  • 1 Post By narezzaspeed3
 Old 08-12-2013, 05:28 PM   #1
narezzaspeed3's Avatar
Posts: 171   (View Stats)
narezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the world
Groaned at 5 Times in 1 Post
Default Sonic Tuning Coils Installed
I have the rear slammed to its lowest setting, and definitely rubbing on the back so I'm getting my rear fender rolled.
I am running 18x8 +35 varrstoens w/approximately -2.5+ camber on rear, I maxed out the front cambers lol. only rubbing on the rear.
over all ride is comfortable i just cringed a little bit because when i hit rough roads the rear rubs.
getting my fenders rolled this coming thursday.
Thanks to the following users who answered questions during my research before install:
@RayDanger2020
@trixms3
@sonictuning
brandonlee likes this.
narezzaspeed3 is offline   Reply With Quote
The Following 2 Users Say Thank You to narezzaspeed3 For This Useful Post:
Boosted Beluga (08-14-2013), KiwiFlavor (08-12-2013)
 Old 08-12-2013, 05:57 PM   #2
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Neutral  -1 score
I stopped there. You could have done the same if not lower with Racelands for far less.
Mazda247.com
The Following 2 Users Say Thank You to helmetface For This Useful Post:
Arab81253 (12-22-2013), zenit (10-29-2013)
 Old 08-12-2013, 09:19 PM   #3
bstover17's Avatar
Posts: 586   (View Stats)
Groans: 228
I want those wheels! Did varrstoen custom powder coat them for you?
2010 MAZDASPEED 3
 Old 08-13-2013, 10:25 AM   #4
Mazda247.com
thank you for your 2 cents sir. I only did one adjustment so I will raise it as soon as I install a cat back.
'to each on his own.'
no, I had them done locally for $180 for the set. they look nice, too many people has the black on black theme. I may change them to a bright purple or bright green.
The Following User Says Thank You to narezzaspeed3 For This Useful Post:
bstover17 (08-13-2013)
 Old 08-13-2013, 11:49 PM   #5
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
How do they compare to your old setup?
 Old 08-14-2013, 12:55 AM   #6
trixms3's Avatar
Posts: 424   (View Stats)
trixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the worldtrixms3 is the leader of the world
I love my Sonics. About 18k/19k on em now...no complaints. Id suggest these to anyone just looking for DD coils.
@narezzaspeed3; << gotta use the ; to tag someone(unless you were just mentioning names and didnt wanna tag)
Sonic Tuning CO's//JBR rear camber arms//JBR 3.5" WP//Cobb FMIC piping w/ Treadstone TR6 core//Turbosmart dual port bpv//Autotech HPFP//(unbranded) DP//straight pipe axleback// Cobb AP V3// FREEKTUNE
trixms3 is offline   Reply With Quote
 Old 08-14-2013, 01:12 AM   #7
LumberJack's Avatar
Groans: 57
@RayDanger2020
@trixms3
@sonictuning
I'm really really curious as to what the reasoning was to spending damn 4k on wheels if you purchased brand new. Imo if you're spending 4k on wheels you should be driving something other then a speed3 ha
Sent from my SPH-L900 using Tapatalk 2
10.36@148 Fastest Gen 2
 Old 08-14-2013, 05:35 AM   #8
trixms3's Avatar
Varsteons arent 4k set so he didnt spend that /:
The Following User Says Thank You to trixms3 For This Useful Post:
bstover17 (08-14-2013)
 Old 08-14-2013, 05:50 AM   #9
Ray Danger 2020's Avatar
Posts: 768   (View Stats)
Ray Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the world
That's the lowest setting? Doesn't look any lower than mine. Measure from the ground to the top of the wheel wells for me please.
