 Old 09-26-2018, 04:42 PM   #1
eliwwjd's Avatar
Posts: 518   (View Stats)
Default CS Cams install valve clearance
Ok I’m getting ready to do corksport cams and I know that from engine to engine valve clearance (tappets) can vary but wanted to know from anybody here that has done these cams , what were the tappets range they use to adjust clearance. I know that when I do my install clearance is going to be different but just wanted to have an idea of around what measurements people here experienced in there install
Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS
Valve Tappet Clearance Excel Spreadsheet silvapain MazdaSpeed 3 - Engine, Transmission & Driveline 3 05-11-2018 01:32 PM
VALVE CLEARANCE ADJUSTMENT jaguar_mike CX-7 > Engine, Transmission & Driveline 1 02-08-2016 06:02 PM
Head Rebuild and Valve clearance issues tkephart MazdaSpeed 6 - Engine, Transmission & Driveline 14 10-05-2012 12:46 PM
Page generated in 0.22370 seconds with 20 queries
