 Old 11-27-2013, 08:21 AM   #1
Dat8687's Avatar
Posts: 257   (View Stats)
Dat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond reputeDat8687 has a reputation beyond repute
Groaned at 60 Times in 22 Posts
Default Clutch engagement point?
Ok I thought it was just my new car but why is the clutch engagement point and release so high? When I went from my WRX on the Original clutch with 110,000 miles it to the speed 3 I thought something was wrong.. The speed 3s clutch felt like it had 0 pressure and the engagement point is ridiculous. In fact after driving it for a couple of weeks now I still have trouble with it. Mind you I have been driving manual cars since I was in the middle school at the end of the 80s.
Should I take it into the dealership and see if somethings wrong? I have never had a clutch feel like this and have so much trouble measuring between shifts. My speed 6s clutch was like butter shifting compared to this car.
There is 0 slippage mind you It just feels akward how high the clutch pedal engages
Dat8687 is offline   Reply With Quote
 Old 11-27-2013, 09:01 AM   #2
Matrix311's Avatar
Posts: 2,133   (View Stats)
Different clutch different car. Maybe try bleeding the crap out of it and check the brake fluid, make sure its topped off and no air in the system. If after bleeding it the results remain the same, then maybe check the dealer.
 Old 11-27-2013, 10:07 AM   #3
manila's Avatar
Posts: 1,767   (View Stats)
These cars are tricky to learn. It took me a while to actually get used to the release point. You're not alone on this one.
'12 MS3 Black Mica w/ Tech
 Old 11-27-2013, 10:13 AM   #4
Bludypoo's Avatar
Posts: 287   (View Stats)
Bludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the worldBludypoo is the leader of the world
I've been driving manual for almost 10 years since i first received my license. Took the ms3 for a test drive and stalled instantly in the parking lot.
These cars definitely have an interesting clutch, and there is most likely nothing wrong with your car. It's just different than what you are used to. I've had mine since June and have zero problems with it.
Bludypoo is offline   Reply With Quote
 Old 11-27-2013, 05:27 PM   #5
Patty-Wack's Avatar
Posts: 885   (View Stats)
Patty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the worldPatty-Wack is the leader of the world
So glad i happen to read this. I only have had my car for a couple of months and was thinking my clutch was going out of I just suck at driving. My clutch grabs hard and at the top. 1st to 2nd is hard to make smooth sometimes. Sounds like it's a normal thing.
OP, my only 2 cents is that my shifting did seem to improve with new RMM. Sorta clutch related..
Black 2010 MS3 - Non-Tech 281whp/310tq on 92 (v-dyno w/ 1.01 correction)
Corksport 3" Intake l AP v2 l Stage-2 CP-E RMM l Autotech Internals l DDM 35w 5k Hids (Low Beam) l JBR Stage 2 Short Shift Plate Kit w/ Bushings l JBR big Fing Knob l Corksport TMIC l Forge BPV v2 l Stratified E-Tune l Stratified 3-port (Running 2-port) l NGK 1 step Colder plugs l Corksport Test Pipe l DDM 35w 3k Hids (Fogs)
Waiting to install... Prosport Boost Gauge w/ vent pod
Patty-Wack is offline   Reply With Quote
 Old 11-27-2013, 05:33 PM   #6
timjs's Avatar
Posts: 908   (View Stats)
timjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the world
Groaned at 16 Times in 7 Posts
If it's grabbing at the top, something isn't right.
'06 Mazdaspeed 6
timjs is offline   Reply With Quote
 Old 12-02-2013, 08:04 PM   #7
ChaunceyM's Avatar
Posts: 948   (View Stats)
ChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the world
I did the same thing, even after the salesman warned me that the clutch was tricky and alot of people stall it out their first time. I then proceded to over-rev my SpecV on the drive home after getting used to the MS3 clutch.
Corksport: SRI & TIP, Strut Tower Brace, Coilovers
CP-e: RMM
JBR: Rear Sway Bar (with Moog End Links)
TWM: Full Replacement Shifter
Cobb: AP
AutoTech: HPFP Internals
Ebay: Test Pipe
ChaunceyM is offline   Reply With Quote
 Old 12-02-2013, 09:03 PM   #8
jk_ms3's Avatar
Posts: 1,390   (View Stats)
Groans: 40
I was OK with the clutch when I got into my car after I test drove the speed, but the brakes made me panic! I didn't realize how soft the brakes in my Corolla were, and I thought that they'd given out.
On deck: VG Sharkfin Antenna
 Old 11-27-2013, 11:08 AM   #9
JgamB's Avatar
Posts: 2,566   (View Stats)
Same here, mine grabs a bit higher and more abruptly than any other manual car I've owned. It takes a bit of getting used to, but our OEM clutch (from what I've seen on our Nator AL pack of wild animals) can take some substantial abuse.
 Old 11-27-2013, 12:31 PM   #10
Alexander's Avatar
Posts: 841   (View Stats)
Alexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the world
Groaned at 43 Times in 16 Posts
My clutch grabs pretty early and has a lot of pressure on the pedal. But ive seen other speed 3s with a weaker pedal. It just depends
2011 Mazdaspeed 3
Cobb v3 AP | Autotech CDFP | JBR Sri | JBR Balance Shaft Delete | JBR Rear Sway Bar | JBR 88 duro RMM | M2 Testpipe | Corksport Tip | Corksport Short Shifter | Corksport SSP | Corksport Shifter Bushings | Cobb Counterweight | H&R Lowering Springs | Joseph Koni Shocks/Struts | SPC Rear Camber Arms
Alexander is offline   Reply With Quote
 Old 11-27-2013, 01:38 PM   #11
timjs's Avatar
See attachments, get to work. Yes, Mazda wants you to grind your gears on the last inspection. Not gonna hurt anything.
