![]() Join Date: Apr 2014 Location: Ripley, WV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 78
(Thread Starter) | Not Ranked : 0 score Opinions? Thanks for the input. BTW, its not about the money at all and Stratified is fantastic at what they do, but I also do not mind doing it myself and learning more about the Cobb software.
__________________ (SOLD) 2013 Crystal White MS3--JBR 3.5" intake, very minor PNP intake manifold, CS TMIC, CS HPFP internals, CS BPV, JBR EGR delete and block-off, CFM RMM, CS TM insert, Cobb AP V3 with Stratified Stage 3 tunes (93 and E85 mix), VTCS delete, coolant bypass, 1 step colder plugs, CS shifter bushings, CS short shifter, Damond OCC, Ultra Gauge, Progress RSB, Koni dampers, Eibach Pro-Kit springs, JBR rear spacers, 235/40/18 Nitto Motivo tires, Drag DR-49 18x8" wheels, CNT cat-less DP, CNT cat-back, DDM HIDs, etc. 2017 Mazda CX-3 Meteor Gray Last edited by TORQUERULES; 03-18-2016 at 07:37 AM. Reason: MSF Database - Automerged Doublepost |
Rep Power: 3748 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,745
| Unless you're running something significantly larger than a K04, there's really not much point in having an intake with an ID of 3". You'll lose MAF sensor granularity, and your car's drivability at low load/low revs will suffer. Think of it this way: Stock Intake: 2.5" ID --> 4.91 sq.in. cross section. Aftermarket : 3.0" ID --> 7.07 sq.in. cross section. JBR TRU-3.5": --> 3 ---> 9.62 sq.in. cross section. That's a 44% increase for a 3.0"ID, and a 96% increase for a 3.5", but the K04 can only efficiently make use of a little over 300g/s of air. On the stock intake the top end of the MAF curve (5.0V) sits at about 366g/s. On a JBR 3.0" intake, that would be about 500g/s, and on the 3.5", it would be nearly 680g/s.
![]() Join Date: Oct 2011 Location: San Leandro, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 460
Groans: 87
| Not Ranked : 0 score ^This Also, I doubt that you can change the MAF cal. since most tuners lock their maps.
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT |
| The Following User Says Thank You to tegxsi For This Useful Post: | Vansquish (03-18-2016) |
| It's actually better to do the $25 retune since you can't change the locked tune anyways. And I run a 3.5" JBR right meow. I don't have any drivability issues at low revs/idle. I like to go to straight to the "end game" intake since I'll be upgrading the turbo later on. sent from my Nexus 6P
| The Following 5 Users Say Thank You to MS3Shadow For This Useful Post: | robbspeed (03-18-2016), Shwa (03-18-2016), speedfreak44 (03-18-2016), TORQUERULES (03-18-2016), Vansquish (03-18-2016) |
![]() Join Date: Dec 2013 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 462
| Not Ranked : 0 score What ms3shadow said
__________________ The line up: 2013 G37 loaded...not stock for long 2013 MS3...stock to midturbo back to stock (traded) 2009 Nissan Frontier LE loaded...big stereo system (traded) 2009 Cadillac CTS sport package...stock (blown and traded piece of shit) 1994 Integra RS built all motor (sold) 1990 Civic EF nitrous turbo motor swapped beast (sold) 1987 Dodge pick up...jacked up (sold) |
![]() Join Date: Jun 2014 Location: Saint-Basile-Le-Grand, Quebec
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 289
Groans: 45
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score ^ what he said
__________________ 2010 Black MS3 Cobb AP // Cobb EBCS // Cobb Downpipe // Cobb RMM // JBR Tru 3.5'' Intake // JBR TMM // JBR PMM // JBR RSB // CP-E Cat Back // NGK One step colder plugs // GT 3071r // Azenis 615k // Bilstein PSS B14 Coilovers // Treadstone TR8 FMIC // Bully Stage 4 Clutch // Damon EGR Delete // Autotech HPFP // AEM V1 Meth Kit 50/50 // Freektuned 94 Oct ![]() |
![]() Join Date: Sep 2011 Location: Stockholm Sweden
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,687
Groans: 33
| Not Ranked : 0 score I would absolutely go with a bigger intake no matter what turbo is on. There are gains to be had even on a k04. And you wont need to change the intake when/if you go with a bigger turbo. The cs + k04 setup makes alot of spool-up noise, so going to a silicone intake will make it less noisy. My gtx + cpe intake was far less noisy than k04 + cs s2. But the gtx is also a much quiter turbo, sadly. I'm throwing in my new Freektune 4" metal intake now which should hopefully result in more flow and noise, also looks better. Less resistance in the intake tract could make your turbo overboost slightly at spool-up, so a small calibration might be needed but you'll find that out quickliy Go for it
__________________ Mazdaspeed6 -06 Tuned with by Alex@StratifiedCP-E Atmosphere Kit GTX3076 Tial 0.82AR / EWG / 3,25" MAF / Catless DP Simons 3" Catback CP-E Diff Mount HDI FMIC HTP Battery Relocation Corksport: Rear Brace Bar - Front Strut Bar - Stubby Antenna - Interior + Underhood LED Kit JBR: TMM+PMM+RMM - Short Shift Kit /w Bushings - TIG Throttle - Coolant Bypass - EGR Delete - JBR OCC Stage 2 Whiteline Rear Swaybar SPC Camber Joints Turbosmart BPV Autotech Internals SURE Juggernaught Stratified Guardian Angel & Boost Dial NGK IX @ 0.025 Bosch 3 bar MAP w/ PNP Harness Block8Head Dual Gauge Pod Defi Racer Boost & Oil Pressure & Oil Temp Techna-Fit Clutch Line + Brake Lines ATE Super Blue Racing ProSport Oil Filter Adapter Mazda Spin-On Conversion + NPT/BSPT adapter Not installed yet: SP63 longblock, FreekTune 4" Intake, JBR TIG IM, DM Meth Spacer 290 AWHP / K04 370 AWHP / GTX3076 @ 23 psi |
| The Following User Says Thank You to SpeedRebirth For This Useful Post: | TORQUERULES (03-18-2016) |
I am going to go to a BNR S3 later, so I thought I would upgrade intakes now to get ahead of the game. I figured that the $25 update was the way to go, but it never hurts asking everyone what their experience has been. Thanks.
