 Old 11-26-2010, 06:18 AM   #1
Default JBR Heavy Shift Knobs Back In Stock!!
Weighing in at a blistering 650 grams (compared to the stock 265 grams for the speed3 and speed6), this heavy Shift Knob allows for smooth shifts by putting the weight at the end of the shift lever. This gives you greater mechanical advantage and lets the stick glide into gear. Powder coated in Wrinkle Black or Wrinkle Red for superior grip. This is a must for any enthusiast.
4 Color Combinations!!
Thanks,
Jamie
The Following 13 Users Say Thank You to JBR For This Useful Post:
Aetherfury (11-26-2010), Amazon (11-26-2010), AndersonGT (11-28-2010), BLK_MS3 (11-26-2010), Dash08 (11-26-2010), fywdyl (11-26-2010), jwilkins88 (11-26-2010), Monotonous ONE (11-26-2010), Nataphen (11-26-2010), neotide87 (11-26-2010), novice_01 (12-02-2010), PiKA West (12-02-2010), redblur (11-27-2010)
 Old 11-26-2010, 07:23 AM   #2
3Sleeper's Avatar
Posts: 136   (View Stats)
3Sleeper is the leader of the world3Sleeper is the leader of the world3Sleeper is the leader of the world3Sleeper is the leader of the world3Sleeper is the leader of the world3Sleeper is the leader of the world3Sleeper is the leader of the world3Sleeper is the leader of the world3Sleeper is the leader of the world3Sleeper is the leader of the world3Sleeper is the leader of the world
Just ordered J! Thanks!
BRY H
2010 MS3 Velocity Red Mica W/Tech & Down Syndrome
BNR S3 Slug - COBB 3 Port EBCS - Bosch 3 Bar MAP
JBR 3.5 WideMouth - Corksport Battery Box - UR DP
ETS TMIC 3.50' - Forge BPV GEN 2/REV 2 - UR Test Pipe
JBR Eliminator Shift Knob (black w/red) - JBR Short Shift Plate Kit (red)
JBR Solid Shifter Bushings GEN2 - JBR Rear Sway Bar (black)
JBR 70 Passenger & Trans Motor Mounts - JBR OCC Stage 2 w/ Check Valve
Whiteline Rear Swaybar Endlinks - Dogbone RMM - 6K HID's
KONI Yellows (Dutch Pride) - CorkSports Aluminum Skid Plate
AutoTech HPFP - NGK (6510) LTR7IX-11 Iridium IX
Rally Armor Mud Flaps....Protecting Da Paint! - Cobb AccessPORT
Custom E-Tune done by RichTune.... Go Fast or Go Home.....
3Sleeper is offline   Reply With Quote
The Following User Says Thank You to 3Sleeper For This Useful Post:
JBR (11-26-2010)
 Old 11-26-2010, 07:45 AM   #3
jwilkins88's Avatar
Posts: 3,675   (View Stats)
Groans: 126
Boys and girls... This is the real deal... Been using this in my car for a little while now, and it's fantastic. I love Jamie's knob
The Following 3 Users Say Thank You to jwilkins88 For This Useful Post:
gtarman77787 (11-26-2010), JBR (11-26-2010), Nataphen (11-26-2010)
 Old 11-26-2010, 07:58 AM   #4
kabobulate's Avatar
Posts: 1,146   (View Stats)
kabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the world
I love Jamie's knob
hmmm
2012 CWP MS3: Tuned by Phate - 50/50 E85 | Cobb AP | SURE Intake, TIP | Corksport Racepipe, TMM Inserts | ITV22's | AT Intl's | ACT Sprung 6Puck & Prolite Flywheel | CP-E Stg2 RMM | JBR SSB, EGR Plate
2008 Silver MS3: Sold
kabobulate is offline   Reply With Quote
The Following 3 Users Say Thank You to kabobulate For This Useful Post:
gtarman77787 (11-26-2010), JBR (11-26-2010), jwilkins88 (11-26-2010)
 Old 11-26-2010, 08:12 AM   #5
Amazon's Avatar
Posts: 2,679   (View Stats)
Groans: 214
Jamie,
Does your knob screw on farther down the shaft than my stock knob does?
Amazon is offline   Reply With Quote
The Following User Says Thank You to Amazon For This Useful Post:
JBR (11-26-2010)
 Old 11-26-2010, 11:04 AM   #6
Big Titty Sucker
BLK_MS3's Avatar
Posts: 1,612   (View Stats)
BLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the world
Groans: 139
Originally Posted by Amazon View Post
Jamie,
I would like to know the same.
