  • 1 Post By RallySportDirect
  • 1 Post By sirploppy
 Old 06-04-2013, 04:46 PM   #1
RallySportDirect's Avatar
Posts: 1,452   (View Stats)
Default How-to: CP-E Stage 2 Rear Motor Mount
Yurtle Gets a CP-E Stage 2 Rear Motor Mount
If you would like more product information, you can click any of the images below, or click HERE.
First, let’s give you the rundown about the mount itself.
Mfgr. Warranty: Limited Lifetime Warranty
Color: Black
Durometer: 75A
Material: Aluminum
It is well known that the stock rear motor mount on the MS3 is a weak link and cp-e™ has chosen to think outside the box on this and come up with a completely new design. To do this cp-e™ carefully studied the layout of the stock MS3 Engine Mounts. While designing the side engine mounts it was determined that a better design could be achieved on the rear mount as well.
The way the Mazda engine mount system works is that the two side mounts provide a rotational mounting point, if just these two mounts are installed without a lower engine mount the bottom of the engine is free to swing like a pendulum. Now if you take the stock engine mount and put it in place with its horizontally mounted bushing and you apply some power, it will stop the engine from swinging but you are now stressing the bushing in two directions. These types of bushing are not really meant for this.
So cp-e™ came up with a way to stress the bushing in only one direction, by remaking both sides of the engine mount cp-e™ was able to mount the bushing vertically so now the pendulum affect of the engine is stretching or pushing in only one direction. This also increases the durability of the engine mount substantially.
To accomplish this two blocks of aluminum, starting at 15.81 lbs are slowly whittled down over the course of a couple of hours in our CNC machine to a final weight of 3.53 lbs. This process takes a lot of time but was necessary to give our customers what they want.
Here’s a list of the tools you’ll need to do this yourself:
3/8 ratchet
Sockets: 19mm, 17mm
Wrenches: 19mm
Torque Wrench
Jack, Jack stands, or lift
This is how your mount will come packaged. I am really impressed with CP-E and their attention to detail. Their product packaging is an obvious example of this. You know when a company takes time to package their products this well they really care about what's inside.
When you pull everything out of the box you will be in awe at how badass this mount is. Everyone here was thoroughly impressed when I was opening ours up for the install. CP-E includes awesome color instructions, hardware, a sticker, thank you card and they even have an employee check off each part that goes in the box and initials. I am very impressed with their attention to detail. No one likes being in the middle of a project to find out not everything was included in the package. You won't have to worry about that with CP-E.
This install is very easy and anyone can do it in less than an hour if you include time to get the wheel ramps or jack stands out and the car up on those.
Pull out your sockets, ratchet wrench and box end wrench.
Here is a shot of the stock mount before being uninstalled. Very easy to access all the bolts and no need to worry about supporting the engine when removing this.
Go ahead and pull out the 3 19mm bolts holding the mount to the transmission and the 2 17mm bolts that are left. Set your stock mount in a dark corner of your garage because you will never want to install it after the new ones in.
Prep the new mount by taking the long bolt and putting a washer on it before inserting it through the CP-E mounts.
This part is pretty self explanatory but slide the rear portion of the mount into the crossmember.
Go ahead and toss 1 of the 17mm bolts you just pulled out of the stock unit back in and set the left over one with your factory mount. Install all 3 19mm bolts back into the front portion attaching the mount to the transmission.
The tolerances are very tight and didn't see starting with one bolt versus the other to really matter but you might have to put a little pressure up on the engine to line up a few of the holes before the bolts will go in.
Ensure you take the 2nd washer CP-E includes and put it over the end of the bolt before installing the lock washer and bolt.
Snug up all the bolts.
Grab your torque wrench and set it to 85ft/lbs and torque all 5 bolts down. You will need to grab your 19mm wrench and hold the head side of the bolt while you have the torque wrench on the nut side to get it to 85ft/lbs.
Here is the finished product. This mount looks amazing on the car!
I was a little worried about how much noise and vibration I would get inside the car with this mount but I am very impressed. There is very little at all. Getting in the car and starting it up for the first time with the new mount you can feel the engine starting which I love and then it purrs like a kitten. You will get a little vibration in your rear view mirror but nothing to compared to when I have the stereo turned up.
Pulling out of our shop I could immediately feel a difference. I had urethane inserts in the stock rear motor mount previously which were nice but this CP-E Stage 2 setup is completely different. Steering and gear shift feedback is awesome, much more precise and no jerky 1st gear starts because the engine is rocking with this thing. Previously shifting into 2nd or 4th was a little notchy with the stock mount and inserts but every shift now is super smooth and exact.
This is definitely one if not the first upgrade I would recommend on these cars without a doubt. Very easy installation and for the price you won't regret how much better your car drives.
