> 2010 MS3 - ECU Computer Tuning
 Old 04-01-2011, 06:59 AM   #1
jallways's Avatar
Posts: 41   (View Stats)
jallways is just really nicejallways is just really nicejallways is just really nicejallways is just really nicejallways is just really nice
Default CEL codes p0421 and u0100
Anyone throw both those codes after fuel pump internals install?
jallways is offline   Reply With Quote
 Old 04-01-2011, 07:27 AM   #2
atvfreek's Avatar
Posts: 7,787   (View Stats)
No, but I believe there is a firmare update for the ap that takes care of the u0100 code. And you can get rid of the p0421 code with ATR
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 2 Users Say Thank You to atvfreek For This Useful Post:
jallways (04-01-2011), Pat Attack96 (01-19-2017)
 Old 04-01-2011, 09:20 AM   #3
VT2WA's Avatar
Posts: 82   (View Stats)
VT2WA has a reputation beyond reputeVT2WA has a reputation beyond reputeVT2WA has a reputation beyond reputeVT2WA has a reputation beyond reputeVT2WA has a reputation beyond reputeVT2WA has a reputation beyond reputeVT2WA has a reputation beyond reputeVT2WA has a reputation beyond reputeVT2WA has a reputation beyond reputeVT2WA has a reputation beyond reputeVT2WA has a reputation beyond repute
Whose internals did you get?
Current Cars:
2014 Ford Focus ST, Performance Blue
1948 Lotus 7 with a turbo'd '99 Miata Motor (200+hp and weighs 1400 lbs)
1992 Mazda Miata, Racing Red
Old Cars:
1992 Mazda Kliata, Miata with V6 KL-DE Engine, Blue/Black
2011 Mazdaspeed3, Celestial Blue Mica
2008 Mazdaspeed3, Black Mica
2006 Mazda3, Strato Blue
VT2WA is offline   Reply With Quote
The Following User Says Thank You to VT2WA For This Useful Post:
 Old 04-01-2011, 10:18 AM   #4
jallways's Avatar
Autotech
The Following User Says Thank You to jallways For This Useful Post:
 Old 03-28-2012, 04:05 PM   #5
osmar_21's Avatar
Posts: 27   (View Stats)
osmar_21 is a splendid one to beholdosmar_21 is a splendid one to beholdosmar_21 is a splendid one to beholdosmar_21 is a splendid one to beholdosmar_21 is a splendid one to beholdosmar_21 is a splendid one to beholdosmar_21 is a splendid one to behold
got the same problem. car wont start.
osmar_21 is offline   Reply With Quote
The Following User Says Thank You to osmar_21 For This Useful Post:
 Old 04-12-2012, 12:34 PM   #6
Shadow's Avatar
Posts: 430   (View Stats)
Shadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the world
are you running a catless or high flow cat? p0421 is cat failure. the u0100 code should be the update like was said previously, if your running a catless dp or high flow catted dp it will throw a 421, just use atr, turn off monitoring 420/421. It should be done already if your running stage 2 unless your running ancient maps.
Shadow is offline   Reply With Quote
The Following User Says Thank You to Shadow For This Useful Post:
 Old 01-19-2017, 05:58 PM   #7
Pat Attack96's Avatar
Posts: 3   (View Stats)
Pat Attack96 is an unknown quantity at this point
Neutral  :  -1 score
Other than buying an AP....how else can you get rid of the P0421 code??? I have heard rumors of dummy sensors that will do that? I will have a code reader that can clear codes but if the root cause isn't fixed the check engine light will come on in a matter of time...
Thanks!
Pat Attack96 is offline   Reply With Quote
 Old 11-12-2019, 06:07 PM   #8
zumanback's Avatar
Posts: 60   (View Stats)
zumanback is just really nicezumanback is just really nicezumanback is just really nicezumanback is just really nicezumanback is just really nice
Groaned at 9 Times in 4 Posts
Bumpity bump. Have read all the threads on this but still can't determine what may be causing the issue. I do not have an exhaust leak BTW. I would hate to buy a new 02 sensor and then still have the code showing up (which i have read over and over happens).
Suggestions?
zumanback is offline   Reply With Quote
 Old 11-12-2019, 10:27 PM   #9
Posts: 2,826   (View Stats)
Suggestions: Yes. List your mods (all of them that are power related), especially on the exhaust side, describe when the code started, and what you’ve already done to try to resolve the issue.
You are asking us to be mind readers with nothing to go on but the P0421.
 Old 11-13-2019, 07:29 AM   #10
Posts: 2,233   (View Stats)
o2 sensors are wearing out parts that need replacement one day or another...
if you have the main wideband one, it cannot be fooled with a bung extension because it drive the whole system afr...And no it isn't something often happening, it will happen often if you keep erasing the code without repairing it but once repaired it won't come back.
For the second probe, it is mostly there to watch if you remove the cat, you need to fool it in some way by either cancel the trigger with a cobb ap or try the bung extension that didn't worked for my 6 and cobb DP...i dont remember which exact code i was getting but it was related only to the second probe.
U1900 and U0100 codes after fuel economy AP tune 626 MazdaSpeed 3/6 - ECU Computer Tuning 6 03-17-2011 06:31 PM
P0421 speedms6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 03-06-2011 06:04 PM
P0421 CEL RichB MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 12-30-2009 07:51 AM
Help! CEL P0421!! Decepticon MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 05-04-2009 06:28 AM
How to get rid of a P0421 CEL...? AutoXRacer MazdaSpeed 3/6 - ECU Computer Tuning 10 04-15-2008 05:45 AM
Page generated in 0.30318 seconds with 28 queries
