  • 1 Post By aaronc7
 Old 12-11-2009, 09:14 AM   #1
Dre
Dre's Avatar
Posts: 1,651   (View Stats)
Dre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the world
Groans: 48
Groaned at 16 Times in 14 Posts
Default Motor Mount Inserts vs. Rear Motor Mount Pro's n Con's
Heard, and felt, my engine hit the firewall today during a hard launch and it worries the shit outta me.. I've noticed there's Inserts and actual replacements, but which is better and why? I know most people have the RMM, but I'd like the hear the reasons why.. And what are the benefit of using the inserts over the replacement mounts, if there are any?? Thanks!!
"Pain? I ain't got time for pain.. Only pain I got time for is the pain i put on fools who don't know what time it is."
-TTT
Dre is offline   Reply With Quote
 Old 12-11-2009, 09:16 AM   #2
banditscout's Avatar
Posts: 783   (View Stats)
banditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the world
Groans: 50
I'm putting my inserts in today, so I'll let you know what I think...but most folks say that the inserts don't hold up too well. Yes, they're a third the cost, but they probably won't last for more than a few months. I'd go ahead and buy the full rear motor mount, and save myself the hassle.
banditscout is offline   Reply With Quote
The Following User Says Thank You to banditscout For This Useful Post:
Dre (12-11-2009)
 Old 12-13-2009, 09:36 AM   #3
badams118's Avatar
Posts: 821   (View Stats)
badams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the world
Groaned at 126 Times in 71 Posts
Try some 3M window weld. Let it cure ~3 days in warm weather/heated garage.
2011 WRX | Cobb AP | Cobb DP | SPT CBE | AEM CAI
Whiteline F/R Sways | SPT SSK | TWM M1 Abrams
badams118 is offline   Reply With Quote
 Old 12-13-2009, 09:44 AM   #4
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
Why mess with inserts when the new MM is prolly designed a lot better. It's like using a bandaid to cover a gaping wound....IMHO of course.
What a lovable bunch we are!!
 Old 12-13-2009, 10:44 AM   #5
JS + MS3's Avatar
Posts: 1,794   (View Stats)
JS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the world
Groaned at 72 Times in 51 Posts
I heard it hitting the firewall once when I accidently turn on the engine when the car was left in 1st gear. It was scary, I though I hit something really hard.
JS + MS3 is offline   Reply With Quote
 Old 12-13-2009, 10:50 AM   #6
andrew88's Avatar
Posts: 36   (View Stats)
andrew88 has a spectacular aura aboutandrew88 has a spectacular aura about
Groaned at 20 Times in 3 Posts
get trz rear mm and tranny mount.. you wont be disappointed. makes car much more fun to drive
andrew88 is offline   Reply With Quote
 Old 12-13-2009, 10:54 AM   #7
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
inserts are a temp solution. i had inserts, i felt the difference for a little then i felt like i didnt have inserts anymore...just go with a RMM from jump street
2015 Mazda 6
The Following User Says Thank You to IshiKage For This Useful Post:
Dre (12-13-2009)
 Old 12-13-2009, 11:23 AM   #8
WVDPS643's Avatar
Posts: 66   (View Stats)
WVDPS643 is a splendid one to beholdWVDPS643 is a splendid one to beholdWVDPS643 is a splendid one to beholdWVDPS643 is a splendid one to beholdWVDPS643 is a splendid one to beholdWVDPS643 is a splendid one to beholdWVDPS643 is a splendid one to behold
Anyone running the turbine tech mm?
WVDPS643 is offline   Reply With Quote
 Old 12-13-2009, 11:40 AM   #9
Dre
Dre's Avatar
Groans: 48
Thanks for the input everyone.. I was gonna go for the inserts, but why waste time and $$ cuz eventually ill want the RMM.. 240mazspd3 is the Mace Windu of these forums btw
-TTT
 Old 12-13-2009, 11:54 AM   #10
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
You're gonna want to get the replacement MM. I have the CS inserts right now. I like them. They're a very subtle change. They do help, but not like a whole new mount will.
