> 2010 MS3 - ECU Computer Tuning
Like Tree19Likes
 Old 06-19-2013, 06:34 AM   #41
bhamitgeek's Avatar
Posts: 362   (View Stats)
bhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the world
I t took me a day or two but I finally got used to the throttle. It definately takes some finesse to drive smoothly but rev matching is much easier. However if somebody else drives my car, its like they are driving a stick fir the first time, haha.
lol.. you know the resolution to that then???? DON"T LET OTHER FOLKS DRIVE IT. much safer that way.
bhamitgeek is offline   Reply With Quote
The Following User Says Thank You to bhamitgeek For This Useful Post:
snailD (06-19-2013)
 Old 06-19-2013, 07:37 AM   #42
moomooz12's Avatar
Posts: 378   (View Stats)
moomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the world
Wow, I've been toying around with the DBW/APP tables to get a good peppy feel to the speed. Snail did a great job with this and has saved me a ton of time.
This is exactly what I wanted.
Thanks!
Autotech HPFP Internals || Corksport TBE || cp-e FMIC || JBR 3.5" WP Intake || JBR TIG & Coolant bypass || JBR EGR delete || JBR OCC || JBR BSD || JBR 88 Trilogy Mounts|| JMF Direct Port Meth Inj IM || Stratified 2-Port EBCS || Turbosmart BOV || NGK colder plugs || Swift springs || JBR RSB
|| Snow Performance//Devils Own WMI
Self Tuned @ 330whp/352wtq 10/19/2013
moomooz12 is offline   Reply With Quote
The Following User Says Thank You to moomooz12 For This Useful Post:
snailD (06-19-2013)
 Old 06-19-2013, 10:43 AM   #43
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Well considering that a friend of mine totaled his Speed 3 and then bought an 09 Civic SI, I wanted to show him how much of a mistake it was, haha.
I seem to notice that a lot of people have a hard time driving speeds with short shift plates and 6 puck clutches.
@snailD; does this fix keep the car in closed loop?
bhamitgeek likes this.
Pickles Tune in progress
 Old 06-19-2013, 11:11 AM   #44
julienjj's Avatar
Posts: 292   (View Stats)
julienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the worldjulienjj is the leader of the world
Will try at next reflash.
Current money pits:
2006 MS6 Black mica
CP-E RMM|COBB AP|Test pipe|RX-8 oem wheels|Corksport SRI+TIP|Autotech CDFP|Michelin Pilot Super Sports 235/40ZR18|
|HKS SSQV|COBB Sift weight|Corksport mudflaps (Because rallycar)| JBR 70A Sidemounts|
2008 BMW 135i 6MT
M package|JB4 tune|255/35r18 Michelin PSS|BMW Performance exhaust|
julienjj is offline   Reply With Quote
 Old 06-19-2013, 03:02 PM   #45
snailD's Avatar
Posts: 3,039   (View Stats)
throttle doesn't have much to do with closed loop/open loop. so it all depends on what settings you have for the closed loop tables and how heavy your foot is
 Old 06-20-2013, 04:41 AM   #46
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
In short, no.
Not at all.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 06-20-2013, 05:26 AM   #47
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Woooo not for me haha
This really exacerbated the jerkiness accompanied with a PnP manifold on cold starts..like barely driveable.
Also, taking off from a stop I would have to ride thehclutch more than I'd like or end up launching haha. As soon as I would 'lightly' tap on the gas going into second I would feel like I'm already > 50% APP
I do like the rev matching but I'll definitely have to tweak mine as it's barely driveable at the moment.
Thanks for sharing, SnailD
 Old 06-20-2013, 05:27 AM   #48
himurax13's Avatar
Groans: 255
For the canyons and rev matching these tables feel great.
I would like a little more lag at the low end to slow acceleration while attempting to stay within the local speed limits, haha.
What would be the best way to adjust for this?
 Old 06-20-2013, 05:41 AM   #49
helmetface's Avatar
Groans: 219
By a "little more lag" I'm assuming you meaning a little more 'dead pedal' prior to it ramping up?
You just need a few extra values in the first few cells, like where it says 1.69 for the first gear- first populated cell: you'll need a lower value there and likely for the next few cells.
