 Old 11-14-2018, 03:20 AM   #1
Lucid's Avatar
Posts: 23   (View Stats)
Lucid is a jewel in the roughLucid is a jewel in the roughLucid is a jewel in the roughLucid is a jewel in the rough
Default Crank not sitting flush when building engine
Ok, So It seems I have had problem after problem with this engine build. I thought I was finally over the worst and ready to put it together completely. Only after I had my oil pan on and everything tight I noticed whats in these pictures.
The clearance at the top is almost touching the cradle, and at the bottom its damn near 1/8 an inch! I don't know whats going on, Ive gone back at re-seated all the bearings, looked at the crank, everything I could imagine.
I'm using .25 oversized bearings because I had a spun bearing and had to have a machine shop do some work on the block.
Did they somehow screw up the work on the block or something?
I dont even know what they could have got wrong!!! I'm at a total loss here, anybodys help is super appreciated.
Lucid is offline   Reply With Quote
 Old 11-14-2018, 11:22 AM   #2
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
No images.
 Old 11-14-2018, 12:52 PM   #3
Lucid's Avatar
20181114_040944[1].jpg[ATTACH]20181114_040949[1].jpg[/ATTACH]
 Old 11-16-2018, 03:33 AM   #4
Lucid's Avatar
Really? Nobodys got any input?
 Old 11-16-2018, 06:46 AM   #5
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
I didn't snag any pics of my build to compare.
I wish I had enough knowledge to confidently say, "if there's no contact, send it."
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 11-16-2018, 08:29 AM   #6
Posts: 2,235   (View Stats)
not sure if you ask about the engine rack against the crank in the pictures or the crank against the bloc.
For the rack, i had to install some shim with longer bolts for mine to clear the flywheel.
I don't see how machining a crank could make it seat differently from left to right, you don't works against the side but usually just regrind smaller 1 part and most of the time isn't a main but a rod bearing that worn out so it has nothing to do with crank alignement....Unless you did something wrong with the thrust bearing and even there, you would probably not be able to put the other caps on the crank itself....???
i will compare with the one i have in the garage this week end. Maybe is just because it miss the rear seal frame and look too much out...
And it is the original crank from it's own bloc ? Not a ford crank or something ?
And did you plasti-gage your new bearings just to confirm the machining job against bearing itself?
 Old 11-21-2018, 06:02 AM   #7
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Does the crank spin freely in the block? Did you gauge the bearing clearances? Did you measure crank end play?
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 11-21-2018, 07:51 AM   #8
Fstrnyou's Avatar
Ditto. I'd assume if the crank spins free and has proper end play....send it.
Other rides:
History:
Engine Won't Crank nijathomp5 Mazdaspeed3/6 General Discussion 10 01-18-2020 04:25 PM
How To Flush Engine Coolant | Autoblog Wrenched Haltech Automotive News 0 02-01-2017 01:40 PM
Engine Flush? BaggiestPanther MazdaSpeed 3 - Engine, Transmission & Driveline 9 11-27-2016 06:02 PM
Oil and engine flush eaglesct2006 2010 MS3 - Engine, Transmission & Driveline 26 01-01-2015 05:47 PM
Engine Flush? HSpeed3K 2010 MS3 - Engine, Transmission & Driveline 5 05-29-2013 03:17 AM
Page generated in 0.28759 seconds with 25 queries
