 Old 01-07-2019, 08:00 AM   #1
mhebert2001's Avatar
Posts: 491   (View Stats)
mhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond repute
Groaned at 6 Times in 4 Posts
Default Stripped hardline nut while installing brakes
I was working on installing my Stoptech brakes this weekend, and I completely rounded the nut that is attached to the front passenger hard line.
PB Blaster, heat, and sadly a set of vice grips, finally loosened it.
I believe the threads to be ok, however the hex nut is f'd.
The only way I can see to fix that, would be a new hard line or to have the tools and know how to cut and install a new flange nut, neither of which I have.
Is it ok to just leave it, install the new SS lines, and snug it up with channel locks?
I dont think you need to apply a lot of torque on the fitting, but I want to make sure it is 100% reliable.
Thanks!
2012 MAZDASPEED3 BLACK MICA (Stage 1, Cobb AP, Autotechs, Cobb SF, TIP & Airbox)
Coming soon: 2nd etune
2013 MAZDASPEED3 Liquid Silver (Stock and not allowed to touch!)
mhebert2001 is offline   Reply With Quote
 Old 01-07-2019, 08:47 AM   #2
08mzr's Avatar
Posts: 641   (View Stats)
08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world
I dont think anyone would say its ok, but I have done it before without any issues. As long as you can get it tight enough to seal I see no difference between using a wrench to tighten it or using vice grips to tighten it.
2008 Metro Gray Mica Speed 3-SOLD
Corksport SRI
Corksport TIP
JBR 80 duro RMM
Cobb AP v3
Autotech internals
CX Racing FMIC
SPC rear camber arms
Hawk HPS pads front and rear
FREEKTUNE OTS+
1998 Civic - SOLD
2011 Speed3 200k+ miles Stock -Daily
08mzr is offline   Reply With Quote
 Old 01-07-2019, 08:59 AM   #3
Thanks, that helps. Its not a pretty solution, but I would think I can get it tight enough to not leak, and as long as the vice grips didnt crack or warp anything, I guess its ok.
At this point, I would pay someone to finish it, and replace that line, but I cant even drive it somewhere without finishing the front brake installation.
 Old 01-07-2019, 09:28 AM   #4
doublegmoto's Avatar
Posts: 23   (View Stats)
doublegmoto will become famous soon enough
100% correct if you can tighten it enough so it does not leak under pressure. Your good. Graduated Denver auto and diesel in 1988 the reason I write this because of (some) of the idiotic crap I hear.
Sent from my LGMS631 using Tapatalk
doublegmoto is offline   Reply With Quote
 Old 01-07-2019, 10:07 AM   #5
Good to hear, thanks man!
Originally Posted by SaveMelMac View Post
Where you using flare nut wrenches? You could find a local hydraulic shop and many of them could repair and reflare the end for you. But you would have to get the whole line removed.
I was. It was even brand new, and this is the 1st time the nut had been turned. It was really my fault.
Last edited by mhebert2001; 01-07-2019 at 10:07 AM. Reason: MSF Database - Automerged Doublepost
 Old 01-07-2019, 09:27 AM   #6
SaveMelMac's Avatar
Posts: 485   (View Stats)
Stripped Bracket bolt when changing Brakes PoMan MazdaSpeed 3/6 - Suspension & Brakes 6 11-18-2012 05:27 PM
Page generated in 0.26563 seconds with 24 queries
