 Old 10-26-2019, 03:19 PM   #1
Rklamb2008's Avatar
Posts: 5   (View Stats)
Rklamb2008 will become famous soon enough
Default Mazdaspeed leaking coolant from pipe behind thermostat
Hello guys first time poster. I just recently swap engines in my speed 3 and I been having an issue with coolant leaking down the block of my engine. Originally I thought it was my thermostat, then the hoses. I replaced all of those and I'm still leaking. So I rented one of those cylinder cameras and realized it was leaking where the pipe curves. Can this pipe be fixed or replaced.
Rklamb2008 is offline   Reply With Quote
 Old 10-26-2019, 03:54 PM   #2
Rklamb2008's Avatar
Quick Video
 Old 10-29-2019, 07:40 AM   #3
Rklamb2008's Avatar
Ok for anyone that end up having this issue. I link the part number at the bottom. Some how mine had a pin hole in it and it was a pita to get out. Hopefully I can get this one back in with no leaks.
https://www.onlinemazdaparts.com/p/M...LF0115271.html
The Following User Says Thank You to Rklamb2008 For This Useful Post:
cyclist20 (10-29-2019)
Coolant temp, thermostat hahaitzskippy CX-7 > Issues & Troubleshooting 8 06-28-2014 05:54 AM
Coolant temperature issue. Thermostat? 08cosmic3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 24 08-10-2013 04:22 PM
Coolant leaking, please help jbmazda6 MazdaSpeed 3 - Engine, Transmission & Driveline 17 07-03-2012 05:20 AM
Coolant Thermostat Install help? Scribbles MazdaSpeed 3 - Engine, Transmission & Driveline 7 06-11-2011 03:16 PM
getting dtc:P0126 Coolant thermostat stuck open ON 2 Thermostat dixie789456 MazdaSpeed 6 - Engine, Transmission & Driveline 4 06-08-2010 10:52 AM
Page generated in 0.23702 seconds with 21 queries
