![]() Join Date: Dec 2014
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Hi, I'm in the process of fighting P0300 in my Mazda. The existing injector filters are failing, and I'm looking to replace them. Any recommendation of what can be used from ebay? Also, anyone is using the GB REMANUFACTURING seals between the injector and the head? I read a few posts about using GB seals between injector and rail but what about injector and the head? Thank you, |
| Not Ranked : 0 score if you search just few minutes here, you will find many threads about injectors seal especially the ones between head and injectors... Some use toyota but the brass sleeve model is a lot better
(Thread Starter) | Not Ranked : 0 score Thank you for your comments. I did search the forum, and I'm aware that you can use Toyota seals or CS sleeves. I'm using Toyota right now, but I was wondering if anyone used GB from the Rockauto kit. Also, what about injector filters. Injectors that I have they have crappy OEM, and they failed — looking to install SS microfilters from eBay. I was wondering if anyone can recommend something or a quality seller. |
![]() Join Date: Nov 2016 Location: AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 550
Groans: 105
| Not Ranked : 0 score GB rockauto seal kit seems to be holding up for one member that I'm aware of. As for the injector screens, you might be best off taking it to an injector specialist and having them flow tested. My local shop replaces the screens with stainless steel mesh.
__________________ Stockish |
| Injector seals - need to replace injector/fuel line O-rings? | TheRealDefman | 2010 MS3 - Engine, Transmission & Driveline | 3 | 03-02-2014 09:35 PM |