Stay away from delrin mounts unless you want all that vibration and noise.
this forum serves 2 purposes
The Following User Says Thank You to Dash08 For This Useful Post:
Dre (12-15-2009)
 Old 12-13-2009, 02:36 PM   #11
Had the CS inserts. Nice improvement and no extra vibration. Now I have the CP-E mount. Definitely extra vibration but better response as well. Increasing idle RPM to 850-900 helps when the A/C is on.
 Old 12-13-2009, 03:29 PM   #12
erod550's Avatar
Posts: 467   (View Stats)
erod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the world
I don't get why people complain about vibrations so much. With completely solid mounts, not polyurethane like the ones most people have here, I only noticed the vibrations in my SRT-4 at a stop light with the AC on. If you're that sensitive about vibrations, why not just leave your car completely stock. Then it will be extra smooth for you. Me, I will give up a little bit of comfort to make the car perform better. It's not like these cars have a super smooth ride anyway. Better not get stiffer springs cause then I will feel more bumps in the road. Why didn't you get a Lincoln Town Car if you wanted a cushy ride?
This is not directed at any one person. Just a general rant about all the whining about vibrations.
2011 Mustang GT Premium 5.0
2009 True Red Mazdaspeed3 - Sold
Cobb SRI | Cobb TIP | Cobb AP | CP-E DP | SU TMIC | Denso ITV22 | PTP HPFP | Synapse Synchronic BPV | Saikou Michi OCC | SU 90A RMM | SU Side Mounts | TWM Stage 2 STS w/Bushings | Dashhawk
erod550 is offline   Reply With Quote
The Following User Says Thank You to erod550 For This Useful Post:
meatball18 (12-13-2009)
The Following 2 Users Say NO Thank You to erod550 For This Un-useful Post:
 Old 12-13-2009, 04:10 PM   #13
I <3 your mom
Dash08's Avatar
Groans: 293
You don't get it man. I had the TRZ delrin mount on. It's fucking violent. Too much for a daily driver. Sure, the power transfer was amazing as well as buttery smooth shifts, but it felt and sounded like the car was going to vibrate apart. No joke.
I'm no fucking wuss, I can handle vibrations. But, when my 2008 Mazdaspeed 3 vibrates just as much as my 1956 Ford pick-up, that's where I draw the line. In this day and age, you don't need that much vibration for better performance.
I save the delrin mount for track days or as a back up now. It sits in the shed most of the time. The inserts are very cheap and effective, but doesn't help with wheel hop or direct shifts.
FreeFlyFreak (12-13-2009)
 Old 12-13-2009, 04:44 PM   #14
ms3077's Avatar
Posts: 4,024   (View Stats)
ms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the world
Groans: 974
Groaned at 738 Times in 373 Posts
I've had both the SU and CP-E RMM and both are a great improvment over stock. The SU RMM I had provided great results for roughly 8 months then the bushings started to crack. I'm sure SU would've provided new bushings but I decided to just sell the mount and try something else. Now I'm running the CP-E and it's been great!
ms3077 is offline   Reply With Quote
 Old 12-13-2009, 04:55 PM   #15
ATAZ's Avatar
Posts: 314   (View Stats)
ATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond repute
I just installed the SU MM- very nice piece, solid construction. It took loosening and removing more bolts than the TRZ needed for the install, but when it was done and installed...very happy customer. Smooth shifts, no crazy engine shifting and the vibes are there but not agonizing. Cpe, SU or TRZ poly are all good choices.
ATAZ is offline   Reply With Quote
The Following User Says Thank You to ATAZ For This Useful Post:
Dre (12-15-2009)
 Old 02-04-2010, 08:38 PM   #16
Groans: 50
Ok, so here's my update. I've had the CS mm inserts in for approximately 2 months now...and the shift feeling is essentially back to square one. In short, don't waste your funking money on these...save your pennies and go with the SU or CP-E rear mm's. Oh...but the idle vib's are still there
 Old 02-05-2010, 04:43 AM   #17
Dre
Dre's Avatar
Groans: 48
LoL.. man this thread is old.. ive had my CPE RMM in for like a lil over a month now.. love it to death.. i love feeling the vibes.. in the shifter, in the pedal, throughout the car.. feels more alive..