 Old 06-20-2013, 05:56 AM   #50
himurax13's Avatar
Groans: 255
Thanks, that I'd exactly what I mean. Woukd it be best to adjust each gear? I want to maintain the smoothness of shifting while slightly increasing the dead pedal.
 Old 06-20-2013, 06:32 AM   #51
helmetface's Avatar
Groans: 219
Personally, I would decrease the first few values by a little to decrease the rate of acceleration- just keep in mind gear 2 and above do not need as much of a 'dead area' in the first few fields as you're not riding the clutch as much ie starting off.
 Old 06-20-2013, 06:44 AM   #52
captain slow's Avatar
Posts: 5,559   (View Stats)
Groans: 398
Wow, first gear was nuts. I think the throttle is already touchy, this makes it more so. Any time I touched the pedal it was like it was floored. I reverted back to OTS, but I may try to make first gear a little more to my liking. The rest of the gears were mostly ok. You cant help but speed with those settings
 Old 06-20-2013, 10:40 AM   #53
Wicked's Avatar
Posts: 319   (View Stats)
Wicked is the leader of the worldWicked is the leader of the worldWicked is the leader of the worldWicked is the leader of the worldWicked is the leader of the worldWicked is the leader of the worldWicked is the leader of the worldWicked is the leader of the worldWicked is the leader of the worldWicked is the leader of the worldWicked is the leader of the world
Groaned at 3 Times in 1 Post
I don't get what all the fuss is about. I don't have any jerking or difficulty with the changes. Definitely love these settings. Reminds me of how it felt with the larger throttle body on my Cobalt SS, which if you drive with a heavy foot, it won't be fun haha
2010 Velocity Red Mica MAZDASPEED3 |E30 self tune|CorkSport SRI/TIP|CorkSport Ice Box|CorkSport TMIC|Forge v2|Autotech Internals|JBR 80a RMM|JBR Shifter Bushings|COBB shift knob|H&R springs|JBR rear camber arms|MOOG end links|
Wicked is offline   Reply With Quote
 Old 06-20-2013, 11:10 AM   #54
himurax13's Avatar
Groans: 255
Starting from a dead stop, gear changes, and rev matching is a hell of a lot smoother than before.
What I don't like is that any more input than barely holding the gas pedal down causes my car to accelerate quickly. No bueno for driving in LA traffic.
 Old 06-20-2013, 11:11 AM   #55
helmetface's Avatar
Groans: 219
The "jerkiness" mainly comes from my PnP mani, these tables make it much more noticeable.
Wicked (06-20-2013)
 Old 06-22-2013, 06:11 PM   #56
LatinKraze's Avatar
Posts: 804   (View Stats)
Flashed this set up for about fifty miles yesterday. I liked it a lot but it doesn't match my driving style. It definitely encourages speeding, lol. It's damn awesome on the highway but I was always in boost on the street. I may have to tweak this in the future but for now OEM set up will do. Much thanks for the work put into this @snailD
2016 CX-5 GT AWD
The Following 2 Users Say Thank You to LatinKraze For This Useful Post:
m.a.vega1 (02-27-2014), snailD (06-22-2013)
 Old 07-11-2013, 08:22 PM   #57
MS3Cody's Avatar
Posts: 14   (View Stats)
MS3Cody will become famous soon enough
Thanks for the table. Going to try this tomorrow!
Silver 2011 MS3 - SURE Aero SRI - CS TIP - CS Catless Downpipe - CS RP - Magnaflow CBE - JBR RMM - Autotech Internals - COBB AP - H&R Springs
MS3Cody is offline   Reply With Quote
The Following User Says Thank You to MS3Cody For This Useful Post:
snailD (07-11-2013)
 Old 07-11-2013, 09:29 PM   #58
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
Ive tried this again, slightly modified. It seems my original issue must have been a bad flash as everything is working as it should.
snailD (07-13-2013)
 Old 07-13-2013, 09:08 PM   #59
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
I just gave these settings about a 20 mile run, and they work absolutely perfect for me. Throttle is much more crisp, rev matching is far easier, and modulating boost is a breeze. Anyone with a bit of finesse in their right foot should like these tweaks.
