 Old 04-01-2011, 10:40 AM   #1
TanMan's Avatar
Posts: 48   (View Stats)
TanMan is a jewel in the roughTanMan is a jewel in the roughTanMan is a jewel in the rough
Default Fueling system upgrade
If I want to upgrade my 2011 MS3's fueling system, what options do I currently have for a complete CDFP other than the CP-E item?
Alternatively, will upgrading the in-tank fuel pump or adding an inline fuel pump do the trick?
TanMan is offline   Reply With Quote
 Old 04-01-2011, 11:12 AM   #2
rghispanic88's Avatar
Posts: 3,131   (View Stats)
Groans: 263
perhaps with a bigger turbo, but internals will do the trick if you are bolted with the stock k04
2010 Black Mica
rghispanic88 is offline   Reply With Quote
 Old 04-02-2011, 05:14 AM   #3
Amazon's Avatar
Posts: 2,679   (View Stats)
Groans: 214
Banana peppers tend to go better when chilled raw and with an organically tomato based sauce.
Amazon is offline   Reply With Quote
The Following 2 Users Say Thank You to Amazon For This Useful Post:
ScarMS3 (04-12-2011), Speed3eak (04-03-2011)
 Old 04-02-2011, 10:52 AM   #4
speed14's Avatar
Posts: 527   (View Stats)
speed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the world
Agreed.
2010 Mazdaspeed 3 | Black Mica
COBB AP V3| HTP 3" Intake | CP-E TMIC | UR Turbo Back Exhuast | GS 3-Port EBCS | DO Meth Injection | Autotech Internals | Denso ITV22 | GFB Respons BPV | DDM 6000k lows | 3000k fogs | 18x8 TSW Nurburgrings | 235/40/18 Toyo Proxes | H&R Springs
speed14 is offline   Reply With Quote
The Following User Says Thank You to speed14 For This Useful Post:
 Old 04-02-2011, 11:12 AM   #5
JS + MS3's Avatar
Posts: 1,794   (View Stats)
JS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the world
Groaned at 72 Times in 51 Posts
bacon
2010 Mazdaspeed3
Cobb AP - CP-E SRI - Ultimate Racing TP - CP-E RMM 75D - JBR RSB - JBR SSP - Autotech HPFP Internal - Denso ITV22 - Advan RZ 18x8 (Conti ExtremeContact DW 235/40/18)
JS + MS3 is offline   Reply With Quote
The Following User Says Thank You to JS + MS3 For This Useful Post:
 Old 04-12-2011, 02:48 PM   #6
Spag's Avatar
Posts: 26   (View Stats)
Spag is a splendid one to beholdSpag is a splendid one to beholdSpag is a splendid one to beholdSpag is a splendid one to beholdSpag is a splendid one to beholdSpag is a splendid one to beholdSpag is a splendid one to behold
Originally Posted by JS + MS3 View Post
bacon
No see what you have to do is line the cylinder walls with bacon, the fuel will be so anxious to get in there to get the bacon you wont even have to use a fuel pump, 2500psi+ all the time.
Spag is offline   Reply With Quote
The Following User Says Thank You to Spag For This Useful Post:
JS + MS3 (04-12-2011)
 Old 04-12-2011, 02:57 PM   #7
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
When you're late to the game, even if you feel that you have something clever to say, it is usually best to just let it slide... Fail
Ckmazdaspeed3 is offline   Reply With Quote
The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post:
wolly6973 (04-12-2011)
 Old 04-12-2011, 03:28 PM   #8
Spag's Avatar
10 days is not grave digging, it was still on the first page of that particular section.
 Old 04-12-2011, 03:33 PM   #9
ScarMS3's Avatar
Posts: 2,088   (View Stats)
Groans: 97
Amyl nitrate....YAH MEAN?
 Old 04-12-2011, 04:25 PM   #10
Illmatic MS3's Avatar
Posts: 226   (View Stats)
Illmatic MS3 is the leader of the worldIllmatic MS3 is the leader of the worldIllmatic MS3 is the leader of the worldIllmatic MS3 is the leader of the worldIllmatic MS3 is the leader of the worldIllmatic MS3 is the leader of the worldIllmatic MS3 is the leader of the worldIllmatic MS3 is the leader of the worldIllmatic MS3 is the leader of the worldIllmatic MS3 is the leader of the worldIllmatic MS3 is the leader of the world
huh
2011 Black Mica MS3
CP-E SRI-Forge BPV-Custom CBE-COBB AP-SU RMM-DIY RED TAILS
NATOR NJ
Illmatic MS3 is offline   Reply With Quote
When is it time to upgrade the fuel system??? akbrazil 2010 MS3 - Engine, Transmission & Driveline 30 05-11-2010 12:12 AM
MS3 Fueling Discussion Haltech MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 39 02-23-2009 12:09 PM
Fueling/AFR Discussion dadasracecar Mazdaspeed3/6 General Discussion 13 12-24-2008 09:56 AM
endlink upgrade needed w/ ASB upgrade? red07 MazdaSpeed 3/6 - Suspension & Brakes 12 11-26-2008 01:34 AM
Fueling 06Speed6 Mazdaspeed3/6 General Discussion 1 08-31-2008 03:16 PM
Page generated in 0.30513 seconds with 28 queries