Enjoy this comparison video:
Thanks,
Tanner
For more information click here:
Jetech likes this.
The Following 6 Users Say Thank You to RallySportDirect For This Useful Post:
802MS3 (06-05-2013), Jetech (06-26-2013), Nliiitend1 (06-05-2013), Onelovesoccer (06-19-2013), SpeedNess (06-06-2013), ToyCop (12-21-2015)
 Old 06-05-2013, 02:21 PM   #2
hsraffety's Avatar
Posts: 106   (View Stats)
hsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud of
Can't wait to pick that up.
hsraffety is offline   Reply With Quote
The Following User Says Thank You to hsraffety For This Useful Post:
RallySportDirect (06-06-2013)
 Old 06-05-2013, 02:45 PM   #3
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
It looks good. Is the part that would be the old rmm solid or is that a poly insert
The Following User Says Thank You to skeeter149 For This Useful Post:
 Old 06-05-2013, 02:47 PM   #4
J.Dy's Avatar
Posts: 109   (View Stats)
J.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond repute
It's solid.
J.Dy is offline   Reply With Quote
The Following 2 Users Say Thank You to J.Dy For This Useful Post:
RallySportDirect (06-06-2013), skeeter149 (06-05-2013)
 Old 06-05-2013, 02:55 PM   #5
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
That video is really cool! Amazing how much movement there is in the drivetrain. Kind of curious what the factory motor mount looks like...
'08 CWP MS3 w/ T3 3071r
 Old 06-05-2013, 04:47 PM   #6
GreyGhost's Avatar
Posts: 315   (View Stats)
GreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the world
+1 I too have the CPE Stage 2 RMM and PMM and love them!
2013 Mazdaspeed 3:
Performance: Autotech Internals // COBB AP // COBB TIP // Cobb Intake & Air Box // COBB FMIC // UR Catted DP V1 // UR CBE // UR Testpipe // Go Fast Bits BPV // Stratified ECBS 2-Port Mode // NGK One Step Colder Plugs // JBR Coolant Bypass Kit // Rotella T6 5w-40 // CP-e Stage RMM // Cp-e PMM // CS Shifrer Plate // Sure Shift Anchors // Redline Plus Hood Struts
VD: 304hp / 333tq Stage 2 91 Octane Freek Tune
GreyGhost is offline   Reply With Quote
The Following User Says Thank You to GreyGhost For This Useful Post:
 Old 06-06-2013, 02:19 PM   #7
Here is a picture of my stock RMM. It even looks like the Gen2 has a slightly better mount than the Gen1 from pictures I've seen of the Gen1.
 Old 06-06-2013, 04:51 PM   #8
We only have a few of these guys left before we run out. THE best mod. I've done yet, you wont' regret it
 Old 06-09-2013, 08:18 PM   #9
sirploppy's Avatar
Posts: 16   (View Stats)
sirploppy is a jewel in the roughsirploppy is a jewel in the roughsirploppy is a jewel in the roughsirploppy is a jewel in the rough
Was on the fence and that video tipped me over. Tired of stock cluncking...
RallySportDirect likes this.
sirploppy is offline   Reply With Quote
The Following User Says Thank You to sirploppy For This Useful Post:
RallySportDirect (06-10-2013)
 Old 06-18-2013, 10:53 AM   #10
To clarify on the vibrations on my way home last night I had the A/C on and the car definitely vibrates more at idle and 1000RPM but with the A/C off it goes away.
 Old 07-14-2013, 01:55 PM   #11
MattStratt's Avatar
Posts: 14   (View Stats)
MattStratt is a glorious beacon of lightMattStratt is a glorious beacon of lightMattStratt is a glorious beacon of lightMattStratt is a glorious beacon of lightMattStratt is a glorious beacon of light
Do you have any left? Website says you're out.
Thnx
MattStratt is offline   Reply With Quote
The Following User Says Thank You to MattStratt For This Useful Post:
RallySportDirect (07-15-2013)
 Old 07-15-2013, 03:21 PM   #12
Thnx
We've been waiting on these from CP-E for a bit now. They are supposed to be arriving here towards end of the month.
The Following User Says Thank You to RallySportDirect For This Useful Post:
MattStratt (07-15-2013)
How-to: CP-E Stage 2 Rear Motor Mount RallySportDirect 2010 MS3 - How-To's 18 11-10-2017 11:26 AM
How-to: CP-E Stage 2 Rear Motor Mount RallySportDirect MazdaSpeed 3 - How-To's 0 06-04-2013 04:43 PM
New stage 2 CP-e rear motor mount peter_parker8740 2010 MS3 - Engine, Transmission & Driveline 210 08-09-2012 09:02 PM
Page generated in 0.37902 seconds with 27 queries
