> 2010 MS3 - ECU Computer Tuning
Like Tree19Likes
 Old 11-29-2013, 05:41 PM   #81
The Nut's Avatar
Posts: 1,571   (View Stats)
@snailD; I'm so happy so many people are enjoying these new tables you worked up. I know I am!
2012 BLACK MICA w/TECH
91 & Corn diagnostics by:
snailD (11-29-2013)
 Old 11-29-2013, 07:37 PM   #82
snailD's Avatar
Posts: 3,039   (View Stats)
no problem man. i just felt like there were improvements to be made. glad i could help
The Nut (11-29-2013)
 Old 01-06-2014, 09:01 AM   #83
snailD's Avatar
so.... went back through here just for the fuck of it and noticed something kinda odd. so i did some copy and paste stuff and my hunch was correct. i could have SWORN i pasted a different DBW table when i made the post for "the relaxed individuals" but apparently only the APP table copied over correctly... ah fuck. Regardless that table was more relaxed because of the APP positioning, BUT i meant to post this. I updated the OP DBW table to match...
Code:
0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00
1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00
1.50	1.50	1.50	1.50	1.63	1.75	2.00	2.00	2.00	2.00	2.00	2.00	2.00	2.00	2.00
2.34	2.34	2.34	2.34	2.47	2.60	2.60	2.60	2.60	2.60	2.60	2.60	2.60	2.60	2.60
3.96	3.96	3.96	3.96	4.08	4.20	4.00	4.00	4.00	4.00	4.00	4.00	4.00	4.00	4.00
4.50	4.50	4.50	4.50	4.80	5.10	5.20	5.20	5.20	5.20	5.20	5.20	5.20	5.20	5.20
5.85	5.85	5.85	5.85	6.26	6.67	6.84	6.84	6.84	6.84	6.84	6.84	6.84	6.84	6.84
6.30	6.30	6.30	6.30	6.97	7.64	8.28	8.28	8.28	8.28	8.28	8.28	8.28	8.28	8.28
8.10	8.10	8.10	8.10	8.71	9.31	9.63	9.63	9.63	9.63	9.63	9.63	9.63	9.63	9.63
9.90	9.90	9.90	9.90	10.59	11.27	11.54	11.54	11.54	11.54	11.54	11.54	11.54	11.54	11.54
11.70	11.70	11.70	11.70	12.57	13.45	13.90	13.90	13.90	13.90	13.90	13.90	13.90	13.90	13.90
13.50	13.50	13.50	13.50	14.45	15.40	15.80	15.80	15.80	15.80	15.80	15.80	15.80	15.80	15.80
15.15	15.15	15.15	15.15	16.41	17.67	18.50	18.50	18.50	18.50	18.50	18.50	18.50	18.50	18.50
17.71	17.71	17.71	17.71	19.15	20.59	21.50	21.50	21.50	21.50	21.50	21.50	21.50	21.50	21.50
20.91	20.91	20.91	20.91	21.65	23.39	24.65	24.65	24.65	24.65	24.65	24.65	24.65	24.65	24.65
24.81	24.81	24.81	24.81	26.25	27.68	27.80	27.80	27.80	27.80	27.80	27.80	27.80	27.80	27.80
29.71	29.71	29.71	29.71	31.11	32.51	32.00	32.00	32.00	32.00	32.00	32.00	32.00	32.00	32.00
34.60	34.60	34.60	34.60	36.41	38.22	38.00	38.00	38.00	38.00	38.00	38.00	38.00	38.00	38.00
39.51	39.51	39.51	39.51	41.73	43.95	44.00	44.00	44.00	44.00	44.00	44.00	44.00	44.00	44.00
44.41	44.41	44.41	44.41	47.04	49.67	50.00	50.00	50.00	50.00	50.00	50.00	50.00	50.00	50.00
49.30	49.30	49.30	49.30	52.35	55.39	56.00	56.00	56.00	56.00	56.00	56.00	56.00	56.00	56.00
54.21	54.21	54.21	54.21	57.79	61.37	62.50	62.50	62.50	62.50	62.50	62.50	62.50	62.50	60.00
59.10	59.10	59.10	59.10	63.22	67.33	69.00	69.00	69.00	69.00	69.00	69.00	69.00	69.00	64.00
64.00	64.00	64.00	64.00	68.65	73.31	75.50	75.50	75.50	75.50	75.50	75.50	75.50	75.50	68.00
68.90	68.90	68.90	68.90	74.09	79.28	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	72.00
73.80	73.80	73.80	73.80	76.90	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	76.00
73.80	73.80	73.80	73.80	76.90	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00
The Following 4 Users Say Thank You to snailD For This Useful Post:
Cevaes_64 (03-10-2014), jseams (01-12-2014), socaltouch13 (01-06-2014), Tokay444 (01-06-2014)
 Old 01-06-2014, 09:14 AM   #84
littleloogy's Avatar
Posts: 4,005   (View Stats)
Ha ha, I'll try this tonight. Thanks for the update!