__________________ (SOLD) 2013 Crystal White MS3--JBR 3.5" intake, very minor PNP intake manifold, CS TMIC, CS HPFP internals, CS BPV, JBR EGR delete and block-off, CFM RMM, CS TM insert, Cobb AP V3 with Stratified Stage 3 tunes (93 and E85 mix), VTCS delete, coolant bypass, 1 step colder plugs, CS shifter bushings, CS short shifter, Damond OCC, Ultra Gauge, Progress RSB, Koni dampers, Eibach Pro-Kit springs, JBR rear spacers, 235/40/18 Nitto Motivo tires, Drag DR-49 18x8" wheels, CNT cat-less DP, CNT cat-back, DDM HIDs, etc. 2017 Mazda CX-3 Meteor Gray | |
![]() Join Date: Nov 2011 Location: Victoria, BC, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 86
| Not Ranked : 0 score When selecting your intake make sure you take in to consideration the inlet size of the turbo you think you will upgrade to. I know you said S3, however if you are like me, you will change your mind 1000x about your turbo choice. Honestly, I would hold off on the larger intake until you upgrade the turbo. That way you know for sure what intake will work with your turbo selection.
__________________ '08 MS3 // Corksport Turbo // JBR 3.5" WP // CNT Racing Turbo-Back // CX Racing FMIC // COBB AP // SURE Ventus // SURE Return // Damond Motorsports PMM & TMM // SURE Torq R3 // Stratified Guardian Angel // Autotech HPFP Internals // JBR EBCS // Corksport 3.5bar MAP // JBR S2 OCC // JBR EGR Delete // JBR TIG's // CP-e Safe Seals // SURE Shortcut // Corksport Swaybars // Bilstein Sports // H&R Springs // Tenzo R Type M 18"x8" // Michelin PSS |
| The Following User Says Thank You to gdawg25 For This Useful Post: | TORQUERULES (03-18-2016) |
Groans: 33
| Not Ranked : 0 score That's only an issue if he goes with a silicone intake
| The Following 2 Users Say Thank You to SpeedRebirth For This Useful Post: | gdawg25 (03-18-2016), TORQUERULES (03-18-2016) |
(Thread Starter) | Not Ranked : 0 score I didn't plan on full silicone. I want to be able to change the adapter at the turbo end. That way upgrading turbos will not require yet ANOTHER intake.
Sound advice, its just hard when you have a little money burning a hole in your pocket. Lol.
__________________ (SOLD) 2013 Crystal White MS3--JBR 3.5" intake, very minor PNP intake manifold, CS TMIC, CS HPFP internals, CS BPV, JBR EGR delete and block-off, CFM RMM, CS TM insert, Cobb AP V3 with Stratified Stage 3 tunes (93 and E85 mix), VTCS delete, coolant bypass, 1 step colder plugs, CS shifter bushings, CS short shifter, Damond OCC, Ultra Gauge, Progress RSB, Koni dampers, Eibach Pro-Kit springs, JBR rear spacers, 235/40/18 Nitto Motivo tires, Drag DR-49 18x8" wheels, CNT cat-less DP, CNT cat-back, DDM HIDs, etc. 2017 Mazda CX-3 Meteor Gray Last edited by TORQUERULES; 03-18-2016 at 12:55 PM. Reason: MSF Database - Automerged Doublepost | |
| Not Ranked : 0 score The jbr silicone 3" will fit over a s3. I ordered my s2 worried it wouldn't stretch to the s3 size but slipped over the s2 without a hitch. 3" is more than enough. Ask your mom
![]() Join Date: Mar 2016 Location: Northeastern Colorado
| Not Ranked : 0 score My mom said 3'' is fine...
__________________ Give credit when credit is due. |
| What order is best to upgrade 2012 Mazdaspeed 3? | Spense214 | Mazdaspeed3/6 General Discussion | 31 | 03-18-2016 04:36 PM |
| Todd - Tune Order 1165 - can't get a hold of you! | Lex | Stratified Automotive Controls | 2 | 05-21-2014 12:19 PM |
| bigger tip and intake? | cocoleveo7686 | MazdaSpeed 6 - Engine, Transmission & Driveline | 14 | 03-13-2014 05:59 PM |
| CorkSport Max Flow High Pressure Fuel Pump Upgrade Pre-Order | CorkSport | CorkSport | 193 | 02-16-2014 05:48 PM |
| HPFP Upgrade with no tune. | theurgy | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 19 | 10-02-2012 06:07 PM |
