 Old 02-02-2019, 05:53 PM   #1
Tr33x0rs's Avatar
Posts: 6   (View Stats)
Tr33x0rs is an unknown quantity at this point
Default Clutch Pedal Switch Not Engaging
I drive 2013 Speed3 with the Tech package. For the past week when I try to start the car it's acting as though the clutch pedal isn't pushed in although it is. If I manually go down to my clutch pedal and press the clutch switch and press the start button the car starts.
It appears as though the clutch is traveling 9/10 of the way but isn't traveling that last 1/10th of the way to fully engage the clutch pedal switch. I made sure the switch is fastened into its bracket correctly.
Any ideas would be greatly appreciated. I don't know if we can adjust our clutch pedals or not or why this would happen. I haven't noticed any issues when driving. The clutch doesn't seem to be slipping or anything like that. Thank you in advance for the help.
Tr33x0rs is offline   Reply With Quote
 Old 02-02-2019, 09:01 PM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Is the rubber bumper still on the pedal? They get brittle and break off and the switch is now 1/4" too short.
Google pedal bump stop.
Clutch not engaging while running qMazdaspeed3p MazdaSpeed 3 - Engine, Transmission & Driveline 25 04-07-2018 05:38 PM
Cracked clutch pedal bracket caused pedal to crack firewall which pierced my master cylinder Marcus Mazdaspeed3/6 General Discussion 0 10-17-2015 06:14 AM
Clutch Not Engaging Cheapspeed MazdaSpeed 3 - Engine, Transmission & Driveline 8 10-05-2015 02:41 PM
Oem clutch/Fidanza Flywheel, Causing sticky clutch pedal? Douggievee MazdaSpeed 6 - Engine, Transmission & Driveline 14 05-14-2015 10:44 AM
MS6 clutch pedal Turbosuby Mazdaspeed3/6 General Discussion 10 04-16-2013 08:25 PM
Page generated in 0.22795 seconds with 21 queries
