 Old 06-19-2011, 09:38 PM   #1
I_Heart_Haters's Avatar
Posts: 1,446   (View Stats)
I_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the worldI_Heart_Haters is the leader of the world
Groaned at 63 Times in 39 Posts
Default What coils should I get?
Im new to this forum and I'm in the market for a Gen2 Speed3. I am looking for coils to get for this car and not sure what coils are recommended. Not going autox or tracking, just want to be able to lower it a bit more than springs. I did SEARCH and couldnt really find anything to help answer this question...any suggestions?
I_Heart_Haters is offline   Reply With Quote
 Old 06-19-2011, 09:44 PM   #2
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
suggestion...
donate..
then more answers to follow
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 06-19-2011, 09:50 PM   #3
yah yah yah, donation will happen...now? i think so.
done
Last edited by I_Heart_Haters; 06-19-2011 at 09:50 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to I_Heart_Haters For This Useful Post:
taf0422 (06-20-2011)
 Old 06-19-2011, 11:00 PM   #4
skeurton's Avatar
Posts: 745   (View Stats)
skeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the world
Searching brings up TONS of threads on coilovers!!! These are only a few...
http://www.mazdaspeedforum.org/forum/foru...essions-64356/
Fortune Auto Coilovers?
Coil over Options?
BC Racing Coilovers 2010 MS3 Review
Coilover Opinions BC vs KW V2
BC Coilovers
2011 MAZDASPEED 3
BNR: 352 hp / 342 ft-lbs
K04: 296 hp / 343 ft-lbs
BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges
skeurton is offline   Reply With Quote
 Old 06-20-2011, 02:07 AM   #5
rgz
rgz's Avatar
Posts: 397   (View Stats)
rgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the world
^^close thread
rgz is offline   Reply With Quote
What coils should I get? PapaSmurf 2010 MS3 - Suspension & Brakes 28 06-17-2011 08:53 AM
KW Variant 1 Coils vs. H&R Coils surfwagon MazdaSpeed 3/6 - Suspension & Brakes 11 04-10-2011 10:18 AM
affordable coils for ms3? phillyb MazdaSpeed 3/6 - Suspension & Brakes 51 05-27-2010 03:11 PM
How often to coils need adjustment KayWhy MazdaSpeed 3/6 - Suspension & Brakes 4 09-28-2009 06:17 AM
Page generated in 0.26802 seconds with 23 queries
