 Old 05-29-2012, 06:16 AM   #361
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
They /should/ be....
You can find these things everywhere. Great example would be marine generators where the small Toyota diesel is one of the most prevalent out there.
Toyota has their toes in several places...
340hp / 371tq
 Old 05-29-2012, 06:51 AM   #362
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
I've notice something after installing these, when I start my car when it's cold, starts up like a champ. Let's say I drive to the mall and make a quick run in and out, when I go to start my car again she struggles a bit, but still fires on the first try. Thoughts? The hotter it is the harder it is to get cranked. But my pressure is fine and I have 0 knock.
tapatalkin on my Nexus
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
 Old 05-29-2012, 08:03 AM   #363
knarfies's Avatar
Posts: 2,568   (View Stats)
knarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the world
i wasnt sure or cant remember if this started afrer the seals but i did notice once in a while when turning over itll sound like its bogging on first fire and then acts as normal. is this similar to what your talking about?
**********************Riding Rainbows Since 1986.**************************
knarfies is offline   Reply With Quote
 Old 05-29-2012, 08:20 AM   #364
Exactly, but only after it's warm
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 05-29-2012, 08:22 AM   #365
knarfies's Avatar
ya i know what you mean. it doesnt happen to me all the time, just randomly. maybe once every 4-5 days.
 Old 05-29-2012, 08:25 AM   #366
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
My car does that as well and I don't have these seals. I think its something in the tuning or setup
 Old 05-29-2012, 08:33 AM   #367
knarfies's Avatar
ya, honestly...i think it started when it started to warm up. i guess tune makes alot of sense too. joel let me know if you figure out a solution or cause : )
 Old 05-29-2012, 08:45 AM   #368
My knee-jerk thought is a fuel pressure issue, but the pump is supposed to prime the system when the drivers door is opened to prevent it....
340hp / 371tq
 Old 05-29-2012, 08:53 AM   #369
Well, it could be a leak that's only recognizable when the pressure just sits in the rail... And none of the "juices" are flowing. It would have to be the tiniest of leaks because my fuel economy is better than ever.
On a cold start the pump will prime a bit more than compared to a warm start right? Or is it always the same?
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 05-29-2012, 08:59 AM   #370
Then again... wouldn't a leak be easily detected by smell?
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 05-29-2012, 09:05 AM   #371
in my scenario it's an issue of fuel returning to the tank when it's supposed to remain at the front of the system & ready to be injected. Not so much a leak to the open air
340hp / 371tq
 Old 05-29-2012, 10:15 AM   #372
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Driver's door?
Where did you read that?
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 05-29-2012, 10:46 AM   #373
I always thought it was turning the key. Same concept though. Shits getting primed, lol.
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 05-29-2012, 10:46 AM   #374
fuck- that was my euros (gti & a4)
Key turn in the speed6 primes the system
340hp / 371tq
 Old 05-29-2012, 06:17 PM   #375
What brought you to this conclusion?
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 05-29-2012, 06:41 PM   #376
Just a knee-jerk response to symptoms which are similar to other, older vehicles that would exhibit the same symptoms. Not a single one of them was direct injection, so I have no direct tie-in.
Tho, now that I think about it, old school vapor lock is a better match to the base symptoms- good cold start, poor warm start. Any drain back or system prime is more of a cold start thing I suppose.
340hp / 371tq
 Old 05-29-2012, 07:17 PM   #377
knarfies's Avatar
not to throw a wrench in your theories but mine did it while cold this morning. (shrug ) i dont think its anything to worry about i suppose
 Old 05-29-2012, 07:49 PM   #378
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
It could be a form of vapor lock (in the way that not enough fuel is being sprayed before spark due to the heat/pressure of the fuel), but I hope you understand that the fuel systems on these cars are returnless.
 Old 05-29-2012, 08:21 PM   #379
I know it's not considered a return system, but I imagine he's referencing the fuel rail valve back to the hpfp.
So should this get chalked in the No Big Deal category?
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 05-29-2012, 08:31 PM   #380
Thanks, but no, I was thinking good ol' fashioned return.
Happy to own up to being wrong. Just want to trigger ideas/conversation on the problem
340hp / 371tq
 Old 05-29-2012, 09:26 PM   #381
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
intank pump hurting?
'08 CWP MS3 w/ T3 3071r
 Old 05-30-2012, 05:06 AM   #382
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
^I thought that initially. Is there adirect replacement to our? Maybe an avo or walbro?
 Old 05-30-2012, 07:16 AM   #383
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
That;s unlikely to be caused by the injector seals. if the injectors are sealed properly it doesn't really matter if you do it with chewing c^Hgum or you weld them in. The jerky startup is most probably fuel/ignition related (meaning that you need to check the plugs and/or monitor the FRP during these startups and log it along with a few other params).
Als keep in mind that during cold startups the engine speed goes up to 1750 (which means also higher fuel rail pressure) and after that much time the spark plugs are also dry. After a short drive the condensation resulted during the engine heat-up may still be there (and if you notice this symptom only after short drives preceeded by a cold start it's most probably condensation related).