Sent while cleaning my spill valve again...
 Old 01-06-2014, 10:32 AM   #85
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Code:
So there is a need to redo the relaxed tables?
Is the Gen 2 APP tables the same for 2nd to 6th gear?
Can I reduce wheelspin in the first 3 gears by modifying the APP tables?
Pickles Tune in progress
 Old 01-06-2014, 11:23 AM   #86
The Nut's Avatar
This updated DWP table is the one he mocked up for me. You all only had the updated APP tables to this point which is FAR less aggressive than the original post with both sets of tables. With out this DWP table, I can see why you thought the new mock ups were so pussy since it only changed the APP table. @himurax13;, copy and paste this in and it might change your mind about it being too mild.
Also, on this relaxed version, the APP table uses the same table for 1st-6th gear. Unlike the original which had a different one for 1st. In short, you should like this much better now.
This is a great set of tables for those that aren't FMIC as as much compensation isn't needed for air travel time.
Like I stated in a previous post, this eliminates the lag in the gas pedal and causes much quicker spool up.
 Old 01-06-2014, 11:31 AM   #87
ibcrusn's Avatar
Posts: 494   (View Stats)
ibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the world
I'll have to revisit the tables in my map as I went with what was posted for the less aggressive APP and used the other DWP tables figuring they were good to go.
It took me a few days to get accustomed to but the throttle is a lot nicer and no pedal dead spot/lag.
'10 VRM MS3
3" JBR WP, ETS TMIC, KMD/Aviva HPFP, NGK LTR7IX, M2 TP, Grimmspeed, JBR & MD EGR delete, MD OCC, MD PMM, CPe Stg2 RMM, CS TMM insert
Mazda Motorsports C/O, JBR RSB, SPC camber arms, Konig Hypergram 17x9 +40 & 200 UTQG rubber or Drag DR-49 18x8 +45, Michelin Pilot Sport A/S 3
Strive for perfection in everything. Take the best that exists and make it better.
If it doesn't exist, create it. Accept nothing nearly right or good enough.
Sir Henry Royce
ibcrusn is offline   Reply With Quote
 Old 01-06-2014, 02:37 PM   #88
snailD's Avatar
yea idk how it didnt end up getting pasted correctly. @lobitoPU; is running the tables i just posted so maybe he can chime in on how he thinks the feel is. basically it should feel like stock without the dead pedal it has at about 50% input. And yes its meant to run this APP table for 1-6. it really only probably needs to be run 1-3 and you could run a linear throttle table for 4-6 to make those feel peppier but it will be marginal if you could even tell at all
 Old 03-10-2014, 12:18 PM   #89
El Beaner's Avatar
Posts: 4,262   (View Stats)
Holy wow, did this make a huge difference on the OTS Stage 1 map.
Love gears 2+ but 1st was too picky for me. Copied the throttle info from Stage 0 onto stage 1 and gonna see how that works for me(I like the way stage 0 feels)
SOLD 2012 LSM Tech - 11/17/17
 Old 03-10-2014, 12:27 PM   #90
The Nut's Avatar
Which tables did you implement? The original set or the more chill, revised ones?
