> 2010 MS3 - ECU Computer Tuning
 Old 12-15-2012, 09:53 PM   #1
Fusion_MS3's Avatar
Posts: 72   (View Stats)
Fusion_MS3 is a glorious beacon of lightFusion_MS3 is a glorious beacon of lightFusion_MS3 is a glorious beacon of lightFusion_MS3 is a glorious beacon of lightFusion_MS3 is a glorious beacon of light
Default cobb ap: is safe tune quicker than stage 0 tune?
they feel pretty close to me, am i trippin?
Mods:cs sri/tip
i did two 3rd gear pulls w/ stage 0
and two 3rd gear pulls w/safe tune for cs 91
i might have let off a little early from redline on a couple of the pulls.
Fusion_MS3 is offline   Reply With Quote
 Old 12-15-2012, 09:59 PM   #2
Dmurray06's Avatar
Posts: 3,279   (View Stats)
Groans: 189
mxlplx71 (12-15-2012)
 Old 12-15-2012, 10:15 PM   #3
Hush's Avatar
Posts: 520   (View Stats)
Hush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the world
Groans: 156
Why aren't you using Stage 1 cs sri/tip 91?
Just experimenting?
Hush is offline   Reply With Quote
 Old 12-15-2012, 10:40 PM   #4
Fusion_MS3's Avatar
Just experimenting?
I kinda don't want to try until hpfp.
4th gear is better to log, no 93 or e85 around?
what is up w your afr?
Negative. I'm in Cali highest pump gas is 91.
Save the whales!
Last edited by Fusion_MS3; 12-15-2012 at 10:40 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-15-2012, 10:25 PM   #5
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
Last edited by mxlplx71; 12-15-2012 at 10:25 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-15-2012, 10:32 PM   #6
Hush's Avatar
Groans: 156
afr is stock tune...rich rich rich.
 Old 12-16-2012, 12:55 AM   #7
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Stock MAP AFRs are indeed rich but his dip into mid 9's while they should normally stay in the low 10's.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 12-16-2012, 01:05 AM   #8
Hush's Avatar
Groans: 156
Boost dumps too - related? I was thinking this was a Stage 0 thing.
 Old 12-15-2012, 10:47 PM   #9
Pseud0logik's Avatar
Posts: 2,042   (View Stats)
Pseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the world
Groaned at 34 Times in 31 Posts
Plug all your logs into vdyno and see how they compare.
I'd do it for you but I don't have it installed on my work comp and I don't like you enough to go through all that trouble, sorry.
Pseud0logik is offline   Reply With Quote
The Following User Says Thank You to Pseud0logik For This Useful Post:
 Old 12-15-2012, 11:35 PM   #10
Hush's Avatar
Groans: 156
I'll be your huckleberry!
I got the two that looked decent...put your weight at 180#. I think one of your logs had a shift in it, so I did not include. Someone please let me know if I did this wrong. EDIT - FIXED - CORRECTED VD - THANKS @Pseud)logik!
Comparing Safe and 0:
I see now about the afr's on stage 0 going rich...You would think opposite would happen with new intake and more air comming in, but it dives with the boost.
The Following 2 Users Say Thank You to Hush For This Useful Post:
Fusion_MS3 (12-16-2012), Pseud0logik (12-16-2012)
 Old 12-16-2012, 12:21 AM   #11
If you use a 1.01 correction factor and set smoothing to 3 the numbers will be more accurate, but it doesn't look like the logs were done very well in the first place.
@Fusion_MS3; log from 2500-6500 RPM in the future. But I can say right now that the safe mode map is better than stage 0. There's no harm in trying stage 1 as long as you watch your fuel pressure like a hawk for dips below 1600 at WOT.
Hush (12-16-2012)
 Old 12-16-2012, 02:27 AM   #12
Fusion_MS3's Avatar
Thanks, duly noted... I'm still getting the hang of logging. If I end up running stage 1, I'll post some logs as well.
 Old 12-16-2012, 02:19 AM   #13
Fusion_MS3's Avatar
Thanks man!
The Following User Says Thank You to Fusion_MS3 For This Useful Post:
Hush (12-16-2012)
 Old 12-16-2012, 01:08 AM   #14
Stage 0 is the shitty stock tune. Boost and AFR drop like a stone over 5k. No reason to bother running it.
 Old 12-16-2012, 01:13 AM   #15
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
The key factor that seperates the "safe tune" from others is that peak boost targets are shifted farther up the RPM range taking some load off of the HPFP where it has its disadvantage.
Edit: To answer your question, you will be slower on the safe map..
www.tunedbynishan.com
The Following 5 Users Say Thank You to ms3blackmica For This Useful Post:
CWP_MS3 (12-18-2012), Fusion_MS3 (12-16-2012), Hush (12-16-2012), outshined (12-16-2012), Pseud0logik (12-16-2012)
cobb AP stage 1 tune question CornBread 2010 MS3 - ECU Computer Tuning 5 03-23-2012 04:36 PM
What are the requirements for Cobb ap stage 1 tune? caesura 2010 MS3 - ECU Computer Tuning 3 01-23-2012 08:32 PM
K&N Typhoon + Turbo Inlet Pipe = safe with no tune? ChicagoMike 2010 MS3 - Engine, Transmission & Driveline 21 08-05-2011 11:50 AM
Is there a safe Tune? Balzy88 MazdaSpeed 3/6 - ECU Computer Tuning 38 07-05-2010 09:23 PM
is this mild tune prob safe? gsrtype1 MazdaSpeed 3/6 - ECU Computer Tuning 20 07-11-2008 08:47 AM
Page generated in 0.36255 seconds with 27 queries
