeding the brakes again this weekend to see if it resolves my issue.
I also plan on greasing the caliper guide pins to get rid of the awful creaking, however I may hold off on this as I am contemplating upgrading the pads to a more aggressive compound (I have a pile of go fast parts waiting to be installed once I get the brakes sorted). My working theory is that the calipers are not clamping down on the rotor as well as they should due to increased friction on the guide pins. Not sure how likely this is; its just a thought.
2003 A4 1.8TQ
 Old 02-26-2016, 11:50 AM   #7
texasboy21's Avatar
I wanted to show you this article Car and Driver did on various brake pads on a MX-5. It shows quantified evidence that different pads require more pedal force as well as pedal travel.
Performance Brake Pads Compared: Hawk HPS, Hawk HP Plus, EBC Yellowstuff | Car and Driver Blog
2003 A4 1.8TQ
 Old 02-26-2016, 01:33 PM   #8
mituc's Avatar
Groans: 111
More pedal force to get the same braking force is different than the pedal feel. Bleed your lines.
tbcota25 likes this.
AwAfrican (07-15-2016), frothy (02-26-2016)
 Old 02-26-2016, 02:33 PM   #9
frothy's Avatar
Posts: 1,067   (View Stats)
Doing an aftermarket part comparison between the MS3 and Focus ST shows different part #s for front pads. The rears seem to match up. So, are the pads they put on your car even compatible? Did the dealership provide an invoice with part #s ?
 Old 02-26-2016, 02:48 PM   #10
ALPINEST4RS's Avatar
Posts: 905   (View Stats)
Groaned at 8 Times in 3 Posts
Try doing a few ABS stops and see if the pedal rises up. Gravel road. Air gets trapped in the ABS module and its impossible to bleed out of the valving mechanism. After a few stops the pedal should rise.
The Following 3 Users Say Thank You to ALPINEST4RS For This Useful Post:
aznpersuazn (02-27-2016), roguemazda (02-27-2016), texasboy21 (02-27-2016)
 Old 02-26-2016, 11:49 PM   #11
mituc's Avatar
Groans: 111
This is what probably happened actually. There was air in the ABS module and was bled out after one-two more hard stops and now that air is somewhere else. I had the same problem at some point so I kind of know.
 Old 03-15-2016, 11:42 AM   #12
texasboy21's Avatar
Wanted to update this thread. I bleed the brakes once again with a motive power bleeder, and the initial bleeding from the clutch bleeder valve had quite a bit of bubbles. The calipers did not appear to have any air in them.
After bleeding the system the pedal has firmed up quite a bit. I am still unsure how air entered the system over 1K miles after bleeding the the first time, but for now all is good.
I appreciate the replies and help offered by those in the thread.
2003 A4 1.8TQ
 Old 03-15-2016, 03:21 PM   #13
mituc's Avatar
Groans: 111
The ABS pump is hard to bleed, or impossible. Usually when the brake fluid boils and needs to be replaced you need to do a few ABS brake stops to get it out, and bleed the brakes again.
Also, if the mechanic bled the brakes improperly (one of the common mistakes is not to top up quickly enough which results into a lot of air sucked into the system including the ABS pump) or not enough then may also cause this problem to appear after a while.
Whenever it happens go bleed the lines again. Usually it takes about 600-700ml of brake fluid for a complete change, so you have at least 300ml left for one or even two bleeds.
roguemazda (03-15-2016), texasboy21 (03-16-2016)
 Old 04-03-2016, 11:05 AM   #14
texasboy21's Avatar
Bumping this thread..
The brakes are back to feeling soft. What could be going on that could allow air to enter the system? When I bled the brakes most recently, the only air bubbles were from the clutch bleeder.
2003 A4 1.8TQ
 Old 04-03-2016, 12:24 PM   #15
roguemazda's Avatar
Posts: 159   (View Stats)
roguemazda has much to be proud ofroguemazda has much to be proud ofroguemazda has much to be proud ofroguemazda has much to be proud ofroguemazda has much to be proud ofroguemazda has much to be proud ofroguemazda has much to be proud ofroguemazda has much to be proud ofroguemazda has much to be proud ofroguemazda has much to be proud of
unless they got dirt in the brake fluid and its not sealing properly, meaning bits are floating about in the system?? or your master cylinder is failing or there's a very small leak some where
roguemazda is offline   Reply With Quote
 Old 04-03-2016, 04:49 PM   #16
mituc's Avatar
Groans: 111
If you didn't boil the brake fluid in the meanwhile when bleed the system again and top it up. Then see where that goes. There's a chance you had some air in the ABS pump and hopefully it went all out, finally.
 Old 04-03-2016, 10:46 PM   #17
texasboy21's Avatar
Not sure what you are saying.
I will bleed the system again. One thing to note, the brake pedal stiffens up (feels right) when braking with the clutch engaged. Seeing as I had some air bubbles come out of the clutch bleeder screw last time, I think is safe to presume the clutch is somehow involved. Thoughts?
2003 A4 1.8TQ
 Old 04-03-2016, 10:56 PM   #18
mituc's Avatar
Groans: 111
The clutch and brake fluid circuits meet only at the top of the brake fluid fill hole, they have nothing in common otherwise and the exchange of fluid between the two under normal conditions is non-existent.
However, if the fluid boils you may see some exchange.
texasboy21 likes this.
