> 2010 MS3 - ECU Computer Tuning
  • 1 Post By WillyH
 Old 04-23-2012, 08:57 AM   #1
Bubba Ho-Tep's Avatar
Posts: 224   (View Stats)
Bubba Ho-Tep is the leader of the worldBubba Ho-Tep is the leader of the worldBubba Ho-Tep is the leader of the worldBubba Ho-Tep is the leader of the worldBubba Ho-Tep is the leader of the worldBubba Ho-Tep is the leader of the worldBubba Ho-Tep is the leader of the worldBubba Ho-Tep is the leader of the worldBubba Ho-Tep is the leader of the worldBubba Ho-Tep is the leader of the worldBubba Ho-Tep is the leader of the world
Default Not hitting Stage 2 boost targets (boost leak?)
Just upgraded my HPFP internals (autotech), Cobb DP, and went to Stage 2. After some logs I noticed I'm not hitting my 18.5psi boost target (stage 2 w/o tip). It may be a boost leak but I wanted to post some logs to see if anyone see's anything else that could be the cause.
If the logs check out ok and I go ahead and order a boost leak tester, where should it be attached. I've heard some people say right at the top of the TIP (right where the intake would connect)- other say right at the turbo compressor. If I do have to order (or make one) I want to make sure I have the right size as the turbo and opposite side of the tip are different sizes. Thanks in advance everyone!
PS All the logs were 4th gear pulls, at sea level, approximately 72 degrees out.
2012 Cadilac CTS-V coupe
2014 Corvette Stingray
Bubba Ho-Tep is offline   Reply With Quote
 Old 04-23-2012, 10:12 AM   #2
speed14's Avatar
Posts: 527   (View Stats)
speed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the world
This is with a Stage 2 OTS map?
I suspect you're hitting your load limits, which is the reason you're not seeing 18psi. You can see your throttle plate closing to stay under the requested load.
You can learn how to raise the load limits in ATR to reach desired boost, or have one of the e-tune guys do it for you. I don't think you have a boost leak.
-good luck
2010 Mazdaspeed 3 | Black Mica
COBB AP V3| HTP 3" Intake | CP-E TMIC | UR Turbo Back Exhuast | GS 3-Port EBCS | DO Meth Injection | Autotech Internals | Denso ITV22 | GFB Respons BPV | DDM 6000k lows | 3000k fogs | 18x8 TSW Nurburgrings | 235/40/18 Toyo Proxes | H&R Springs
speed14 is offline   Reply With Quote
The Following User Says Thank You to speed14 For This Useful Post:
Bubba Ho-Tep (04-23-2012)
 Old 04-23-2012, 10:51 AM   #3
WillyH's Avatar
Posts: 316   (View Stats)
WillyH has a reputation beyond reputeWillyH has a reputation beyond reputeWillyH has a reputation beyond reputeWillyH has a reputation beyond reputeWillyH has a reputation beyond reputeWillyH has a reputation beyond reputeWillyH has a reputation beyond reputeWillyH has a reputation beyond reputeWillyH has a reputation beyond reputeWillyH has a reputation beyond reputeWillyH has a reputation beyond repute
Groaned at 53 Times in 27 Posts
Increase your WGDC 500 rpms before the area where you see your boost not reaching the boost targets. For amount of increase, try calculating a % based on the boost your getting vs target boost.
For example, @ 3000 rpm, lets say you're getting 14 psi, and you're targeting 18 psi, (1- (14/18))*100 = 22%, so increase WGDC by 22% @ 2500 rpms.
To be more conservative, you might want to try 1/2 that so 11% to see if your car is adjusting how it should.
If anyone disagrees with my method, please correct me.
IMPORTANT: You should also be going WOT @ ~ 2500 RPMS till 6500 rpms. Don't adjust your map until you post a proper WOT log or 2. If you adjust your map based on your current logs, there could be issues.
Current Mods: K&N SRI, UR downpipe, UR testpipe, Magnaflow CBE, 3.5" ETS TMIC, Cobb AP(Stage 2 91), cp-e 75 RMM, JBR HSK/SSP/bushings, RA mudflaps, EGR delete, Autotech HPFP Internals, DO stage 2 meth/water kit 50/50 mix,Ford Motorcraft Tranny Fluid
WillyH is offline   Reply With Quote
The Following 2 Users Say Thank You to WillyH For This Useful Post:
Bubba Ho-Tep (04-23-2012), fortressofcomfort (04-23-2012)
 Old 04-23-2012, 11:01 AM   #4
bigriver's Avatar
Posts: 1,123   (View Stats)
OP - was your DSC and AC turned off?
bigriver is offline   Reply With Quote
The Following User Says Thank You to bigriver For This Useful Post:
 Old 04-23-2012, 11:44 AM   #5
-good luck
Hey, thanks for taking a look and responding. I haven't gone the route of ATR software because I know so little about tuning, I don't want to tinker with something don't understand. That's what I get for being more of an A/V geek and not a gear-head.
