 Old 11-29-2011, 04:18 PM   #1
FY"IED"N
dMuze's Avatar
Posts: 506   (View Stats)
dMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the world
Default Strut tower braces or f/r sway bars?
Looking for my next mod and haven't seen much talk about strut tower braces. Prices are the same, and it seems adding a tower brace would yeild more result then upgrading stock sway bars... any thoughts?
Sent from my SPH-D700 using Tapatalk
2010 Silver MS3 Tech Pkg 307whp, 340ft/lbs tq
CS SRI/TIP, UR Turbo Back, UR FMIC, TS Dual Port BOV, DENSO ITV22 Plugs, AP EcuTek ProTune, DO STG 2 Prog Kit 100% Meth, JBR SSP w/ Bushings, CS Springs, JBR camber arms, Koni yellows, 80D PMM/88D RMM/88D TMM, MD OCC, CP-E HPFP, Ford Motorcraft tranny fluid, DashDaq, Kenwood 12"sub, Kicker 400w amp, DDM 35W 6k lows/3k fogs, CS LED kit, 20% tint.
dMuze is offline   Reply With Quote
 Old 11-29-2011, 05:04 PM   #2
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Front Strut Tower Braces aren't worth much on an MS3 if you ask me. The strut towers are already pretty much butted against the firewall member and there are already triangulating braces on them.
Get a rear sway bar first and see how you like the new setup. Then, if you decide you need a front, then get one. You probably won't.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
The Following 6 Users Say Thank You to Nliiitend1 For This Useful Post:
adlpb (11-29-2011), dMuze (11-29-2011), kritz (12-14-2011), MS3kid08 (11-29-2011), silvapain (11-29-2011), stang9779 (12-14-2011)
 Old 12-14-2011, 06:56 PM   #3
stang9779's Avatar
Posts: 1,066   (View Stats)
stang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the world
Get the JBR RSB. I really noticed a difference in handling after I installed it.
2010 MS3 Velocity Red w/ Tech Package
Custom FreekTune e85 mix
GTX3071r - Cobb AP - CP-e Big TIP, XcelXL - Hallman PRO RX MBC - Steedspeed exhaust manifold - CS TMIC, CBE, Air Box, Interior LED kit, Mud Flaps - JBR EGR Block off, 88D RMM, 80D PMM, 88D TMM, HSK, RSB, SSP - KMD V2.1 internals - CNT DP - Forge BPV V2 - MD OCC - TWM FSS - NGK LTR7IX-11 - Konig Kilograms 18x8 +45 on 245/40zr18 Hankook V12's - H&R sport springs - SPC RC kit - Aeroforces Dual gauges - DDM tunning HID 35w 6000k - 20% black window tint, clear bra
Future Mods DO stage 2 WMI, Intake manifold of some type.
stang9779 is offline   Reply With Quote
The Following User Says Thank You to stang9779 For This Useful Post:
kritz (12-14-2011)
 Old 12-14-2011, 10:10 PM   #4
genrec's Avatar
Posts: 83   (View Stats)
genrec is a glorious beacon of lightgenrec is a glorious beacon of lightgenrec is a glorious beacon of lightgenrec is a glorious beacon of lightgenrec is a glorious beacon of lightgenrec is a glorious beacon of light
This ^^
genrec is offline   Reply With Quote
The Following User Says Thank You to genrec For This Useful Post:
kritz (12-14-2011)
 Old 12-14-2011, 10:26 PM   #5
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
JBR RSB + CS FSB=FTW
Nator is what it does.
Matsu Strut Tower Bar review 9900rpm 2010 MS3 - Suspension & Brakes 18 03-29-2011 04:03 PM
Strut Tower Bar ehuff MazdaSpeed 3/6 - Suspension & Brakes 7 06-29-2010 03:58 AM
Strut tower bar doubleflusher MazdaSpeed 3/6 - Suspension & Brakes 15 03-14-2009 07:13 AM
what kinda strut tower brace is this??? udontknowjack Custom Performance Engineering (cp-e.com) 18 10-18-2008 12:54 AM
Page generated in 0.25824 seconds with 24 queries