BLK_MS3 is offline   Reply With Quote
The Following User Says Thank You to BLK_MS3 For This Useful Post:
JBR (11-26-2010)
 Old 11-26-2010, 11:22 AM   #7
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
this is a real nice knob job here
will be ordering eventually...when i haz monies
black with red numbering is best...obviously
JBR (11-26-2010)
 Old 11-26-2010, 11:39 AM   #8
AJ713's Avatar
Posts: 291   (View Stats)
AJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the worldAJ713 is the leader of the world
WOOT! thanks jamie! just ordered a red/red one....
~AJ
AJ713 is offline   Reply With Quote
The Following User Says Thank You to AJ713 For This Useful Post:
JBR (11-26-2010)
 Old 11-26-2010, 12:30 PM   #9
Jamie,
All the way down in to the boot. No knob can go farther than that.
Thanks,
Jamie
Originally Posted by wolly6973 View Post
So this is still all metal on the outside? I need something that doesn't turn into a freakin ice cube in the winter...
Yes...All metal but the wrinkle finish helps a wee bit.
Thanks,
Jamie
Last edited by JBR; 11-26-2010 at 12:30 PM. Reason: MSF Database - Automerged Doublepost
AJ713 (11-26-2010), wolly6973 (11-26-2010)
 Old 11-26-2010, 08:17 AM   #10
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
The Following User Says Thank You to wolly6973 For This Useful Post:
JBR (11-26-2010)
 Old 11-26-2010, 08:18 AM   #11
jwilkins88's Avatar
Groans: 126
Simple solution... Have your girl come out and sit on it before you get in the car in the morning. Voila! Warm knob!
gtarman77787 (11-26-2010), JBR (11-26-2010), neotide87 (11-26-2010)
 Old 11-26-2010, 08:24 AM   #12
dizzydtrain's Avatar
Posts: 2,476   (View Stats)
Groans: 64
That knob makes the shifter look a lot like a chode. I might have to give this one a try.
dizzydtrain is offline   Reply With Quote
The Following User Says Thank You to dizzydtrain For This Useful Post:
JBR (11-26-2010)
 Old 11-26-2010, 09:34 AM   #13
NCZ13's Avatar
Posts: 1,268   (View Stats)
ffffffffffffffffffffffffffffffffffffffffffffffffff fffuuuuuuuuuuu
cant decide on color.
am I brave enough to rock the red?
2008 Cosmic Blue Mazdaspeed3
1986 Mazda RX7
The Following 2 Users Say Thank You to NCZ13 For This Useful Post:
 Old 11-26-2010, 09:43 AM   #14
NCZ13's Avatar
scratch that
just ordered wrinkle black w/ red shift pattern AND shifter bushings.
JBR the shopping car wouldnt let me add two items to the cart, so I did two separate orders.
Ive been waiting awhile for you to release your knob to the public again.
1986 Mazda RX7
The Following User Says Thank You to NCZ13 For This Useful Post:
JBR (11-26-2010)
 Old 11-26-2010, 09:57 AM   #15
snailD's Avatar
Posts: 3,039   (View Stats)
it's been getting around regardless....
JBR (11-26-2010)
 Old 11-26-2010, 10:00 AM   #16
NCZ13's Avatar
I just cant wait to get my hands on it.
1986 Mazda RX7
JBR (11-26-2010)
 Old 11-26-2010, 11:30 AM   #17
Speed3eak's Avatar
Posts: 2,290   (View Stats)
Groans: 82
God damnit jamie... I'm powerless against this shit.
Are these height adjustable?
The Following User Says Thank You to Speed3eak For This Useful Post:
JBR (11-26-2010)
 Old 11-26-2010, 01:36 PM   #18
BeeZaa's Avatar
Posts: 267   (View Stats)
BeeZaa is the leader of the worldBeeZaa is the leader of the worldBeeZaa is the leader of the worldBeeZaa is the leader of the worldBeeZaa is the leader of the worldBeeZaa is the leader of the worldBeeZaa is the leader of the worldBeeZaa is the leader of the worldBeeZaa is the leader of the worldBeeZaa is the leader of the worldBeeZaa is the leader of the world
Damn it, I just bought an E4 performance knob on the 14th (which has still yet to come, got paypal involved, and finally got a tracking #) I would have bought this though, does the powder coating help keep it from getting hot during summer?
BeeZaa is offline   Reply With Quote
The Following User Says Thank You to BeeZaa For This Useful Post:
JBR (11-27-2010)
 Old 11-26-2010, 01:43 PM   #19
gtarman77787's Avatar
Posts: 1,872   (View Stats)
gtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the worldgtarman77787 is the leader of the world
Groans: 444
Groaned at 154 Times in 97 Posts
Yes...All metal but the wrinkle finish helps [prevent the knob from being hot] a wee bit.
