> 2010 MS3 - ECU Computer Tuning
Like Tree19Likes
 Old 07-13-2016, 02:27 PM   #241
dale_gribble's Avatar
Posts: 4,720   (View Stats)
I haven't noticed any increase in KR after part to wot throttle cycles since playing around. Again, my app tables are linear, so I can't speak to app curves and their impact.
Sent from my XT1585 using Tapatalk
MINI H1 6.0 - CAR LED TAILS
 Old 08-24-2016, 11:45 AM   #242
Franky-5-Fingaz's Avatar
Posts: 25   (View Stats)
Franky-5-Fingaz is a jewel in the roughFranky-5-Fingaz is a jewel in the roughFranky-5-Fingaz is a jewel in the roughFranky-5-Fingaz is a jewel in the rough
Neutral  :  -1 score
what have you guys been using for the Neutral APP Translation table? My guess is that this table would affect launches as much as the 1st gear table.
Franky-5-Fingaz is offline   Reply With Quote
The Following User Says NO Thank You to Franky-5-Fingaz For This Un-useful Post:
Vansquish (08-24-2016)
 Old 08-24-2016, 12:11 PM   #243
Police - Grammarhead
Vansquish's Avatar
. . . car is not in neutral when it is in first gear . . .
 Old 08-24-2016, 12:13 PM   #244
Are you sure? Manual transmissions are hard.
g00s3y (08-26-2016)
 Old 08-24-2016, 12:15 PM   #245
My thought exactly, if im wrong thats fine. Just wanted to get somebody else's opinions before i made the Neutral tables 1:1.
 Old 08-24-2016, 12:17 PM   #246
I was being sarcastic.
There are sensors that let the ECU know what gear the car is in, even if the clutch is still depressed. This is how LC on the AP and things like WOT boxes know when to engage and release.
 Old 08-24-2016, 12:19 PM   #247
ah, point taken. Thanks for getting your point across without having to add a No Thank you.
The Following User Says Thank You to Franky-5-Fingaz For This Useful Post:
 Old 08-24-2016, 12:34 PM   #248
Vansquish's Avatar
Have you ever tried non-linear APP tables? In particular, have you used any S-curve-based APP tables? I found they dramatically improved the predictability of boost delivery at part-throttle.
Code:
0	2.43	4.77	7.01	9.15	11.2	13.15	15	16.75	18.41	19.98	21.45	22.83	24.12	25.32	26.45	28.93	31	32.75	34.3	35.77	37.3	39.06	41.23	44	47.59	49.76	52.22	58.15	65.65	75
The Nut (08-24-2016)
 Old 08-24-2016, 01:00 PM   #249
The Nut's Avatar
Posts: 1,571   (View Stats)
Code:
What turbo are you using this with (BNR?)? I've just never noticed a problem with boost predictability with the 2nd revision of @snailD;'s APP tables, but I'm still on a k04.
2012 BLACK MICA w/TECH
91 & Corn diagnostics by:
 Old 08-24-2016, 02:03 PM   #250
Vansquish's Avatar
Mods in sig.
 Old 11-16-2017, 02:09 PM   #251
armyman's Avatar
Posts: 30   (View Stats)
armyman has a spectacular aura aboutarmyman has a spectacular aura about
How do these tables convert to Versatuner? APP consists of more pedal positions and more values in the DBW A, B and C
CPe HPFP, Corksport Mazdaspeed 6 power series catted downpipe, Corksport TMIC, Corksport MZR Bypass valve, Cooling Mist W/M injection with cmgs, JBR Tru-3.5 Wide Path Full aluminum Intake System, Denso ITV-22, intank 265 L fuel pump, rear engine mount, EGR block off plate, XS stainless steel exhaust manifold ceramic coating, BNR stage 3 turbo, Stratified Mazda 3 Port Electronic Boost Control Valve, Stratified tune, HKS Twin Power
armyman is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f426/snaild-s-throttle-table-fix-146060/
Hunter's Cosmic Blue Build - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 05-18-2015 01:02 PM
Self-tuning adventure! - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 10-13-2014 11:36 AM
Thinking about a tune. - Page 2 This thread Refback 08-19-2014 04:33 AM
Snaild on corn snailD 2010 MS3 - Dyno Sheets/Discussions 13 11-23-2012 10:58 PM
Unsettling hesitation under part throttle and full throttle at first track day dachtler 2010 MS3 - ECU Computer Tuning 0 10-01-2012 02:49 PM
OL/part throttle at what percent throttle? MS3Zoom24
Cobb ATR Support
4 10-31-2009 02:37 PM
Do we know when the ECU uses each table? FreeFlyFreak
Cobb ATR Support
17 05-07-2009 01:54 PM
Page generated in 0.30425 seconds with 26 queries
