 Old 06-14-2019, 07:49 PM   #1
intrigueturbo's Avatar
Posts: 53   (View Stats)
intrigueturbo is a jewel in the roughintrigueturbo is a jewel in the roughintrigueturbo is a jewel in the roughintrigueturbo is a jewel in the rough
Default Help with EGR tube front bolt??
Went to clean my EGR valve and EGR tube today. Had a hell of a time getting the tube off and then when I went to put it back on I couldn't get the front bolt to thread in properly. It sits in place and I can turn the bolt but it won't actually thread. Help??
Cobb AP // Stratified Stage 2 Flash Tune // CP-E Nano SRI // Corksport TMIC // AutoTech HPFP Internals // CP-E RMM
intrigueturbo is offline   Reply With Quote
 Old 06-14-2019, 09:25 PM   #2
Police - Grammarhead
Vansquish's Avatar
Loosen up the other end of the EGR tube so that you've got some play, then you should be able to install it.
Front strut wishbone bolt nut size - Info GroceryGtr MazdaSpeed 3/6 - Suspension & Brakes 1 06-15-2018 11:25 AM
Front Endlink Bolt Stuck InvictusFatum 2010 MS3 - Suspension & Brakes 12 07-07-2017 11:00 AM
looking for a trick to loosen front sway bar boushing bolt Jeff23spl MazdaSpeed 3/6 - Suspension & Brakes 8 03-26-2014 12:07 PM
Stripped front RMM bolt thread. Help plz? Tibu MazdaSpeed 6 - Engine, Transmission & Driveline 16 10-27-2012 04:07 PM
Anyone know the bolt size for the front diff mount? Boostlag MazdaSpeed 6 - Engine, Transmission & Driveline 1 06-01-2011 08:15 AM
Page generated in 0.22699 seconds with 21 queries