Thanks,
Jamie
beezaa... you're killin me
gtarman77787 is offline   Reply With Quote
The Following 2 Users Say Thank You to gtarman77787 For This Useful Post:
JBR (11-27-2010), sellers (11-26-2010)
 Old 11-26-2010, 02:11 PM   #20
Nataphen's Avatar
Posts: 2,704   (View Stats)
Very nice, Jaimie, I've never known about these before today. I already have a 600 gram, or else I'd give you monies. I'll be ordering your RSB soon for sure though!
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
The Following User Says Thank You to Nataphen For This Useful Post:
JBR (11-27-2010)
 Old 11-26-2010, 05:38 PM   #21
Speed3eak's Avatar
Groans: 82
So...
Not height adjustable? Or height adjustable?
JBR (11-27-2010)
 Old 11-26-2010, 05:49 PM   #22
oh10speed3's Avatar
Posts: 1,119   (View Stats)
oh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the world
Groaned at 74 Times in 30 Posts
What does one of these run? Phone won't let me access the site
Sent from my Droid using Tapatalk
//Stage 1 & Done\\
oh10speed3 is offline   Reply With Quote
The Following User Says Thank You to oh10speed3 For This Useful Post:
JBR (11-27-2010)
 Old 11-26-2010, 06:01 PM   #23
AJ713's Avatar
Holy Shit...Knob shipped acouple hours after I placed my order.....
Jamie, you don't by chance work for the US Postal Service do you? Carry a gun, too?
Many Thanks !!!!
~AJ
JBR (11-27-2010)
 Old 11-26-2010, 06:44 PM   #24
Groans: 444
$70 shipped
The Following User Says Thank You to gtarman77787 For This Useful Post:
JBR (11-27-2010)
 Old 11-26-2010, 06:53 PM   #25
Aetherfury's Avatar
Posts: 1,227   (View Stats)
Aetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the world
Man, you are really churnin' out more stuff now Jamie! Keep it up!
Maybe he rents an apartment above the post office and just has a hole in the floor he jams his knob down when he wants to ship it.
I drive a white car with a HUGE spoiler
Cobb Accessport Stage 1 + Cobb SF Intake
Aetherfury is offline   Reply With Quote
The Following User Says Thank You to Aetherfury For This Useful Post:
JBR (11-27-2010)
 Old 11-26-2010, 06:51 PM   #26
oh10speed3's Avatar
Originally Posted by gtarman77787 View Post
$70 shipped
Thank you
//Stage 1 & Done\\
The Following 2 Users Say Thank You to oh10speed3 For This Useful Post:
gtarman77787 (11-27-2010), JBR (11-27-2010)
 Old 11-26-2010, 07:08 PM   #27
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
i actually like that...
are they threaded?
or does one have to deal with the dreaded set screws?
JBR (11-27-2010), Speed3eak (11-26-2010)
 Old 11-26-2010, 07:50 PM   #28
3Sleeper's Avatar
Within an hour it already shipped... Soon my grubby paws will be all over JB's knob....
I can't wait.... Thanks bro!
BRY H
The Following 2 Users Say Thank You to 3Sleeper For This Useful Post:
JBR (11-27-2010), jwilkins88 (11-27-2010)
 Old 11-26-2010, 09:36 PM   #29
jwilkins88's Avatar
Groans: 126
are they threaded?
Threaded motherfucker. Jamie's knob is threaded. Wait till you feel his knob in your hand.
The Following 2 Users Say Thank You to jwilkins88 For This Useful Post:
JBR (11-27-2010), phillyb (11-27-2010)
 Old 11-26-2010, 10:12 PM   #30
sellers's Avatar
Posts: 1,280   (View Stats)
sellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the world
Groans: 546
Groaned at 125 Times in 71 Posts
I felt one tonight, its a really nice knob.
sellers is offline   Reply With Quote
The Following 2 Users Say Thank You to sellers For This Useful Post:
 Old 11-26-2010, 10:38 PM   #31
neotide87's Avatar
Posts: 1,388   (View Stats)
neotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the world
+1 jamie on the new knobs. Now that is 2 things in a week I have looked at changing on my holiday list and it is like 60$ cheaper than the TWM big type r I was gonna get too! Well done again!