Also, @snailD;, I still have a small bit (about the first 1/2") of dead pedal with the revised ones. Is that normal?
 Old 03-10-2014, 12:43 PM   #91
El Beaner's Avatar
I went with the first DBW table in the first post. Is the second table the more chill one?
This is what I went with
DBW TABLE A,B,C
Code:
1.50	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	2.00	2.00
1.70	1.50	1.50	1.50	1.80	2.00	2.00	2.00	2.00	2.00	2.00	2.00	2.00	3.50	3.50
1.90	2.50	2.60	2.60	2.90	3.30	3.00	2.60	3.00	3.00	3.00	4.00	4.00	5.00	5.00
2.10	3.50	4.40	4.40	4.60	4.90	4.60	4.50	3.90	4.50	4.50	5.50	6.00	7.00	7.00
2.30	4.00	5.00	5.70	6.10	6.50	6.40	6.20	6.00	6.70	7.00	7.00	7.60	8.10	8.10
3.50	5.50	6.50	7.30	6.80	8.20	7.80	7.60	7.60	8.20	8.40	8.90	9.90	9.60	9.60
7.00	7.00	7.00	7.00	10.40	10.40	10.40	10.40	10.40	10.40	10.40	10.40	10.40	10.40	10.40
9.00	9.00	9.00	9.00	11.00	12.00	12.00	12.00	12.00	12.00	12.00	12.00	12.00	12.00	12.00
11.00	11.00	11.00	11.00	12.00	14.00	13.00	13.00	13.00	13.00	13.00	13.00	13.00	13.00	13.00
12.00	13.00	13.00	13.00	13.00	16.00	16.00	16.00	16.00	16.00	16.00	16.00	16.00	16.00	16.00
15.00	15.00	15.00	15.00	16.00	17.00	18.00	18.00	18.00	18.00	18.00	18.00	18.00	18.00	18.00
16.83	17.50	16.83	17.50	17.83	21.50	19.83	20.50	19.83	20.50	19.83	20.50	19.83	20.50	19.83
19.68	20.46	19.68	20.46	20.68	22.46	21.68	22.46	21.68	22.46	21.68	22.46	21.68	22.46	21.68
21.79	22.67	22.12	23.00	22.62	26.92	26.21	26.92	26.21	26.92	26.21	26.92	26.21	26.92	25.26
26.90	27.88	27.57	28.55	28.57	30.38	29.73	30.38	29.73	30.38	29.73	30.38	29.73	30.38	28.14
32.01	33.09	33.01	34.09	34.51	36.84	36.26	36.84	36.26	36.84	36.26	36.84	36.26	36.84	34.01
37.12	38.31	38.45	39.64	40.45	43.31	42.79	43.31	42.79	43.31	42.79	43.31	42.79	43.31	39.89
42.23	43.52	43.90	45.18	46.40	49.77	49.31	49.77	49.31	49.77	49.31	49.77	49.31	49.77	45.76
47.34	48.73	49.34	50.73	52.34	56.23	55.84	56.23	55.84	56.23	55.84	56.23	55.84	56.23	51.64
52.45	53.94	54.78	56.28	58.28	62.69	62.37	62.69	62.37	62.69	62.37	62.69	62.37	62.69	57.51
57.56	59.15	60.23	61.82	64.23	69.15	68.89	69.15	68.89	69.15	68.89	69.15	68.89	69.15	63.39
62.67	64.36	65.67	67.36	70.17	75.61	75.42	75.61	75.42	75.61	75.42	75.61	75.42	75.61	69.26
67.78	69.58	71.11	72.91	76.11	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	75.14
72.89	74.79	76.56	78.46	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00
78.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00
GEN 2 1st Gear APP
Code:
0.00	1.69	2.25	4.12	6.77	10.95	14.37	17.40	19.85	24.75	29.65	34.55	40.00	45.00	50.00	60.00	70.00	80.00	90.00	100.00
Gen 2 APP 2-6
Code:
0.00	2.50	5.00	7.50	10.00	12.50	15.00	17.50	20.00	25.00	30.00	35.00	40.00	45.00	50.00	60.00	70.00	80.00	90.00	100.00
This is the second table he listed(I would gather these are the more chill ones)
DBW A,B, and C.