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 07-18-2012, 09:00 AM   #384
fredricktsang's Avatar
Posts: 459   (View Stats)
fredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the world
any long term reports on these seals?
fredricktsang is offline   Reply With Quote
 Old 07-18-2012, 09:21 AM   #385
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
not long term but I have about 5K on mine with a ton of WOT at just under 400WTQ. I left my insulator foam out and can see the injectors and there is no carbon or fuel seeping out as of yet.
 Old 07-18-2012, 10:32 AM   #386
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
I just wiped the majority of injector seals from the Chicago distribution center haha. 16 seals should be here tomorrow!
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 07-18-2012, 10:37 AM   #387
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
¿Why you haz so many?
Tapadatass
 Old 07-18-2012, 10:44 AM   #388
Eth Fiend
phate's Avatar
2 6's to build and backups in case I screw them up haha. If nothing else, nator folks will have them available.
-06 MS6
 Old 07-18-2012, 11:56 AM   #389
daztdMS6's Avatar
Posts: 214   (View Stats)
daztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond repute
Mines are going in on Friday....
MazdaSpeed 6
DashHawk, CorkSport TIP & SRI, CorkSport TMIC, SU RMM, CPE rear diff mount, Perrin EBCS, TurboSmart BPV, TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, JBR EGR deletion & TIG, silicone boost tubes, Bilstein HD shocks, LED light bulbs, TRS clear projectors, 35W DDM Tuning HID foglights, Hawks HPS brake pads, Amsoil in the rear diff, pto & trans, factory navi, XCarLink USB.
daztdMS6 is offline   Reply With Quote
 Old 07-18-2012, 01:02 PM   #390
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
@paveltol should be able to tell you the best, since in the OP he says they're already installed in multiple high power cars. unless you're going to start a second cold war and say you don't trust the russians.
it's fun to do bad things
 Old 07-18-2012, 01:54 PM   #391
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
sneaky fuckin russian...
 Old 07-18-2012, 01:57 PM   #392
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
You trust the Russians?
I was unaware there was long term use from the Toyota Seals, I was just told that they are a cheap alternative.
Pickles Tune in progress
 Old 07-18-2012, 03:16 PM   #393
Trail of Fail
Dano's Avatar
yes they are first
Sputnik and now Toyota seals in the Mazda DISI
 Old 07-18-2012, 03:32 PM   #394
fooqr's Avatar
Posts: 559   (View Stats)
fooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the world
Russia had Sputnik, we countered with the internet.
Now the Russians have upped the ante with these Toyota injector seals, and the ball's back in our court once again.
Nicely played, comrades. Nicely played.
Sent from my DROID2 using Tapatalk 2
08 MS3 GT (SSM). JBR WP intake, CS boost tubes, Forge v2 BPV, JBR TB/IM TIG, JBR TB coolant bypass, JBR EGR block-off, 3-bar MAP, PTP pill, bnoon bolt, SM OCC (MD kit) w/ Kat's heater, UR DP (ceramic cat), UR resonated TP/CBE, JBR SSP, SU shift bushings, JBR trilogy mounts (CRMO 88 RMM, 70 PMM/TMM), Koni yellows, JBR RSB, 2nd Fiamm, Stoptech SS lines, Hawk HPS, spin-on CX-9 oil filter, Fumoto valve, PP 5W-30, XT-M5-QS, tints, clear bra, Continental DWS, ITV22, DashHawk, AP, AT internals
There are no stupid questions, but there are stupid people and some of them ask questions.
- A. Funicello
fooqr is offline   Reply With Quote
The Following User Says Thank You to fooqr For This Useful Post:
Bexar (10-12-2017)
 Old 07-18-2012, 09:49 PM   #395
Groans: 549
the russians countered with toyota? my brain just melted.
 Old 07-18-2012, 10:25 PM   #396
fooqr's Avatar
You see? It was so far out of the box we never saw it coming, never had a chance. Brilliant!
- A. Funicello
 Old 07-19-2012, 02:28 AM   #397
DiGi Faggot's Avatar
Posts: 1,212   (View Stats)
Groans: 148
Installed mine GTG. Engine compression stayed the same. Dont know if its been mentioned. These seals look like they crush when you install them.
 Old 07-25-2014, 08:34 PM   #398
Marcus's Avatar
Posts: 777   (View Stats)
Marcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the world
I realize it's old any long term issues from using the Toyota seals?
I ordered some but just received conflicting info they score / ident the block. Would like to know before I go ahead and install.
2006 Moist Metallica Silver Speed6 GT #6557 @ 267,000km
Leakdown results was 50% or more across all four. slow rebuild in progress
Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses.
Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB.
SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate.
Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs.
To order: Fullrace Exhaust Mani. FMIC. Damond side mounts. New built motor. Still thinking about Flowmasters
Marcus is offline   Reply With Quote
Injector seals solution. paveltol 2010 MS3 - Fuel, Nitrous & Water Injection 404 11-22-2016 03:39 AM
Injector seals solution. Version B paveltol MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 463 11-12-2016 09:30 AM
Injector seals essejkcamraw MazdaSpeed 3/6 - Turbo Induction 703 05-17-2011 09:12 PM
Page generated in 0.54560 seconds with 40 queries
