> 2010 MS3 - ECU Computer Tuning
Like Tree6Likes
  • 1 Post By Tru3
  • 1 Post By Solarsurge
  • 1 Post By Tru3
  • 1 Post By Fstrnyou
  • 1 Post By mituc
 Old 08-26-2018, 03:23 PM   #1
Tru3's Avatar
Posts: 46   (View Stats)
Tru3 is on a distinguished road
Default What map to use?
Hey everyone, just wondering what map on my AP I should use. All my mods so far are in my sig. can I just use the stage 1 Cobb SF map and if so do I have to adjust MAF calibrations or can I just use it how it is. Thanks!
I believe the CorkSport stage 2 SRI/TIP combo is the stock intake size? But I’m not positive.
2010 MS3 // CS TIP - CS SRI - CS BOOST TUBES - CS MZR BPV - CS HPFP - COBB AP
onecivicshort likes this.
Tru3 is offline   Reply With Quote
 Old 08-27-2018, 12:36 AM   #2
Solarsurge's Avatar
Posts: 577   (View Stats)
You can use Stage 1 + SF without needing a tune, but of course getting one will always be better than OTS maps.
Technically, there is a slight difference in the MAF diameter, but it's so small it won't make a difference that requires a MAF cal.
Tru3 likes this.
 Old 08-28-2018, 07:45 AM   #3
Tru3's Avatar
I appreciate the reply. It’s kinda concerning to try it because COBBS website says if it ain’t exact it can cause potential engine damage?
2010 MS3 // CS TIP - CS SRI - CS BOOST TUBES - CS MZR BPV - COBB AP
 Old 08-28-2018, 09:40 AM   #4
Solarsurge's Avatar
It’s literally half a millimeter difference. It says right on the instruction manual from Corksport that you don’t need to tune. Now if it was half an inch difference yea, you’d need a tune for sure.
 Old 08-28-2018, 10:17 AM   #5
Tru3's Avatar
I know it says you don’t need a tune with the stage 2 intake and that’s because it’s the size of the stock intake with the same maf calibration as the stock intake, but taking the CS intake and putting that with a map designed for a completely different intake is the “issue”, that changes things right?
And I by no means am saying your wrong, but do you have documentation on it only being half a millimeter off?
The Following User Says NO Thank You to Tru3 For This Un-useful Post:
g00s3y (08-28-2018)
 Old 08-28-2018, 10:31 AM   #6
Solarsurge's Avatar
RTFM. Stock MAF is 67mm. Corksport is 67mm. Cobb SRI is 67.5mm. Cobb maps are basic AF and if anything, you’re gonna run a tiny bit rich, which is perfectly fine. Running LEAN on the other hand is not fine, and why you need a tune with larger intakes.
 Old 08-28-2018, 12:40 PM   #7
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Running a larger intake than what you're tuned for will run lean. It's measuring less air than what you're actually getting and therefore putting in the correct amount of fuel for the wrong amount of air.
However, a 1/2 mm. Meh. Stock tune is stupid rich anyways. You might be doing yourself a favor.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 08-28-2018, 12:43 PM   #8
Solarsurge's Avatar
His MAF will be a half a millimeter smaller. The Cobb tune is for 67.5mm. His Corksport is 67mm.
 Old 08-28-2018, 01:02 PM   #9
Fstrnyou's Avatar
Ahhhhhhh. I missed that.
Other rides:
History:
 Old 12-04-2018, 05:26 AM   #10
onecivicshort's Avatar
Posts: 9   (View Stats)
onecivicshort is an unknown quantity at this point
Can I run the same map with a AEM CAI?
onecivicshort is offline   Reply With Quote
 Old 12-04-2018, 06:15 AM   #11
Posts: 2,237   (View Stats)
Are you measuring ID or OD? I had in mind the stock was 64,x mm ID
I won't debate about half a mm but you need to keep in mind it is the square value of the difference...And it doesn't just affect AFR in open loop but also all the tables using load including ignition timing. Less load read = more agressive timing.
At the end, you can take a look to your STFT and LTFT after a 2-300 miles after using the map and see if it remain in a +/-8-10%...
Not 100% sure if there isn't other options but if you need a maf cal and you didn't follow the cobb class you would need a personal tune from an etuner to correct it.
 Old 12-06-2018, 09:28 AM   #12
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Same MAP - yes!
Same MAF - yes!
People, please wake up.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
Page generated in 0.33941 seconds with 24 queries