2007 Mazdaspeed 3 Sport SSM
Corksport SRI / HPFP Internals / Front Arm Bar // Cp-e RMM 75d // JBR RSB / IM & TB Gaskets / Bypass Valve Hose // Cobb AP / Shifter Weight // SU Shifter Bushings // Sure TIP // Viper 5901
neotide87 is offline   Reply With Quote
The Following 2 Users Say Thank You to neotide87 For This Useful Post:
 Old 11-26-2010, 11:04 PM   #32
3Sleeper's Avatar
I haven't had a threaded knob in years so this will be one heck of a treat....
And nonetheless it's JB's Knob.... I'll let you know when I get it Jamie (knowing I'll love it anyway)
BRY H
 Old 11-26-2010, 11:37 PM   #33
oh10speed3's Avatar
What color?????
I'm torn between the black/red and the red/red
 Old 11-27-2010, 12:33 AM   #34
jwilkins88's Avatar
Groans: 126
What color?????
Black/Red = Classy and sexy
JBR (11-27-2010), neotide87 (11-30-2010)
 Old 11-27-2010, 12:44 AM   #35
regulator84's Avatar
Posts: 325   (View Stats)
regulator84 has disabled reputation
Just ordered my Black/Red!
Now I wait patiently for the release of the RSB.
2011 STi | Stage 2
[SOLD] 2010 Black Mica | CS SRI + TIP | JBR SSP | TRZ RMM | OCC | DDM 6000k 35w |
regulator84 is offline   Reply With Quote
The Following User Says Thank You to regulator84 For This Useful Post:
JBR (11-27-2010)
 Old 11-27-2010, 01:04 AM   #36
BeeZaa's Avatar
If the RSB gets positive reviews, I will be buying one for sure.
JBR (11-27-2010)
 Old 11-27-2010, 02:12 AM   #37
801MS3's Avatar
Posts: 453   (View Stats)
801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world801MS3 is the leader of the world
Groans: 30
Fucking amazing Jamie.. Well done!
Now i need to sell the e4 one i got from you to get this...
08.5 MS3- : ATP GT3071r: cp-e XL intake: cp-e big inlet: cp-e rmm 75 Duro: cp-e e-flex motor mounts : cp-e catted down pipe: cp-e cbe,: cp-e FMIC, cp-e HPFP: cp-e safe seals : DNP Manifold: COBB AP: COBB RSB: DO stg 2 meth kit ,: SURE TIG's, : KW V2 coilovers: Konig Milligram 18x8.5 +35, Hankook ventus evo's 235/40/18, Saitek adj endlinks :HKS BPV: TWM STS:
465whp 468 wtq Best e.t 11.9 Best trap 123mph
801MS3 is offline   Reply With Quote
The Following User Says Thank You to 801MS3 For This Useful Post:
JBR (11-27-2010)
 Old 11-27-2010, 04:42 AM   #38
Thanks for the overwhelming response guys. I'm very pleased with how they came out. Took me a bit longer then I would have hoped to get them finished but it appears it was worth the extra effort.
The knobs are threaded and height adjustable too.
Thanks,
Jamie
regulator84 (11-27-2010), Speed3eak (11-27-2010)
 Old 11-27-2010, 10:45 AM   #39
redblur's Avatar
Posts: 1,083   (View Stats)
redblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the world
Groans: 46
Just ordered up one of these bad boys for my GenuPu. Black with red bitches!
|2010 VRM Speed3|
|CS SRI/TIP/TMIC|UR CBE/TP|CP-E HPFP|COBB AP Stg2 FREAKTune|SU BPV|TRZ MM|ITV22's|
redblur is offline   Reply With Quote
The Following User Says Thank You to redblur For This Useful Post:
JBR (11-27-2010)
 Old 11-27-2010, 12:59 PM   #40
Speed3eak's Avatar
Groans: 82
For sure getting one now that I know it's height adjustable - I love that it's 650 (!) grams, but I like to have my shift knob raised up to give some more clearance for the cup holders, and to make it easier/quicker to grab when I'm driving.
Would you combine shipping if I were to get a RSB and a shift knob at the same time?
JBR (11-27-2010)
JBR 6 Speed Shift Knobs In Stock!! JBR JAMES BARONE RACING 98 12-31-2014 10:56 AM
JBR Heavy Shift Knobs Back In Stock!! JBR MazdaSpeed 3 - Engine, Transmission & Driveline 58 03-09-2011 04:12 AM
JBR Heavy Shift Knobs Back In Stock!! JBR MazdaSpeed 6 - Engine, Transmission & Driveline 10 12-29-2010 05:23 AM
shift knobs barcainho MazdaSpeed 3 - Engine, Transmission & Driveline 23 04-16-2009 08:44 PM
Page generated in 0.59497 seconds with 43 queries