I'm going to install a Cobb TIP soon and reflash with the Stage2 (w/ tip) as the Tip I had previously (from another company) wasn't molded properly. The fitment wasn't even close. I'll most definitely have to get an e-tune/protune. Btw, if I WERE to check for a boost leak should I be connecting the tester to the tip or the turbo itself? Also should I pressurize the system to around the same PSI the tune is asking for 18-19psi or more?
Thank you also, kindly, for taking the time to read the logs and respond. Unfortunately, yes, this was the Cobb OTS map for my car with appropriate mods, but I didn't request the ATR software yet. I have to check to make sure they have it for the Mac. Additionally I'll probably have to have a professional tune it because in all honestly most of what you said was greek to me. If I understand correctly you are talking about using the ATR software to increase the Wastegate Duty Cycle to allow the turbo to produce more boost?
My hats are off to you guys- this stuff is so perplexing to me. I absolutely love cars but apparently am quite a newb when it comes to anything more technical than basic hardware installs.
Yes and yes sir! Thanks!
 Old 04-23-2012, 11:53 AM   #6
WillyH's Avatar
This may help and save you some monies.
comprehensive tuning link list
"If I understand correctly you are talking about using the ATR software to increase the Wastegate Duty Cycle to allow the turbo to produce more boost?"
Yes, more boost to hit boost targets.
Bubba Ho-Tep likes this.
Last edited by WillyH; 04-23-2012 at 11:53 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to WillyH For This Useful Post:
 Old 04-23-2012, 11:56 AM   #7
bigriver's Avatar
I think the Cobb tuning notes say there is a boost target error factor of +/- 1.5 psi with the ots maps.
 Old 04-23-2012, 11:58 AM   #8
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
For starters, you should start logging @ 2800-3000 RPMs.
You're cheating yourself out of 1k RPMs for the turbo to spool.
Take some logs starting there and see where you're at. You may just have to make small tweaks to the WGDC tables or the TRL by gear tables.
 Old 04-23-2012, 03:27 PM   #9
speed14's Avatar
Just putting this out there, but if you're already hitting your load targets, there's no amount of WGDC you can add that will increase your boost.
The only thing that will happen if you continue to raise WGDC on this map is when you go WOT, you will see a spike above the requested load on spool-up since the ECU uses the WGDC tables and ramp limits as a starting point, then LEC will kick in as you exceed your load targets and cut WGDC to bring you back to meet your requested load targets.
If you wan't some proof, i looked at the 4th gear load targets for a stage 2 map and your logs are dead on with the requested loads.
In summary, all this means is your car does not need to hit 18psi to meet the load targets of a stage 2 OTS map. Time to get tuning!
The Following 3 Users Say Thank You to speed14 For This Useful Post:
Bubba Ho-Tep (04-23-2012), f-castrillo (04-25-2012), snailD (04-26-2012)
 Old 04-23-2012, 03:48 PM   #10
Lots and lots of reading to be done- thank you.
What does that mean exactly? That the boost targets simply may not be reached and require additional tuning (professional, or ATR) to correct it?
Btw, I requested my link for ATR and got an email only a few hours later. I went to install it but quickly realized it's ONLY for Windows. Their AP Manager software is PC or Mac compatible but not the ATR unfortunately.
I'll give that a shot- I just try to stay away from gunning it at lower RPMS, though, I can see from my logs I was pulling from over 4k each time.
So you are pretty sure it's not a leak- if it were I wouldn't be hitting my load targets? Thank you again!
 Old 04-24-2012, 07:45 PM   #11
WillyH's Avatar
He will most likely hit the boost targets if he starts his WOT run at 2500 rpms. His turbo didnt have enough time to spool up fully. With the new logs, if boost still isnt meetings targets, apply the method above by increasing WGDC.
For the record, on stage 1, I was able to go up to 21 psi. If he is boost tuning, and the load tables are zeroed out, i dont think load has anything to do with boost. Correct me if im wrong.
SofaKingAwesome (04-25-2012), TheProYodler (01-20-2016)
 Old 04-24-2012, 08:47 PM   #12
dantes5823's Avatar
Posts: 6,576   (View Stats)
dantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the world
Groaned at 52 Times in 48 Posts
Well if he cant get ATR loaded then he cant do shit to his map. And wont be able to get e-tuned either. First course of business would be to get ATR on some kind of computer and then you can start adjusting. Pretty sure he isnt leaking, wouldnt his wgdc start freaking out and wouldnt his boost go up and down? It def looks like he's hitting his load limit. Which is pretty simple to work around. I would do that first before working wgdc's. He'll end up raising them then doing the load then over shoot his target.
dantes5823 is offline   Reply With Quote
The Following 2 Users Say Thank You to dantes5823 For This Useful Post:
fortressofcomfort (04-26-2012), speed14 (04-25-2012)
 Old 04-25-2012, 10:19 AM   #13
speed14's Avatar
Not saying you're wrong, just providing my tuning experience..