Thanks a lot @snailD;
The Following 2 Users Say Thank You to Agent_Orange For This Useful Post:
omgvance (03-12-2014), snailD (07-13-2013)
 Old 11-19-2013, 11:19 AM   #60
[R]usty's Avatar
Posts: 2,204   (View Stats)
Thanks @snailD;!
I just loaded these last night and wow big difference. Way more my driving style. It's a touchy pedal but I prefer it that way. It will take some getting use to but it's a huge improvement.
Of course right after I loaded these some dude in a modded 328i () pulled up next to me and started revving. We raced from a dig and I just lost control of first and second and held on for my dear like. I'm usually good at handling those but man what a difference. I spun like crazy so he got a half a car but once I hit third I had 4 on him then fourth and he was gone. He tried to fly by as I let off and hit my braked but I tapped the pedal again and he was gone again. Tables are awesome.
tl;dr Loaded tables, raced on my first drive and scared the crap out of myself and won the race (tables are awesome!).
2010 Mazdaspeed3 w/tech
Mauro_Penguin (11-20-2013)
 Old 11-19-2013, 05:46 PM   #61
snailD's Avatar
haha glad you like it. I made a new one for someone looking for a less intense table, its very linear tho, pretty similar to stock down low without that big dead spot. i'll have to post those up for some people who were looking for a less aggressive table.
The Following 2 Users Say Thank You to snailD For This Useful Post:
Mauro_Penguin (11-20-2013), [R]usty (11-19-2013)
 Old 11-19-2013, 05:59 PM   #62
[R]usty's Avatar
That would be great. I like the very aggressive 3rd through 6th. 1st and 2nd are a little too aggressive for my taste so I dialed them back a bit. Haven't loaded the map yet but I'm expecting less loss of control.
 Old 11-19-2013, 06:36 PM   #63
The Nut's Avatar
Posts: 1,571   (View Stats)
I didn't get to use the these for long cause I had to go back to my 91 tune for awhile until I figure out my blow-by problem. But for the few days I used them the less aggressive tables you mocked up for me were awesome. I should copy and paste them into my 91 tune...I'll get on that tonight! Maybe you guys will get lucky and @snailD; will post them!
2012 BLACK MICA w/TECH
91 & Corn diagnostics by:
 Old 11-19-2013, 07:09 PM   #64
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
Posting those tables would be awesome. I am using only your DBW table right now cause the gear tables are just too hyper for me. Not sure what the DBW table effects but I think it improved modulation..especially during cornering...I think?
 Old 11-19-2013, 07:59 PM   #65
snailD's Avatar
I only have the gen 2 APP done up but here it is. i'll update the OP when i get home. For the relaxed individuals.
Code:
0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00
1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00
1.50	1.50	1.50	1.50	1.63	1.75	2.00	2.00	2.00	2.00	2.00	2.00	2.00	2.00	2.00
2.34	2.34	2.34	2.34	2.47	2.60	2.60	2.60	2.60	2.60	2.60	2.60	2.60	2.60	2.60
3.96	3.96	3.96	3.96	4.08	4.20	4.00	4.00	4.00	4.00	4.00	4.00	4.00	4.00	4.00
4.50	4.50	4.50	4.50	4.80	5.10	5.20	5.20	5.20	5.20	5.20	5.20	5.20	5.20	5.20
5.85	5.85	5.85	5.85	6.26	6.67	6.84	6.84	6.84	6.84	6.84	6.84	6.84	6.84	6.84
6.30	6.30	6.30	6.30	6.97	7.64	8.28	8.28	8.28	8.28	8.28	8.28	8.28	8.28	8.28
8.10	8.10	8.10	8.10	8.71	9.31	9.63	9.63	9.63	9.63	9.63	9.63	9.63	9.63	9.63
9.90	9.90	9.90	9.90	10.59	11.27	11.54	11.54	11.54	11.54	11.54	11.54	11.54	11.54	11.54
11.70	11.70	11.70	11.70	12.57	13.45	13.90	13.90	13.90	13.90	13.90	13.90	13.90	13.90	13.90
13.50	13.50	13.50	13.50	14.45	15.40	15.80	15.80	15.80	15.80	15.80	15.80	15.80	15.80	15.80