 Old 04-04-2016, 09:00 PM   #19
texasboy21's Avatar
The fluid has not boiled - no track days or hard driving, just to and from work + errands. I did have one "panic stop" but at a low speed ~10mph. The pedal felt better afterwards, but within a few days it became as soft as before.
Sound like air in the ABS?
2003 A4 1.8TQ
 Old 04-04-2016, 10:52 PM   #20
mituc's Avatar
Groans: 111
Yes, it does. Do a panic stop just before you enter the shop for bleeding the brakes. Replacing the brake lines may also be a good idea if you didn't do that in the last few years. I used to get a spongy pedal with GoodRidge stainless lines until I replaced them with the StopTech lines.
texasboy21 (04-05-2016)
 Old 07-04-2016, 08:34 PM   #21
texasboy21's Avatar
Bumping this thread again. I think I found the culprit. My clutch slave bleeder screw seems to be leaking even when tightened.
So the question is, can I replace just the bleeder valve, or is the entire slave toast?
2003 A4 1.8TQ
 Old 07-15-2016, 05:15 AM   #22
texasboy21's Avatar
Bump - clutch bleeder looks to be the culprit - replace the bleeder valve?
Does anyone know the thread pitch and size of the bleeder?
2003 A4 1.8TQ
 Old 07-15-2016, 06:24 AM   #23
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Yes replace bleeder valve.
No that will not help your soggy brake pedal feel.
 Old 07-15-2016, 11:21 AM   #24
texasboy21's Avatar
What WILL help the soggy pedal feel? I have tested, inspected, and bleed the system countless times. Its good for a week or two, then back to mush.
2003 A4 1.8TQ
 Old 07-15-2016, 12:48 PM   #25
mituc's Avatar
Groans: 111
Then probably it draws air through from somewhere. How old are your brake lines?
 Old 07-16-2016, 02:32 PM   #26
texasboy21's Avatar
Stock lines - car was built in late 2012.
2003 A4 1.8TQ
 Old 07-16-2016, 03:24 PM   #27
ChaunceyM's Avatar
Posts: 948   (View Stats)
ChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the world
Check for leaks inside the calipers, too. I know a Focus ST guy that had fluid leaking around the piston seals which lead to him sucking air into the system.
Corksport: SRI & TIP, Strut Tower Brace, Coilovers
CP-e: RMM
JBR: Rear Sway Bar (with Moog End Links)
TWM: Full Replacement Shifter
Cobb: AP
AutoTech: HPFP Internals
Ebay: Test Pipe
ChaunceyM is offline   Reply With Quote
The Following User Says Thank You to ChaunceyM For This Useful Post:
texasboy21 (07-21-2016)
 Old 07-21-2016, 01:10 PM   #28
texasboy21's Avatar
I have inspected the brakes numerous time, but will take a closer look at the calipers.
There has to be something allowing air to get in, but without fluid escaping.
2003 A4 1.8TQ
 Old 07-21-2016, 07:25 PM   #29
sheston's Avatar
Posts: 1,847   (View Stats)
Have you looked to see if the brake bleeders are doing the same thing as the clutch? I assume that was torqued down correctly
I'll also add that I tried one of those vacuum bleeders and it's really hard to see what's going on. It will pull air thru the bleeder screw and look like air in the system. Finally did it the old fashioned way with some help from a pedal pusher
 Old 07-21-2016, 09:03 PM   #30
texasboy21's Avatar
I have not noticed the same thing from the brake calipers.
I am not using a vacuum bleeder, I am using a power (pressure) bleeder. It attaches to the brake fluid reservoir and pressurizes the system to force the air and fluid out of the bleeder. There is no way to push air back through the bleeder with the pressure bleeder.
https://www.motiveproducts.com/colle...ropean-bleeder
2003 A4 1.8TQ
 Old 07-25-2016, 06:03 AM   #31
roguemazda's Avatar
Throw that thing in the bin and get a friend who can take simple instructions ,in bleeding the brakes in the traditional way
 Old 09-05-2019, 05:40 AM   #32
ihamzeh's Avatar
Posts: 1   (View Stats)
ihamzeh is an unknown quantity at this point
have you fixed the issue ?? i have a 2013 mazda 3, and i have soft brake pedal, i bled the system twice, and when i bled it, the pedal were firm for 2 weeks, and then it got soft again, and as i said i bled it twice with the same issue coming back in 2 weeks, any suggestions?
ihamzeh is offline   Reply With Quote
 Old 09-05-2019, 10:03 AM   #33
Db09ms3's Avatar
Posts: 536   (View Stats)
Groans: 105
Take it to a mechanic
Stockish
 Old 09-05-2019, 02:52 PM   #34
mituc's Avatar
Groans: 111
You have a leak. You need to find where that leak is. Usually it's the lines. Usually...
Soft brake pedal after service Fobio MazdaSpeed 3/6 - Suspension & Brakes 12 12-20-2015 10:20 AM
New OEM Clutch with Fidanza Flywheel Soft Clutch Feel zer010gic MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-15-2014 11:12 PM
New brakes feel soft M4Nathan MazdaSpeed 3/6 - Suspension & Brakes 8 02-17-2014 01:26 PM
Rough clutch pedal feel dread MazdaSpeed 3/6 - Troubleshoot/Diagnostics 16 06-13-2013 09:38 PM
brake question... pedal soft at top of travel natmad MazdaSpeed 3/6 - Suspension & Brakes 1 03-13-2011 04:56 PM
Page generated in 0.54638 seconds with 30 queries
