Like Tree3Likes
  • 2 Post By Thor Hammer
  • 1 Post By Fstrnyou
 Old 03-18-2019, 07:17 AM   #1
Tru3's Avatar
Posts: 46   (View Stats)
Tru3 is on a distinguished road
Question Downpipe Supporting Mods?
Hey all, what are the required supporting mods to run a aftermarket downpipe safely, BESIDES the HPFP. I already have the HPFP internals. Anything to replace or beware of when upgrading the down pipe? Thanks!
Tru3 is offline   Reply With Quote
 Old 03-18-2019, 07:33 AM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
The tune.
Go read.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 03-18-2019, 07:38 AM   #3
Tru3's Avatar
I already planned on that, just forgot to put it in my OP. thanks!
 Old 03-19-2019, 11:35 AM   #4
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Shift knob.
Jeff23spl and danb like this.
 Old 03-19-2019, 12:03 PM   #5
doublegmoto's Avatar
Posts: 23   (View Stats)
doublegmoto will become famous soon enough
Shift knob.
1. Good intake with filter. 2. blow off valve 3.FMIC . 4.cat back exhaust 5. Rear tranny mount. 6. Shifter kit . 7. Better MAF. Oh I hope your running a high flow cat? Tune as you go.
Sent from my LGMS631 using Tapatalk
doublegmoto is offline   Reply With Quote
The Following 3 Users Say NO Thank You to doublegmoto For This Un-useful Post:
MSMS3 (03-19-2019), Thor Hammer (03-20-2019), Vansquish (03-20-2019)
 Old 03-19-2019, 05:01 PM   #6
Groans: 211
I wasn't serious about the knob.
Nothing you listed is needed. And there is no such thing as a "better MAF".
 Old 03-19-2019, 05:25 PM   #7
Fstrnyou's Avatar
Upgrade your blinker fluid.
What people don't realize is that it works with the EBCS too.
danb likes this.
Other rides:
History:
 Old 03-19-2019, 08:27 PM   #8
Posts: 2,827   (View Stats)
People are trying to tell you, OP, that you need to search and read the multiple threads here and educate yourself, rather than expecting to be spoon fed and remain dumb and dependent.
All modifications are interdependent on each other. Some are not compatible with others. There is no quick one size fits all answer for safe and optimal use of an aftermarket down pipe. You seek a quick answer, grab the first one you hear, do it blindly, blow your engine and then blame others.
Read, study, post your present mods and then ask. Do you have a way to data log and monitor? If not, throwing a down pipe, catted or catless, on who knows what other than having an upgraded hpfp, throwing some unknown “tune” on is likely epic fail.
WTF? Blind leading the blind.
Last edited by MSMS3; 03-19-2019 at 08:27 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-20-2019, 08:30 AM   #9
Police - Grammarhead
Vansquish's Avatar
Hope you've budgeted for a new engine with advice like that.
 Old 03-20-2019, 11:45 AM   #10
Have the same set up myself. 67000 miles no oil burn no catch can no oil valve before turbo original clutch beat on on it at least 5 times a day daily driver installed it at 45000 miles. And your talking nonsense because, THIS IS A COBB STAGE 3 PACKAGE WITH CUSTOM TUNE.
The Following User Says NO Thank You to doublegmoto For This Un-useful Post:
Vansquish (03-21-2019)
 Old 03-20-2019, 03:19 PM   #11
Posts: 2,237   (View Stats)
At your #2 , i was already suspecting that you have no idea of what you are talking about and you confirmed it at .#7 ....
By the way, OP wasn't asking : What else he should install on is car to get more power (or to give more money to cobb) but instead: What are REQUIRED supporting mods....
danb (03-21-2019), Vansquish (03-21-2019)
 Old 03-20-2019, 03:44 PM   #12
Groans: 211
Please tell us more about your blow off valve and expound upon your better MAF. We are dying to hear about how we can improve our resolution.
 Old 03-21-2019, 06:10 AM   #13
Loophole35's Avatar
Posts: 59   (View Stats)
Loophole35 is just really niceLoophole35 is just really niceLoophole35 is just really niceLoophole35 is just really nice
Bet he's using a Toyota MAF.
2008 True Red Mazdaspeed 3
Mod list:
Cobb RMM, TIP, SRI w air box, CBE and AP3
Corksport Short throw plate w/ shifter bushings, TMIC and BPV
CPE catted DP
Tune done by Will at PD-Tuning (still slow need BT)
150k miles on original motor and turbo
H&R sport springs w/ Koni yellows
17x9 +48 6UL with 245/45R17 Flaken Azenis
Loophole35 is offline   Reply With Quote
 Old 03-21-2019, 10:22 AM   #14
Maf is from sure and cobb has a base starting point for tune of this particular maf.
Blow off valve is turbosmart. psi max is 19.5
Last edited by doublegmoto; 03-21-2019 at 10:22 AM. Reason: MSF Database - Automerged Doublepost
Db09ms3 (03-21-2019)
 Old 03-21-2019, 10:36 AM   #15
Blow off valve is a turbosmart. I have boost at 19.5 psi max 11.2 fuel ratio at open throttle. Left timing alone at cobbs stage 3 setting. In a friendly way I live in orlando if your ever down that way love to show you the car. For real ! Because I have always wonderd why I dont burn oil or have had any problems. I dont even have rear motor mount. Maybe my way of driving the car hard isn't enough.Again really I'm always willing to learn. So I apologize for any misunderstanding
The Following User Says Thank You to doublegmoto For This Useful Post:
whatsabrooklyn (09-12-2019)
 Old 03-21-2019, 10:37 AM   #16
Ok i was not aware that Cobb had a joint venture with SU to build an electronic flow meter devices, can you point me out where one can buy it online to see what it look like ?
And according to you, if i plan to run above 19.5psi with a turbosmart bov it wont work? What would happen? the valve will explode ?
 Old 03-21-2019, 10:43 AM   #17
I'll get you both part #s very soon, not with car right now.
 Old 03-21-2019, 11:29 AM   #18
Groans: 211
I think you are just a bit confused. Let me explain.
Your intake is made by Sure Motorsports. They have a very bad reputation in this community for lack of quality and being a shill.
Your MAF sensor is most likely OEM. When you buy the intake you put your OEM MAF back into it. I promise you Sure never made a MAF for our cars. OEM is the only one known to work reliably.
Your Turbosmart can handle much more than 19.5 psi. That's just where your tune is targeting boost pressure.
I would upgrade the rear motor mount. Adds little to no vibes and will make a big difference in how tight the drivetrain feels.
Secondly get a custom E-Tune from one of the tuners on here. Leaps and bounds better than any OTS (off the shelf) map like Cobbs. I'd go with Freektune but I'm loyal like that.
Good luck.
Jeff23spl (03-21-2019)
 Old 03-21-2019, 12:06 PM   #19
Take a minute to thanks Thor Hammer above and understand that it was you, that was talking non-sense (not Vansquish). You challenged an old member about basic stuff that much of us know about...
A free tip is to read some hours on this forum, you will understand a lot of things that isn't shown on Cobb and SU online store website.
 Old 03-21-2019, 02:17 PM   #20
Yes, and thats why I apologized. But I will still get you part numbers. Maybe sure doesn't sell it anymore.Will also take photos.
GT2871r Supporting Mods Khill6674 Mazdaspeed3/6 General Discussion 31 02-19-2013 09:05 PM
Best First Mods To My MS3 - CAI, Downpipe, Exhaust? cocktailfruit MazdaSpeed 3/6 - Turbo Induction 27 12-19-2010 03:58 PM
Page generated in 0.42394 seconds with 28 queries
