 Old 01-09-2019, 07:35 PM   #1
tripppleP's Avatar
Posts: 97   (View Stats)
Default Stock rear coil spring questions
Can you guys point me in the right direction. I need to replace the rear coil spring in my 2010 Speed3. I am going to switch out the rear with stock springs but wanted to make sure I get the right set. I plan to replace both the left and right rear. I also will replace the spring seat too.
The reason I am not doing a performance spring set is this is my first time working on my car and I don't want to fuss with lowering springs...which may lead to swapping suspension in the long run...and more cost at the moment.
The spring I think I need is part: Moog 81693.
I have tow links below and they are $30 difference and I don't know why when they are the same item.
https://www.moog-suspension-parts.com/moog-81693
$81
https://www.rockauto.com/en/cart/
$50
The spring seat is part: BP4K28012A
http://www.mazda-parts.com/2010-mazd...4K28012A-item/
Are the above links/items the rear coil spring for the Speed3?
Thanks for any advice and help.
« Brake help needed! | - »
How To: Ignition coil spring stretch mod cld12pk2go MazdaSpeed 3 - How-To's 56 03-21-2016 02:58 AM
Question about different coil spring designs... iammike 2010 MS3 - Suspension & Brakes 8 07-10-2014 11:12 AM
Rear coil spring spacers JgamB 2010 MS3 - Suspension & Brakes 2 11-14-2013 11:45 AM
Coil Spring Spacers dukebrown MazdaSpeed 3/6 - Suspension & Brakes 12 04-09-2011 11:05 PM
Donut Style Coil Spring Spacer booya620 Drag Racing 2 02-07-2011 08:00 PM
Page generated in 0.42082 seconds with 27 queries