Power: BORG WARNER S360 TURBO w/ .70A/R SINGLE SCROLL HOTSIDE HTP 3.5" WHALE PEEN TIAL 44mm EWG (red) FJ PERFORMANCE TUBULAR MANIFOLD w/ VBAND EWG OUTLET/VBAND CATLESS DP/VTA EWG TUBE/FMIC PIPING - HOTSIDE ROUTED UNDER CAR/AN OIL FEED/DRAIN LINES ULTIMATE RACING CBE TREADSTONE TR1035 FMIC CORE AUTOTECH HPFP INTERNALS COBB TUNING ACCESSPORT GO FAST BITS TMS RESPONS BOV NGK LTR7IX-11
Handling: JAMES BARONE RACING RSB/88aRMM/88aTMM/80aPMM SONIC TUNING S3 COILOVERS STOPTECH SPORT STOP CROSS DRILLED ROTORS BRIDGESTONE POTENZA RE-11 235/40/18 SPC REAR CAMBER ARMS
Extra Shit:SURE SHORTCUT/COUNTERSHIFT/ANCHORS JAMES BARONE RACING SPHERICAL HEAVY KNOB/51r BATTERY TRAY/STAGE II OCC CORKSPORT LED REAR BUMPER REFLECTORS/LED INTERIOR KIT/URETHANE EXHAUST HANGERS/GAS HOOD PROP STRUTS BOSCH 3-BAR MAP SENSOR BITWISE PnP MAP HARNESS COBB TUNING 3-PORT EBCS DDM TUNING 8000K LOWS/3000K FOGS O.Z. RACING ULTRALEGGERAS 18x8 +48 MUTEKI SR48 OPEN ENDED LUGS NUTS ARP 100-7708 EXTENDED WHEEL STUDS HELLA SUPERTONES RALLY ARMOUR MUDFLAPS (BLACK WTH RED LETTERS)
K04 POWER FIGURES
277HP/325TQ SixTuned On 93
314HP/356TQ Rfinkle2 Tuned With 33% Corn
S360 POWER FIGURES
365HP/356TQ Purple Drank Tuned ON 93
421HP/392TQ Purple Drank Tuned w/ 3 GAL E85 MIX
NUMBERS LIMITED BY STOCK BLOCK ON STOCK FUELING TILL SPRING
Ray Danger 2020 is offline   Reply With Quote
 Old 08-14-2013, 08:06 AM   #10
LumberJack's Avatar
Groans: 57
Originally Posted by trixms3 View Post
Varrstoens aren't 4k set so he didn't spend that /:
^^^ fixed all your grammar and spelling for you too.
Actually they are. A brand new set in his size and offset with our size hub machined since they do that for you is a $1024.00 a wheel on avg from what I found. So yes they are 4k for the wheels alone thank you... 3500 actually since they give you a discount at checkout out
http://unleashedwheels.com/catalog/product/view/id/11
turbo test (08-14-2013)
 Old 08-14-2013, 08:09 AM   #11
turbo test's Avatar
Posts: 798   (View Stats)
turbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the world
Groaned at 9 Times in 5 Posts
owned
Sent from my EVO using Tapatalk 2
2010 Velocity Red MS3-Eibach PRO-KIT-EVO X Rims-SU RMM-SU solid shifter bushings-CP-e HPFP-CP-e tip-CP-e cai-CP-e hks ssqv bov kit-ddm slim hid kit 35w-5000k-JBR Heavy Shift Knob-JBR RSB-AQ Motorsports catted downpipe-Magnaflow full 3in CBE- SPC camber arms (Stratified tuning) 91/e85 tuned
turbo test is offline   Reply With Quote
The Following User Says Thank You to turbo test For This Useful Post:
LumberJack (08-14-2013)
 Old 08-14-2013, 09:12 AM   #12
trixms3's Avatar
Okay, yea. I chopped that up pretty well. And i guess i was checking out some fake varrstoens because i was looking at what i believed were these same wheels for right at 1k for set. Or i didn't see the "per wheel".
Oh wait here's that wheel for under 1k for the set. Tad different specs but nothing different to make up 2500. So, therefore im right as well as you.
 Old 08-14-2013, 09:26 AM   #13
helmetface's Avatar
Groans: 219
4k in wheels with shit shoes and shit suspension.
PRIORITIES!
brandonnicholson (08-14-2013)
 Old 08-14-2013, 09:30 AM   #14
LumberJack's Avatar
Groans: 57
Either that's per wheel like I just said and they would still total 3800 for 4 or those are FAKE. We are only discussing REAL Varrstoens here
Last edited by LumberJack; 08-14-2013 at 09:30 AM. Reason: MSF Database - Automerged Doublepost
 Old 08-14-2013, 09:40 AM   #15
trixms3's Avatar
The ebay listing is for 4 Wheels. And are the same wheels. Te37 knock offs.
 Old 08-14-2013, 09:47 AM   #16
smr87's Avatar
Posts: 1,288   (View Stats)
smr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the world
Groaned at 6 Times in 4 Posts
This just blew my mind. I didn't realize the cheap ones were fake considering it is almost a direct knock off of a te37.
Speaking of which am I the only one who would only have volk, bbs, fikse, kinesis, ssr or some other select few names on my wheels if I am dropping that kind of change?
That being said I abide by the rule that your wheels shouldn't cost more than 10% of the sticker price on the car...to each their own though.
Edit: I am right, all the sites that sell them sell them as sets of 4, read the text, that is total price for a set not a per wheel price. Cheap knockoffs are still cheap.
1999 Cosmos M3
turning bits and more better suck, squish, bang, and blow
FREEK'D 2012 Liquid Silver Genpu-sold
We were young, and we were fearless and, after all, nobody had ever told us young engineers that we couldn't successfully land humans on another planet. So we did it.
smr87 is offline   Reply With Quote
 Old 08-14-2013, 09:50 AM   #17
bstover17's Avatar
Groans: 228
Varrstoen wheels are like 1k for a complete set. I'm pretty sure what you added to cart is 4 sets of wheels....
