> 2010 MS3 - ECU Computer Tuning
 Old 05-10-2018, 01:02 PM   #1
Theredmazdaguy's Avatar
Posts: 18   (View Stats)
Theredmazdaguy has a little shameless behaviour in the past
Default Knock when shifting?
This is the one thing i couldn't find much on in my searches. I'm looking for more so specifics. Is that literally still considered partial knock and nothing to worry about, or is it a spark plug, clutch, transmission thing. Is there a deeper issue i shouldn't ignore type thing.
It's only like .1 - .5 at the most but, still trying to keep this bitch as healthy as possible, usually always 1st to 2nd, 3rd and forth maybe sometimes
Theredmazdaguy is offline   Reply With Quote
 Old 05-10-2018, 03:00 PM   #2
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
That's nothing to worry about. However, if you're OCD like me, then start checking motor mounts (are you upgraded?) and for anything loose in the engine bay.
 Old 05-10-2018, 03:34 PM   #3
Thanks man! Yeah idk I'm OCD for knock retard that's for sure. I guess I need to relax a little. I never hear any actual knock and I read when you see 6pts while cruising its because ECU pulls timing for gas milage. Another thing I over reacted about. My paranoia stems from not having the money to afford a blown motor haha... No upgrades just a Cobb intake. So when I do my oil change just make sure the motor mounts haven't been knocked loose?
 Old 05-11-2018, 02:55 PM   #4
WAMBUSHHHH!'s Avatar
Posts: 1,599   (View Stats)
The only time you should be OCD about knock is at WOT. You're going to see a wide range of knock at part throttle. For instance, I would see knock as high as 7+ at part throttle and during shifting regularly. Even at WOT, .1-.5 isn't worth looking into. Knock can be caused by more than just a lose motor mount or something. Gas quality is often the culprit (if knock starts to appear out of nowhere) hence why you'll see some tuners/members ask if you can throw some corn into the tank. Any knock over 2 at WOT typically warrants some attention.
Thor Hammer (05-14-2018)
Plug and play knock sensor listening harness. Is it really knock? Turbo_Steve MazdaSpeed 3/6 - ECU Computer Tuning 37 10-07-2019 03:50 PM
Knock Knock Knock..Whose There? (<===total noob) thomas_cory2000 MazdaSpeed 3/6 - ECU Computer Tuning 158 06-12-2014 11:57 PM
Engine knock low speeds/low gear - false knock? Jra2011speed3 2010 MS3 - ECU Computer Tuning 5 12-13-2013 05:17 PM
Knock Retard with Flat Foot Shifting JFord Gen2 MS3 General Discussion 9 05-15-2013 01:37 PM
Knock while flat foot shifting with AP. dsmluck MazdaSpeed 3/6 - ECU Computer Tuning 6 04-19-2011 08:35 PM
Page generated in 0.24240 seconds with 22 queries