Code:
Gen 2 APP
Code:
0.00	1.70	2.70	4.75	7.50	10.50	13.55	16.39	19.26	25.00	30.00	35.00	40.00	45.00	50.00	60.00	70.00	80.00	90.00	100.00
 Old 03-10-2014, 12:47 PM   #92
The Nut's Avatar
@El Beaner; Yes, the 2nd set are the more chill ones. Implement them to your Stage 1 map and you'll be much happier.
El Beaner (03-10-2014)
 Old 03-10-2014, 12:50 PM   #93
obijack's Avatar
Posts: 1,830   (View Stats)
Just saw this thread. The throttle response improvement was the first thing I noticed after @snailD; tuned my car. It feels so responsive and quick to get into boost. Very nice!
2014 Honda Grom-Red
2014 Yamaha Grizzly 350- Blue
 Old 03-10-2014, 12:53 PM   #94
El Beaner's Avatar
Ok, will do. So the APP listed under it I should use for Gears 1-6?
That could explain why I felt gea 1 was much touchier than than the others since the one I implemented had a seperate 1st gear APP.
I'll make the adjustment tonight and flash for my morning drive and will see how that is.
 Old 03-10-2014, 03:16 PM   #95
snailD's Avatar
i dont feel the same thing, but just increase the APP slightly in the low range (where the dip is) to get it to where you are happy. maybe just try a linear app and you will like it better
The Nut (03-10-2014)
 Old 03-10-2014, 03:37 PM   #96
The Nut's Avatar
Yup. I'm kinda thinking I inputted the wrong DBW table when I did this (before he changed it to the "chill" one) and that's why I'm boosting so incredibly quickly. It's almost impossible not too. When the wife gets home with the laptop I'll have to check mine values to the 2 different ones listed above.
 Old 03-10-2014, 05:36 PM   #97
pfp22972's Avatar
Posts: 820   (View Stats)
pfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the world
El Beaner, it looks like your car is coming right along since I saw it last.
I want to thank @snailD. This post almost single-handedly pushed me to learn more about using ATR.
BTW...I made the APP values below after playing with SnailD's and Ledfoot's. It similar to Snail's original but makes my car less likely to jump into boost in stop and go traffic. I use them in APP tables 1 - 6.
Sorry, I don't know how to post a table for easy copying.
0, 1.53, 2.43, 4.28, 6.75, 9.45,12.2, 14.75, 17.33, 22.5, 27, 31.5, 36, 40.5, 45, 54, 63, 72, 82, 100.
2010 Celestial Blue Speed 3
- FREEKTUNED -
Cobb AP v2 - UR test pipe w/ resonator - UR CBE - CS BPV - CS TMIC
CS shifter bushings - CS RMM - CS TMM insert - CS brake pads - CS LED kit - Autotech Internals
JBR Tru 3" WP intake - JBR FSB and RSB - JBR IM+TB TIGs & TB Bypass - JBR boost tubes - JBR EGR Delete
Cobb springs - Koni Yellows - Centric high carbon rotors - Drag DR38 47+ wheels - Continental DW's
Last edited by pfp22972; 03-10-2014 at 07:14 PM. Reason: evidentally I don't know how to link to user's names.
pfp22972 is offline   Reply With Quote
The Following User Says Thank You to pfp22972 For This Useful Post:
snailD (03-10-2014)
 Old 03-10-2014, 06:45 PM   #98
The Nut's Avatar
I wonder if I raise my idle (still OEM value) if that would help the feeling of first half inch dead pedal?
 Old 03-10-2014, 06:48 PM   #99
El Beaner's Avatar
I want to thank SnailD. This post almost single-handedly pushed me to learn more about using ATR.