2010 MAZDASPEED 3
The Following User Says Thank You to bstover17 For This Useful Post:
trixms3 (08-14-2013)
 Old 08-14-2013, 09:55 AM   #18
trixms3's Avatar
Fucking thank you!!!!
VARRESTOEN IS A FAKE WHEEL. Lol
Now back to the op didn't spend 4k on wheels.
 Old 08-14-2013, 10:24 AM   #19
I would put some BBS but I might just end up curbing them so yeah. no.. besides, I don't see the point putting a set of 4k wheels on a 20k car.
it's funny how this thread turned into a wheel pricing debate.
I made this thread to thank the 2 people that helped me in the forum by providing information and the vendor that provided support, so in the future, people who may have questions can talk to those who was able to help me greatly.
and then you got all these fegs acting high and mighty, unless you're doing track every weekend, f.y.i. at end of the day, you're driving the same car brand as the other guy.
I paid 7 bills for my set. guy I bought it from owned a shop that was moving from AZ to CA so he got rid most of his inventory.
once again, thanks to everyone who helped me through the install.
and for everyone who has nothing better to do, don't break your keyboard.
 Old 08-14-2013, 10:28 AM   #20
trixms3's Avatar
Lol the things that happen when one person is wrong and someone corrects them. Then they feel a need for defense because they are clueless on some matters.
Enjoy your coils man you won't be disappointed.
 Old 08-14-2013, 10:31 AM   #21
Bilstein and B8's are definitely stiffer ride wise
but I get a feel for the road on the ST's better.
 Old 08-14-2013, 10:46 AM   #22
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
WTF? How can a spring / shock combo be stiffer than co's?
 Old 08-14-2013, 10:53 AM   #23
oops, sorry. I don't have my Coils on the stiffest setting. that's why. 'ride wise'
lol
 Old 08-14-2013, 10:57 AM   #24
SLOWHATCH's Avatar
Groans: 274
lol
Thanks for clearing that up. I asked because this is not the first time I have read comments eluding to these not being as stiff as I had imagined. I.E people running around at full stiff settings for DD.
 Old 08-14-2013, 11:02 AM   #25
lol. I think its because the people that have their setting set to stiffest for DD have their ride height at its lowest.
my ride height is just set to remove the gap. the rears are rubbing because of my off set and I'm new this is my first ever coil over set up and I didn't realize how to adjust the rears until I put on the wheels.
I'm having my rear fenders rolled tomorrow and then ill adjust it to the stiffest setting. but with what it is now, the car feels glued to the road.
 Old 08-14-2013, 11:13 AM   #26
turbo test's Avatar
I retract my previous statement, carry on
 Old 08-14-2013, 11:53 AM   #27
trixms3's Avatar
 Old 10-25-2013, 01:10 PM   #28
Drumea88's Avatar
Posts: 12   (View Stats)
Drumea88 is an unknown quantity at this point
How is the handling on the sonic tuning coils?
Drumea88 is offline   Reply With Quote
 Old 10-25-2013, 02:03 PM   #29
killer-ms3's Avatar
Posts: 1,187   (View Stats)
killer-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the world
Groans: 32
Hey Hey Hey it might be a rep, but they're still sexy.
And on that note, I payed 900 shipped for mine
Nator FL, bitch
GTX3071 EWG w/ Supporting Mods and some Mef
Tuned by THE FREEK
killer-ms3 is offline   Reply With Quote
The Following User Says Thank You to killer-ms3 For This Useful Post:
Sterling (12-10-2013)
 Old 12-19-2013, 02:47 AM   #30
itzjustme407's Avatar
Posts: 110   (View Stats)
itzjustme407 is infamous around these partsitzjustme407 is infamous around these partsitzjustme407 is infamous around these partsitzjustme407 is infamous around these partsitzjustme407 is infamous around these parts
How are those coils holding up at that height? Mind giving a review?
itzjustme407 is offline   Reply With Quote
 Old 12-23-2013, 02:36 PM   #31
I don't know much review I can give but if you want an idea on how it feels to drive it here are some vague general info lol:
when the ride stiffness is set to medium, (i go by counting the clicks, i forgot how much) it's comfortable and feels stiffer than stock but you don't get the bouncey feeling. I've been on it that settings for 3k and it was great.
Then i switch to the stiffest setting, you feel everything on the road, the slightest bump but the car feels like its glued to the ground even on the tightest turns. I don't do track days so I can't really give any kind of good review but I like it so far, the lady doesn't like the stiffest setting though.
I would recommend it for sure if you're doing coils on a budget for daily drive and the 'occasional' track day.
ISC or SONIC coils?!?!?! Thaad MazdaSpeed 3/6 - Suspension & Brakes 31 07-23-2013 03:59 PM
New Sonic Tuning Coils: from GB V2 narezzaspeed3 Sonic Tuning 17 06-24-2013 05:47 PM
New Sonic Tuning ST8s... NinjaT1985 2010 MS3 - Wheels & Tires 19 01-08-2012 10:22 AM
Page generated in 0.49428 seconds with 33 queries
