 Old 12-16-2018, 04:21 PM   #1
ProChargedLS2's Avatar
Posts: 129   (View Stats)
ProChargedLS2 is a jewel in the roughProChargedLS2 is a jewel in the roughProChargedLS2 is a jewel in the rough
Groaned at 5 Times in 2 Posts
Default Engine knocking, possible VVT issue?
Engine started making this noise after I put it back together from the turbo exploding, comes from the passenger rear side. I got about 100 miles on it before this noise started. Thought it was a heat shield so I took them off one by one, and without any heat shields on it continues to make this noise.
After that my first thought was it's my timing chain. Popped the oil cap off and tried pulling on it, and my chain is tight as hell like it should be. Waited until the following morning to check and the chain is loose because no oil pressure, started it up let it warm up and it's back to being tight.
In every video I've seen of bad VVTs, the car started and has a loud knocking/ticking sound that varies with RPM. Mine is the occasional tick at idle, and doesn't go up in RPM at all. In fact it doesn't make any noise different than idle when I go through the gears. The only other noise is like a metal belt driven fan vibrating sound you'd hear when you let off the gas or push the clutch in.
I can't find the cause of this, every bolt is tight and my belt is tight as it should be when warm.
How much slack should there be when the motor is bone cold? I know it gets its pressure from oil so it will be somewhat loose when the car has been sitting for a while, but idk how loose. I've done a few pulls to get some data, and all of my numbers look fine for the most part being on a base map. No knock, no stray voltage or spikes in anything. No mechanical hiccups driving it, I don't feel it at all, I just hear it every now and then.
Is this an early sign of needing a new VVT kit? I was almost certain I'm fine because I have proper tension in the chain... but now I don't know anymore and can't figure it out.
Upon this rock I will build my church
BNR S4 V3, JMF Intake Manifold, XSP Exhaust Manifold V3, ATP Catless DP, SU TMIC, JBR Tru- 3.5 intake, DM Stage 3 DOCC via route 4, JBR Intake Manifold + Throttle Body Insulating Gaskets, CS EBCS, CS High Pressure Fuel Line, CS HPFP Internals, CS Injector Seals, JBR BSD + Baffle Kit, CS RMM, CS SSB, JBR SSP, Forge BPV, 3 BAR MAP Sensor (for now), DM EGR Delete, NGK 6510 Plugs, DM PCV Plate
TUNEDBYNISHAN!!
ProChargedLS2 is offline   Reply With Quote
 Old 12-16-2018, 06:31 PM   #2
here's the driving sound you hear. It honestly sounds like there's a screw loose, or hell even a socket is lost in the engine bay and vibrating. I've never heard a bad timing chain before, but as tight as mine is I don't think that is the culprit.
I also don't think it's the VVT system because my sound is intermittent, and random(ish). VVT is consistent, so I'd hope it isn't my VVT going. I wouldn't push it past me if it was though, but I just don't think it is because of how random the intervals of the sound is. Took me quite a few tries to get a video of it because it wouldn't tick sometimes.
TUNEDBYNISHAN!!
Knocking/ticking engine at idle piterus MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 09-01-2016 03:43 PM
No more knocking after engine rebuild EmPeEs6 MazdaSpeed 3/6 - ECU Computer Tuning 28 08-31-2014 03:29 AM
Knocking sound from engine rednofive MazdaSpeed 3/6 - Troubleshoot/Diagnostics 20 11-02-2012 09:34 PM
The oh so famous Engine Knocking Mazdagoat324 MazdaSpeed 3/6 - ECU Computer Tuning 7 12-17-2008 03:29 PM
engine knocking under load allmotor95pgt MazdaSpeed 3 - Engine, Transmission & Driveline 100 12-08-2008 10:52 AM
Page generated in 0.26658 seconds with 20 queries