Yeah been doing some Mods here and there. Intake will be going in this weekend as well as solid shifter bushings and some other style enhancements.
 Old 03-10-2014, 06:56 PM   #100
pfp22972's Avatar
I cannot figure out how to link someone in these posts.
@The Nut -
I am using the OTS DBW tables A, B,and C with the values I posted above in APP gears 1 -6. I have no dead spots at all. The throttle is quite a bit more alive than OTS but a touch more tame than SnailD's orginal APP's. I really like it.
- FREEKTUNED -
 Old 03-10-2014, 07:04 PM   #101
El Beaner's Avatar
The Nut
To link people use mention in brackets
mention the persons name and then the ending bracket with / before the m inside the bracket.
@The Nut
Or click on go advanced and the little icon that looks like a speaker will inset the bbcode for you
The Following User Says Thank You to El Beaner For This Useful Post:
pfp22972 (03-10-2014)
 Old 03-10-2014, 07:16 PM   #102
pfp22972's Avatar
Thank you @El Beaner. It's pretty easy to tell I do not post much but I do like to thank those that have helped me.
- FREEKTUNED -
 Old 03-10-2014, 07:47 PM   #103
El Beaner's Avatar
Anytime.
 Old 03-10-2014, 10:08 PM   #104
El Beaner's Avatar
Stage 1 map updated and flashed to ecu. In anticipation of liking it I went ahead and made a stage 1 cs sri+tih map update with these throttle curves.
 Old 03-11-2014, 12:11 AM   #105
The Nut's Avatar
@The Nut -
I love them. I still have a tiny bit (maybe half inch) of dead pedal at the top. Wondering, as I said above, if raising my idle would take care of that. Didn't notice it till a while after I implemented them.
Edit: yup, had more aggressive DBW tables this whole time. Now I should be able to stay out of boost when I want to. Also gone try out more aggressive APP tables for gears 4-6, see how that feels.
 Old 03-11-2014, 06:54 AM   #106
El Beaner's Avatar
Ok, so I did my first drive with the new setup and it was very nice and responsive. Got a couple of questions/issues.
#1 the APP table - I only placed it in Gears 1-6 and left the 0 neutral alone. Should I have updated 0?
#2 I know this isn't at WOT because only WOT I did was during a specific stretch of road. I am seeing a lot more "ghost/partial throttle" KR as well as negative LTFT(first I've ever seen of that). Not sure if this should be a concern/normal?
I'll need to run a log to make sure no other issues. Side note, my HPFP maxed out just over 1800, normally at WOT I'll see it hit into the 20xx range.
 Old 03-11-2014, 07:10 AM   #107
pfp22972's Avatar
I left APP table 0 alone. I think most people do.
How many miles have you driven since the flash?
The general consensus is to not worry about LTFT until you've put at least 50 miles on the map update so the computer can relearn.
- FREEKTUNED -
 Old 03-11-2014, 07:24 AM   #108
El Beaner's Avatar
Ah ok - trip to work is roughly 20 miles.
As far as the KR, I am pretty certain it was partial throttle KR which from my understanding is pretty normal for our cars adjusting timing trying to maximize fuel efficiency and what not.
 Old 03-11-2014, 07:32 AM   #109
pfp22972's Avatar
I really can't speak much on KR. I honestly haven't ventured much further than following this post and Bucker's guide to adjust my maps. I plan to inquire with one of the awesome tuners on this forum about an e - tune before my curiosity gets too carried away and I do something destructive to my car.
Sent from somewhere...but not here.
- FREEKTUNED -
 Old 03-11-2014, 07:45 AM   #110
El Beaner's Avatar
Yeah some good options have surfaced over the past few days. Freektune is now offering slightly modified OTS maps(Freektune OTS plus) for $65 - initial map + 1 revision
http://www.freektune.com/products/ma...6-ots-plus-map
As well as Stratified is offering S-OTS plus maps too for $25 to adjust their SOTS map to be based on your mods.
http://www.stratifiedauto.com/index....roducts_id=230
After I get my intake, I'll most likely pay for a Freektune OTS plus since I don't plan on doing much more and if I do I'll be going full tune at that time.