-TTT
 Old 02-05-2010, 08:04 AM   #18
mzdaspeed3's Avatar
Posts: 425   (View Stats)
mzdaspeed3 has a reputation beyond reputemzdaspeed3 has a reputation beyond reputemzdaspeed3 has a reputation beyond reputemzdaspeed3 has a reputation beyond reputemzdaspeed3 has a reputation beyond reputemzdaspeed3 has a reputation beyond reputemzdaspeed3 has a reputation beyond reputemzdaspeed3 has a reputation beyond reputemzdaspeed3 has a reputation beyond reputemzdaspeed3 has a reputation beyond reputemzdaspeed3 has a reputation beyond repute
Lol I noticed that Dre I started reading the posts half asleep and I was like hold up this dude has a rmm already wtf.... then the coffee kicked in and noticed it was like 2 months old. haha
mzdaspeed3 is offline   Reply With Quote
 Old 02-05-2010, 09:35 AM   #19
NCZ13's Avatar
Posts: 1,268   (View Stats)
anyone running the AWR mount?
2008 Cosmic Blue Mazdaspeed3
1986 Mazda RX7
 Old 04-16-2010, 09:37 PM   #20
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
did you get the 60 or 75?
agreed. i'd like to hear about how people like it.
it's fun to do bad things
 Old 04-16-2010, 11:23 PM   #21
Ironside's Avatar
Posts: 267   (View Stats)
Ironside has a reputation beyond reputeIronside has a reputation beyond reputeIronside has a reputation beyond reputeIronside has a reputation beyond reputeIronside has a reputation beyond reputeIronside has a reputation beyond reputeIronside has a reputation beyond reputeIronside has a reputation beyond reputeIronside has a reputation beyond reputeIronside has a reputation beyond reputeIronside has a reputation beyond repute
Says in his sig he got the 60.
2010 Dodge Challenger SRT-8, Hemi Orange
MODS: Zoomers 3" Cat-back Exhaust w/ X-pipe, Predator Tuned
PREVIOUS:
2010 Mazdaspeed 3, Black
2009 Dodge Charger SRT-8 Super Bee, Hemi Orange
2009 Dodge Caliber SRT-4, Deep Water Blue
2008 Dodge Charger SRT-8, TorRed
2004 Dodge SRT-4, Black
Ironside is offline   Reply With Quote
 Old 04-17-2010, 10:04 AM   #22
Groans: 549
well screw me.
The Following 2 Users Say Thank You to jack_hammer For This Useful Post:
Dre (04-17-2010), Staceye77 (06-02-2012)
 Old 05-21-2016, 08:32 AM   #23
MichaelBrown86's Avatar
Posts: 24   (View Stats)
MichaelBrown86 can only hope to improve
Groaned at 8 Times in 4 Posts
I read a corksport article talking about how durometer measurements don't matter and it's the design that is more important, but that's kind of hard to believe that of we have the same exact mount and have 3 different options for bushings that there won't be a noticeable difference.
MichaelBrown86 is offline   Reply With Quote
The Following User Says NO Thank You to MichaelBrown86 For This Un-useful Post:
Thepedigree13 (05-22-2016)
 Old 05-21-2016, 08:47 AM   #24
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
6+ year old thread, good job.
MS3Shadow likes this.
The Following 2 Users Say Thank You to aaronc7 For This Useful Post:
macdiesel (05-22-2016), Thepedigree13 (05-22-2016)
Corksport motor mount inserts INSTALLED! Hectik1 CX-7 > Engine, Transmission & Driveline 11 05-10-2013 01:41 PM
Should I get inserts or full motor mount? HLR Element MazdaSpeed 3 - Engine, Transmission & Driveline 5 11-25-2009 09:27 PM
Rear motor Mount Franconemo MazdaSpeed 3 - Engine, Transmission & Driveline 13 09-26-2009 10:47 AM
Page generated in 0.42267 seconds with 38 queries