'06 Mazdaspeed 6
The Following User Says Thank You to timjs For This Useful Post:
MPS-06 (06-11-2019)
 Old 11-27-2013, 05:07 PM   #12
Dat8687's Avatar
thanks guys
 Old 11-27-2013, 05:33 PM   #13
boostdmazda3's Avatar
Posts: 1,177   (View Stats)
boostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the world
I actually found the ms3 stock clutch to be very friendly and easy to drive...drive a 6 puck it will have you appreciate the stocker.
Bnr s3/Act 6 puck/sure full 3inch intake/cobb fmic/cobb downpipe/grimmspeed ebc/3 bar map/hks catback/autotech hpfp internals/turbosmart bpv/bc coilovers/jbr trilogy mounts/ngk one step colder plugs/ms6 rims on nt-01 tires. 24 psi E85 freektuned.
Freektuned e85 Focus st as the daily.
boostdmazda3 is offline   Reply With Quote
 Old 11-27-2013, 06:53 PM   #14
OCspeed's Avatar
Posts: 168   (View Stats)
OCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond reputeOCspeed has a reputation beyond repute
Groaned at 7 Times in 5 Posts
Mine grabs around the middle of the pedal while releasing
Definitely took a while to learn and drive smoothly
Self Tuned: 310 HP / 355 TQ on E85 50/50
2012 black speed3 - AP - CxRacing FMIC - COBB SF - COBB TIP - Ebay catless long DP - XS Power Exhaust Manifold - ARK CBE - AutoTech internals - Rotella T6 - JBR 88 Duro RMM - JBR MudFlaps - DevilsOwn M.I. - GFB Respons 50/50 - AEM DryFlow - NGK Step Colder
Instagram @ mpodboj
www.matiaspodbojracing.yolasite.com
OCspeed is offline   Reply With Quote
 Old 11-27-2013, 07:06 PM   #15
jk_ms3's Avatar
Groans: 40
Mine grabs pretty low, and it does take some time to get used to. Even still, after several months, my shifts aren't incredibly smooth when I'm feeling lazy. If I actually try, it's fine.
The Following User Says Thank You to jk_ms3 For This Useful Post:
rymanmazda (11-27-2013)
 Old 11-27-2013, 07:09 PM   #16
cyberb0b's Avatar
Posts: 16   (View Stats)
cyberb0b is just really nicecyberb0b is just really nicecyberb0b is just really nicecyberb0b is just really nice
I have trouble with first to second daily driving. Engine feels like it rocks back and forth. I think I need a RMM. I stalled mine on the test drive. My Mazda 3 had a tricky clutch too.
cyberb0b is offline   Reply With Quote
 Old 11-27-2013, 07:26 PM   #17
Patty-Wack's Avatar
RMM did help with the 1st and 2nd gear rock. My clutch doesn't grab fully at the top but I would say it's past the middle. Has about 2-3 inches worth of grab range if that makes sense. No signs of slipping so i think it's just the car. I'll keep a eye on it and maybe try to drive a fellow Nator's car at next meet to compare.
 Old 11-28-2013, 07:05 AM   #18
timjs's Avatar
You guys should drive an early MS6. The clutch was so hard to get used to for some people that Mazda actually came out with revised parts. Including a revised clutch pressure plate and I believe a pedal assembly as well.
This was for the customers that said "I refuse to accept this" and wouldn't take their cars back.
'06 Mazdaspeed 6
 Old 12-02-2013, 07:09 PM   #19
analbumcover's Avatar
Posts: 152   (View Stats)
analbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant future
+1 on grabbing middle/middle-top and then snapping in. Its more or less clutch engaged, or clutch not engaged. nothing really in the middle.
analbumcover is offline   Reply With Quote
 Old 12-02-2013, 07:15 PM   #20
Status Update's Avatar
Posts: 461   (View Stats)
Status Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the world
Learned how to drive manual in a ms6 and its become second nature ever since but I agree when I drive my friends cars the clutch feel is definitely different.
BMW 335xi 6MT
AR Catless Downpipes///HPF Fmic///BMS DCI///CP-e Chargepipe///Cobb AP V2///Volk TE37sl 18x9.5+22F 18x10.5+20R
2007 BM Mazdaspeed 6 GT #10477
SOLD 8/29/14
Status Update is offline   Reply With Quote
 Old 12-02-2013, 08:26 PM   #21
cobi wan kenobi's Avatar
Posts: 32   (View Stats)
cobi wan kenobi is just really nicecobi wan kenobi is just really nicecobi wan kenobi is just really nicecobi wan kenobi is just really nicecobi wan kenobi is just really nice
Groaned at 37 Times in 6 Posts
Mine grabs high too. I mean really high, like the pedal is almost fully released. 1st to 2nd is a little tricky, but all the other shifts are fine. It doesn't seem right, but I haven't had any problems yet.
cobi wan kenobi is offline   Reply With Quote
Clutch Pedal Engagement radioflyer MazdaSpeed 3 - Engine, Transmission & Driveline 26 01-24-2015 01:02 PM
Weird Clutch Engagement Issue Mfinlay04 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 04-02-2013 11:29 PM
Raising the Engagement Point on my Clutch riott MazdaSpeed 3 - Engine, Transmission & Driveline 30 02-15-2011 07:56 AM
Raising the Engagement Point on my Clutch riott MazdaSpeed 6 - Engine, Transmission & Driveline 0 02-11-2011 06:15 PM
Page generated in 0.41237 seconds with 36 queries