 Old 03-11-2014, 07:51 AM   #111
Posts: 2,237   (View Stats)
I will look at this!
 Old 03-11-2014, 08:27 AM   #112
snailD's Avatar
changing the throttle table wont have anything to do with KR.
adjusting the DBW table and not adjusting the APP to what i have or something very similar will cause the throttle to be very different from what i intended. just wanted to make sure you knew that. if you are trying to get these to your liking and understand the relationship between the two then do whatever you want =)
 Old 03-11-2014, 08:42 AM   #113
El Beaner's Avatar
I'm wondering why I saw that KR then, I've never had anything above 3 while cruising around town until I did this update.
Only thing it could be would be partial throttle KR since I am still trying to get used to the new throttle response and how it behaves. I'll watch it the next few days to see what it does.
 Old 03-11-2014, 11:43 AM   #114
El Beaner's Avatar
Ok went out for lunch and kept an eye on kr. Saw kr mainly on turns or slight merging onto another road. In the straight and did a wot no kr noticed.
Still getting used to the new throttle response but I love having the power when I wsnt/need it
 Old 03-11-2014, 11:47 AM   #115
pfp22972's Avatar
Have you installed a RMM yet? Is it possible the KR is related to the engine jerking around with increased power? I'm sure there are other posts on here about your situation.
- FREEKTUNED -
 Old 03-11-2014, 11:51 AM   #116
El Beaner's Avatar
Lol I had a JBR rmm for a while and just did not like the vibes. Unless/until the stock rmm fails gonna stay this way. But could definitely be just the sensor picking up that extra noise.
 Old 03-11-2014, 12:34 PM   #117
Put the JBR RMM back in and quit being a sissy. Did you buy a luxurious car or a speed wagon??
Sent from my SAMSUNG-SGH-I747 using Tapatalk
The Following 5 Users Say Thank You to littleloogy For This Useful Post:
ANITIX87 (03-11-2014), btstarcher (03-11-2014), El Beaner (03-11-2014), Mauro_Penguin (03-13-2014), The Nut (03-11-2014)
 Old 03-11-2014, 02:37 PM   #118
El Beaner's Avatar
I bought a Daily Driver. Everyone has the things they just don't like. Mine just happens to be vibes/rattles.
I'm happy with how my car rides and if that means dealing with ghost KR due to engine movement then that's what I'll have to deal with.
 Old 03-11-2014, 02:55 PM   #119
it may not be related to the TB control exactly but i have seen strange kr when releasing the gas pedal and i realised my timing chain is a bit loose and i expect this backlash to cause ghost KR, maybe the new table make the engine going from power to compression more quickly and this noise is registered by the knock sensor ??? could it be ? Check your chain just for fun...
 Old 03-11-2014, 11:06 PM   #120
El Beaner's Avatar
I loaded up you app cause I was feeling a bit of the same as you like the car wanted to surge into boost. Loaded it up for tomorrow to see how I like it.
pfp22972 likes this.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f426/snaild-s-throttle-table-fix-146060/
Hunter's Cosmic Blue Build - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 05-18-2015 01:02 PM
Self-tuning adventure! - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 10-13-2014 11:36 AM
Thinking about a tune. - Page 2 This thread Refback 08-19-2014 04:33 AM
Snaild on corn snailD 2010 MS3 - Dyno Sheets/Discussions 13 11-23-2012 10:58 PM
Unsettling hesitation under part throttle and full throttle at first track day dachtler 2010 MS3 - ECU Computer Tuning 0 10-01-2012 02:49 PM
OL/part throttle at what percent throttle? MS3Zoom24
Cobb ATR Support
4 10-31-2009 02:37 PM
Do we know when the ECU uses each table? FreeFlyFreak
Cobb ATR Support
17 05-07-2009 01:54 PM
Page generated in 0.61929 seconds with 29 queries