Even having my load dynamics tables zeroed out, my car was still limited by the TRLxgear tables, as i believe is the same thing happening to the OP. really think it depends on the ECU as some cars do not have this problem.
Only after i raised the TRLxgear values to unachievable levels (ie 2.5 or higher) i was able to reach my boost targets and make adjustments by simply raising/loweing WGDC.
The Following 2 Users Say Thank You to speed14 For This Useful Post:
SofaKingAwesome (04-25-2012), WillyH (04-25-2012)
 Old 04-26-2012, 10:12 AM   #14
RIP: November 21, 2012
fortressofcomfort's Avatar
Posts: 862   (View Stats)
fortressofcomfort is the leader of the worldfortressofcomfort is the leader of the worldfortressofcomfort is the leader of the worldfortressofcomfort is the leader of the worldfortressofcomfort is the leader of the worldfortressofcomfort is the leader of the worldfortressofcomfort is the leader of the worldfortressofcomfort is the leader of the worldfortressofcomfort is the leader of the worldfortressofcomfort is the leader of the worldfortressofcomfort is the leader of the world
Groaned at 20 Times in 12 Posts
Make sure all the Throttle Requested Load - x gear tables (look in Throttle area of ATR)are set to something like 2.5 from 2500rpms and up
Also make sure your Load Error Comp table under Wastegate Dynamics is all zeros.
Like Dantes5823 said, if you don't have ATR then you are SOL now and down the road when you WILL want to get an etune. The OTS maps are merely starting points for REALLY getting your car running good (the difference, for me, from going from a stage 1 Cobb map to my own eTune with help from lots of great guys see sig was 12whp and 67lb/ft at the wheels; sounds funny but its easy to make torque increases on these cars and much harder to make peak hp increases because K04). Try running nearly 106mph in the 1/4 mile with an intake and OTS Stage 1 tune lol. Remember, Cobb has to take into account the worst running car possible when they release a map, otherwise lawsuit or at least dissatisfied customers and loss of sales.
I just realized in my sig that I've had help from SEVERAL different tuning teams. This is great. Not only do I benefit from the collective knowledge and argument between teams, but they can all learn something, maybe sometimes a little thing, because they are all tuning the same exact car. Win/Win.
2012 Black Mica MazdaSpeed3
Mods (in order of significance): Cobb AccessPort, Autotech CDFP upgrade (thanks Captain KR for your assisstance), Cobb SF SRI Intake, Ultimate Racing cat and resonator-less test pipe, Cobb Turbo Inlet Hose, Cobb Knob, Cobb 300g shifter weight
Tune: My own (based on the v210 and v231 Cobb OTS maps but ramped way up)
Street creds:
- Fastest known K04/93 MS3/driver with only an AP, CDFP upgrade, intake, and tune | 13.37@106.83mph on stock Dunlops (2.04 sec 60' time, full curb weight, 75*F ambient temp)
- Has gone an indicated 146mph on three occasions now.
Yes I will help you tune your K04/pump gas car; I have much less experience than the major players but I also charge you $0 and can turn you around quickly. 4 satisfied customers and counting...
fortressofcomfort is offline   Reply With Quote
 Old 04-26-2012, 08:12 PM   #15
I just wanted to take the time to thank you all for the input. I really appreciate it. I've decided to schedule a pro tune at at local Cobb certified pro-tune shop. I'm sure the legendary e-tuners are amazing but I'd rather do the pulls on a dyno. Doing the few hwy pulls I've done so far ranked really high on the pucker factor with the chance of an officer hiding around every corner.
I'll document my experience; fyi I'm using RT Tuning in Lansdale, PA. Probably purchase and have the new Cobb cat-back installed the same day.
The Following 2 Users Say Thank You to Bubba Ho-Tep For This Useful Post:
speed14 (04-26-2012), WillyH (04-27-2012)
 Old 04-26-2012, 08:25 PM   #16
COCKSTRONG
Groans: 890
Damn that's right in my old hood.
Sent from my PG86100 using Tapatalk 2
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f426/not-hitting-stage-2-boost-targets-boost-111639/
Not hitting targets This thread Refback 06-08-2013 12:17 AM
boost tuning, not hitting easy boost targets? Caldazar MazdaSpeed 3/6 - ECU Computer Tuning 11 05-18-2012 06:09 PM
not hitting boost targets exentix MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 04-13-2012 05:57 PM
Not hitting boost targets jvella22 Mazdaspeed3/6 General Discussion 2 04-08-2012 08:26 PM
OTS Map Not Hitting Boost Targets kahunab14 MazdaSpeed 3/6 - ECU Computer Tuning 53 02-18-2012 10:30 AM
Not hitting boost targets again (AP).. dsmluck MazdaSpeed 3/6 - ECU Computer Tuning 28 08-01-2011 05:35 PM
Page generated in 0.40175 seconds with 27 queries