15.15	15.15	15.15	15.15	16.41	17.67	18.50	18.50	18.50	18.50	18.50	18.50	18.50	18.50	18.50
17.71	17.71	17.71	17.71	19.15	20.59	21.50	21.50	21.50	21.50	21.50	21.50	21.50	21.50	21.50
20.91	20.91	20.91	20.91	21.65	23.39	24.65	24.65	24.65	24.65	24.65	24.65	24.65	24.65	24.65
24.81	24.81	24.81	24.81	26.25	27.68	27.80	27.80	27.80	27.80	27.80	27.80	27.80	27.80	27.80
29.71	29.71	29.71	29.71	31.11	32.51	32.00	32.00	32.00	32.00	32.00	32.00	32.00	32.00	32.00
34.60	34.60	34.60	34.60	36.41	38.22	38.00	38.00	38.00	38.00	38.00	38.00	38.00	38.00	38.00
39.51	39.51	39.51	39.51	41.73	43.95	44.00	44.00	44.00	44.00	44.00	44.00	44.00	44.00	44.00
44.41	44.41	44.41	44.41	47.04	49.67	50.00	50.00	50.00	50.00	50.00	50.00	50.00	50.00	50.00
49.30	49.30	49.30	49.30	52.35	55.39	56.00	56.00	56.00	56.00	56.00	56.00	56.00	56.00	56.00
54.21	54.21	54.21	54.21	57.79	61.37	62.50	62.50	62.50	62.50	62.50	62.50	62.50	62.50	62.50
59.10	59.10	59.10	59.10	63.22	67.33	69.00	69.00	69.00	69.00	69.00	69.00	69.00	69.00	69.00
64.00	64.00	64.00	64.00	68.65	73.31	75.50	75.50	75.50	75.50	75.50	75.50	75.50	75.50	75.50
68.90	68.90	68.90	68.90	74.09	79.28	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00
73.80	73.80	73.80	73.80	77.49	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00
73.80	73.80	73.80	73.80	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00
app
Code:
0.00	1.70	2.70	4.75	7.50	10.50	13.55	16.39	19.26	25.00	30.00	35.00	40.00	45.00	50.00	60.00	70.00	80.00	90.00	100.00
The Following 4 Users Say Thank You to snailD For This Useful Post:
MZRSPEED (11-20-2013), The Nut (11-19-2013), WetzMS3 (11-20-2013), [R]usty (11-19-2013)
 Old 11-19-2013, 09:27 PM   #66
The Nut's Avatar
@snailD; is one badass motherfucker.
The Following 4 Users Say Thank You to The Nut For This Useful Post:
lobitoPU (11-20-2013), MZRSPEED (11-20-2013), omgvance (03-12-2014), snailD (11-19-2013)
 Old 11-19-2013, 11:06 PM   #67
[R]usty's Avatar
So excited, I'm going to try these tomorrow at lunch. Thanks snailD!
 Old 11-19-2013, 11:47 PM   #68
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
@snailD; A long time ago I came up with this APP Translation for use with the OTS Cobb tables...Numbs it down and makes it easier to control engine RPM, IMO.
I'd be interested to see what you think about it.
Code:
0.00	0.25	0.50	1.50	3.00	4.50	6.00	7.00	8.00	9.00	10.00	11.00	12.00	13.00	14.00	15.00	20.00	25.00	30.00	35.00	40.00	45.00	50.00	57.50	65.00	75.00	84.00	87.50	90.00	95.00	100.00
 Old 11-20-2013, 12:29 AM   #69
The Nut's Avatar
Ok, got the tables copied and pasted. There's no excess danger (KR, going lean, or whatever) having more aggressive throttle tables on a 91 tune is there?
 Old 11-20-2013, 07:40 AM   #70
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Generically speaking, there shouldn't be.
Still, always log after making changes so you can quantify the results and be sure there are no side effects even on the simple things.
340hp / 371tq
 Old 11-20-2013, 08:51 AM   #71
snailD's Avatar
no, it is only going to effect the feel, its not going to effect anything else. if you made all the 80's 100's, things would change
The Following 3 Users Say Thank You to snailD For This Useful Post:
Agent_Orange (11-20-2013), The Nut (11-20-2013), [R]usty (11-20-2013)
 Old 11-20-2013, 11:40 AM   #72
[R]usty's Avatar
Tried the new app table today. It's just what I was looking for, very good throttle delivery and not overly aggressive as the previous. I almost had you point for point with the one I can up with but yours was better down low so I'm keeping it. Thanks again!
