 Old 05-03-2019, 11:29 AM   #1
Dark_Signal's Avatar
Posts: 245   (View Stats)
Dark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the world
Default ST X Coilovers for the Mazdaspeed 3
Does anyone have any experience with the ST X Coilovers specific to the MS3? (Part Number: 13275019) https://www.tirerack.com/suspension/...2&autoModClar=
I've only seen old reviews for the ST Coilovers that were really meant for the normal MZ3. Turns out the springs were too soft up front for the MS3 due to the heavier front end the MS3 has over the MZ3. Also that at max height they sit a bit low in the back.
I'm curious about the handling characteristics. Are these really as good as the KW V1's or are these a bit more generic? Say more akin to Ksports or BC Coilovers and the like.
Dark_Signal is offline   Reply With Quote
Mazdaspeed 3 Coilovers prspect MazdaSpeed 3/6 - Suspension & Brakes 23 03-18-2009 09:35 PM
Page generated in 0.21625 seconds with 20 queries