The Following 2 Users Say Thank You to [R]usty For This Useful Post:
snailD (11-20-2013), The Nut (11-20-2013)
 Old 11-20-2013, 12:32 PM   #73
The Nut's Avatar
Couldn't agree more. This set up is fucking perf.! Just had a ques/observation. @snailD In the OP you posted one APP table for 1st gear, and another for 2nd-6th. On this revision there's only 1 APP table. Is this one for use with all 6 gears because it's a more mild hybrid? Thought people might want to know.
 Old 11-20-2013, 04:32 PM   #74
snailD's Avatar
it was just because a full linear app was too aggressive in 1st on the one i use, but i liked the pep in 3rd +. glad the last one fits you guys well. Worked for a bit on it
 Old 11-20-2013, 04:34 PM   #75
himurax13's Avatar
Groans: 255
@snailD are you going to redo the first post so you can display the Pussy and Non-Pussy settings?
Agent_Orange likes this.
The Following 4 Users Say Thank You to himurax13 For This Useful Post:
Agent_Orange (11-20-2013), big angry bird (01-14-2014), SLOWHATCH (05-17-2014), snailD (11-20-2013)
 Old 11-20-2013, 05:03 PM   #76
The Nut's Avatar
Says the guy who took the non-pussy version and pussified it himself.
The Following 2 Users Say Thank You to The Nut For This Useful Post:
big angry bird (01-14-2014), snailD (11-20-2013)
 Old 11-20-2013, 05:05 PM   #77
himurax13's Avatar
Groans: 255
Tuned to my liking, thank you very much.
snailD (11-20-2013)
 Old 11-20-2013, 09:44 PM   #78
gpower07's Avatar
Posts: 162   (View Stats)
gpower07 is a glorious beacon of lightgpower07 is a glorious beacon of lightgpower07 is a glorious beacon of lightgpower07 is a glorious beacon of lightgpower07 is a glorious beacon of lightgpower07 is a glorious beacon of light
the throttle is very touchy but i LOVE IT. I test drove it in rain...it scary...maybe take a few days get used to it. thank you
Cobb AP,TIP,SRI,DP. autotech internals. CS LED lights. JBR short shifter, rear and PSS mount. NGK one step cold plus. HID retrofit with black housing{iVTEC and AWD}LOL!!!!!!
gpower07 is offline   Reply With Quote
The Following User Says Thank You to gpower07 For This Useful Post:
snailD (11-28-2013)
 Old 11-28-2013, 05:29 PM   #79
iammike's Avatar
Posts: 1,415   (View Stats)
Just wanted to say thanks for this. I ended up using the more mild table of the two and love it. I had a lot of fun with the more aggressive table but for a DD, it was better to tame it a tad.
Thanks again for sharing these tables. Car feels great!
Mike
The Following User Says Thank You to iammike For This Useful Post:
snailD (11-28-2013)
 Old 11-29-2013, 05:16 PM   #80
speed23's Avatar
Posts: 1,480   (View Stats)
I tried the throttle tables today and they feel pretty good. Thanks for doing the work on these.
The Following User Says Thank You to speed23 For This Useful Post:
BeastlyZoomZoom (02-21-2015)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f426/snaild-s-throttle-table-fix-146060/
Hunter's Cosmic Blue Build - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 05-18-2015 01:02 PM
Self-tuning adventure! - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 10-13-2014 11:36 AM
Thinking about a tune. - Page 2 This thread Refback 08-19-2014 04:33 AM
Snaild on corn snailD 2010 MS3 - Dyno Sheets/Discussions 13 11-23-2012 10:58 PM
Unsettling hesitation under part throttle and full throttle at first track day dachtler 2010 MS3 - ECU Computer Tuning 0 10-01-2012 02:49 PM
OL/part throttle at what percent throttle? MS3Zoom24
Cobb ATR Support
4 10-31-2009 02:37 PM
Do we know when the ECU uses each table? FreeFlyFreak
Cobb ATR Support
17 05-07-2009 01:54 PM
Page generated in 0.57971 seconds with 41 queries
